Click here to visit LS1Tech
Click here to visit Performance Trucks
Click here to visit Mod Motor Tech
Click here to visit Modern Hemi
LS1Tech Wiki
LS1TECH
Go Back   LS1TECH > LS1-LS2-LS3-LS6-LS7 PERFORMANCE > Forced Induction
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into LS1Tech.com, click logo to login
Forced Induction
Superchargers | Turbochargers | Intercoolers
Sponsored by
RPM Motorsports
Old 02-04-2009, 02:38 PM   #21
Trader Rating: 9
what the set you back? and what part number?
and i have 5 layer. is the ls9 better for boost?
Big Bird WS6 is offline   Reply With Quote
Old 02-04-2009, 02:45 PM   #22
veee8's Avatar
Trader Rating: 26
Part number is 12622033. Around $40 each.
veee8 is offline   Reply With Quote
Old 02-04-2009, 04:04 PM   #23
MY99TAWS6's Avatar
Trader Rating: 1
So do they line up perfectly?
__________________
99TAWS6"DEATH WISH" :Iron 408/APS TT, GT-7 cam,Yt 1.8s,,AFR 225, Corsa catback,Fast90 /NW90,Zex direct port,Ron Davis rad, Lonnies twin pump/80's,sfcs,Kyb agx,Hotchkis lcas/stb. Bmr aps kmember, torque arm/relo brackets,Spohn sway bars/panhard,RPM 4l80,Yank PY3400 ,Dana 60/3.54,TTM ,C5z06 brake,kvr rotors,hawk hps pads, HPtuners,electric cutout,Eboost2,Interceptor guages.
96z28 vert,97 Talon Awd Turbo ,91 talon awd auto turbo race car .
MY99TAWS6 is offline   Reply With Quote
Old 02-04-2009, 04:27 PM   #24
veee8's Avatar
Trader Rating: 26
Sure do, just installed them! Just have to torque the studs. They lined up perfectly with the combustion chambers on the heads too.
Those LS7 gaskets had to be restricting flow around the chambers. That is a spot where you would want as much flow as possible.
I think the 7 layer was designed to give a little more cushion, just like how the 5 layers have worked great for people, because they were better for boost then the 3 layer, the 7's have to work better under extreme conditions.
Old 02-04-2009, 04:36 PM   #25
fitz98ta's Avatar
Trader Rating: 17
Please keep us updated. I'm getting ready to buy some head gaskets for my new motor and need info ASAP, so HURRY UP AND TEST THEM OUT, lol, j/k.
Been following your build man, awesome car and awesome numbers. I hope these gaskets work well for you, cause I'm close to the same motor/head combo.
-Jason
__________________
RIP - 1998 Transam
10.06@141 w/ 1.64 60 ft on drag radials
forged 370, L92 heads, 238/242 605/610 114 comp cam
417 Motorsports twin turbo kit, victor jr. intake Face plated T-56 & 12-bolt w/ 3.73's
fitz98ta is offline   Reply With Quote
Old 02-04-2009, 04:45 PM   #26
MY99TAWS6's Avatar
Trader Rating: 1
Sounds great. I will likely go to those if have any water problems like you have. Too bad didn't know that when got the ls7s. And they are cheap also compared to the cometics.
Should of course hold up good after all they are used in FI build. For sure let us know if your water problems go away with these.
__________________
Old 02-04-2009, 05:05 PM   #27
ItsNotStock's Avatar
Trader Rating: 22
I am very interested. I will be running the L92's on a boosted engine pretty soon and have the same bore as you, vee8. I am interested to see if the thin decks are the cause as opposed to gasket choice. Also why are you switching to a gasket with such a big bore? Please enlighten the ignorant
ItsNotStock is offline   Reply With Quote
Old 02-04-2009, 05:13 PM   #28
MY99TAWS6's Avatar
Trader Rating: 1
What is bore of the l92 heads. Aren't ls7 4.10 also? I think 4.10 is recommended for my afr 225. Thats one reason I went to the ls7 gaskets. The ls9 look for sure superior though.
Wish a few more guys with iron blocks and afr 225 with the ls7 gaskets would chime in on how they are working out. At least the holes don't look totally blocked and didn't the lower holes look ok or are they partially blocked too? Hard to tell in the pics.
__________________
Old 02-04-2009, 05:23 PM   #29
Trader Rating: 0
I run the 5 layer mls on my L92 heads and have not pushed any water with 15psi with ARP studs. Made 763whp no problems for a few thousand miles now.
exploder is offline   Reply With Quote
Old 02-04-2009, 05:37 PM   #30
NemeSS's Avatar
Trader Rating: 71
so the l92/ls3 are 5 layer 4.1 bore .055
ls9 (l92/ls3) are 3 layer
correct?
what is the compressed value for ls9?
