Pulling the trans out, and going to freshen it up and install the Griner transbrake. Between that and the new rearend, I will be able to leave under boost instead of vacuum!
__________________ http://www.fquick.com/98turbls1
In the works:Truck mani kit, TC78, 65lb motrons, Neal Chance 9.5" TC, TH400, Innovate LC-1,AIS progressive meth
New ride: 2002 C5 Z06; monster stage 4 clutch and looking where to go from there. "Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, Totally worn out, and loudly proclaiming. . .'Wow! What a ride!'"
Hate I missed seeing it in person but I had to settle up on work repayment to a few friends so dedicated the weekend to them.. think we are all square now so when the rear end comes in I can get to paying you back for some long hours on the vette!
Very impressive start and first outing to the track, I think you did it perfectly, so that you have a baseline to start from and work your way up.
How did the car feel at 130? stable on those M&H Drag Radials? were they holding traction when boost came on?
gimme a ring tonight after 8 man! wanna hear some more about it!
The last pass of the day was the best, I was getting braver, and brake torqued it a bit, but I missed 3rd gear, (damn stock shifter!) it went to neutral, bounced off the rev limiter for a moment, I grabbed it back to 3rd right before the traps.
That pass was a 1.9768 sixty ft.... 7.5271 1/8.....101.57 1/8....11.4841 @ 122.27
Before that I ran a 2.0969 sixty... 7.803 1/8.... 101.17 1/8... 11.62 @ 129.89
As soon as that 60ft drops, the et will come way down.
Probably 3 more weeks, and I will have it ready for kill mode.
Looking forward to seeing what this beast will do with everything polished up and a man sized transbrake boosted launch and some mansized boost through the ole motor!
Will those ls9 gaskets work with ls6 heads on a lq9 block, 370 ci with approx. 9.3 compression and running up to 15 psi of boost? I'm getting ready to put my motor together and want to make sure I get this right the first time. The other question I have is about the bore size. If you have a 4.0 bore wouldn't you want a gasket closer to a 4.030 than a 4.1 so you don't have carbon build-up in the gap? Just trying to learn. Thanks
__________________ 2001 WS6 m6 convertible, sub frame connectors, strut brace, lowered, Koni's SA,s 35mm front sway 22mm rear. BMR K-member, upper and lower A-arms. APS twins, ported LS6 heads, fuel system upgrades, C-5 corvette brakes and wolfe chromoloy roll bar. Midwest fabbed 9" rearend, Textralia OZ700 clutch and GMMG catback. Dyno'ed at 550