NemeSS is offline   Reply With Quote
Old 02-04-2009, 05:41 PM   #31
NemeSS's Avatar
Trader Rating: 71
Quote:
is this part number and price correct for the ls9 gaskets?
Old 02-04-2009, 06:13 PM   #32
382ssz28's Avatar
Trader Rating: 17
Damn Juice! What these guys don't know was the time constraints building that thing before you moved to NC. If you did catch it, it looks like you could have notched the block a smidge to clear the holes in the pic. I believe the 7 layers are the ticket. Can't wait to see the results from the other "Goodies" when you hit the dyno! Those pistons were spotless.
__________________
02 SS Ragtop-382-4L75E-Vig4000-Dana60-4.10-BMR Extreme front to rear-Strange shocks, driveshaft-Kooks 1 7/8" X 3"-Mufflex 4"-ETP Stage 2-FAST 55lb inj,92MM intake-Nick Williams 90 t/b-SLP sfi balancer,oil pump, smooth bellows, billet chain & gears,air intake-Comp Cams, pushrods,XER 281 cam,belt tensioner-Diamond,coated pistons,Callies crank,rods-ARP studs-DM Perf girdle-NX Gemini 2-NANO-Rev can-Innovate-Racetronix 255-HP Tuner MPVI PRO 486 RWHP-455RWT N/A
382ssz28 is offline   Reply With Quote
Old 02-04-2009, 08:05 PM   #33
veee8's Avatar
Trader Rating: 26
That is the correct part number for the LS9's, retail is $60, GM Parts direct had them for $35 each, local dealer prices will vary.
The LS9 is 7 layer,
The L92/LS3 is 5 layer
The LS7 is 3 layer
The LS7 bore is 4.180" IIRC
The LS9 is 4.100"
These LS9 gaskets fit my CNC ported heads perfectly, the LS7 were a little large.
Everything is buttoned up, just need to throw the manifolds on and fluiuds and spark plugs. Should have it burning corn in a hour or so.
Old 02-04-2009, 08:18 PM   #34
Haans249's Avatar
Trader Rating: 24
Send a message via AIM to Haans249
The LS9 is 7 layer,
The LS7 is 3 layer
The LS9 is 4.100"
LS7's are 4.15" bore. Great info, and thanks for sharing!
__________________
Haans249 is offline   Reply With Quote
Old 02-04-2009, 09:04 PM   #35
382ssz28's Avatar
Trader Rating: 17
Extra butter on mine!
__________________
Old 02-04-2009, 09:22 PM   #36
MY99TAWS6's Avatar
Trader Rating: 1
I got in contact with guy running 6.0 iron,ls7 with afr 225.
Here is what he said.
"You will be fine. I was running 15 to 20lbs. That was with 18 degrees of timing. Also on c16 gas.
Alot depends on your compression. A far as how much timing you can run. And of course your pistons. "
__________________
Old 02-04-2009, 11:22 PM   #37
MY99TAWS6's Avatar
Trader Rating: 1
He added this..
"i was at at 8.4 comp. i made approx 20 runs before i showed any signs of pushing water.
__________________
Old 02-04-2009, 11:52 PM   #38
veee8's Avatar
Trader Rating: 26
Well good for him... listening to hearsay is what got me into trouble in the first place, and not double checking.
I have showed photos that point out the coolant ports are partially blocked along the top of the cylinders. I know that can't be a good thing. Whether or not that had ANYTHING to do with pushing water, remains to be seen, but now I know these gaskets are ideal for MY setup.
BTW it is running great, if it is decent out tomorrow, I will go do some street testing.
Seacrest out!
Old 02-04-2009, 11:57 PM   #39
LS1Tech Sponsor
Trader Rating: 10
We run 6.2L on our 408's.I thought a long time about if I wanted the gasket tight to the bore or line up with the heads.Chose the bore and no ill affects on the FI cars.
I wouldn't expect any problems with your setup at 12-14lbs,even on 93 octain.BUT I've always stayed away from L92's and run the thicker deck heads.
FYI- we always torque the ARP's to 80 ft/lbs with the ARP lube.If that helps.
__________________
Slowhawk is offline   Reply With Quote
Old 02-05-2009, 12:01 AM   #40
Trader Rating: 14
Well crap thats the head gaskets I installed....looks like I will be swapping those out. Are you still running the Mahle pistons?
L"SS"1 is offline   Reply With Quote
Tags
12622033, gasket, gaskets, gm, head, layer, ls9, number, part
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
LS1TECH - Archive - Top
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Advertising - Terms of Service - Privacy Policy - JOBS
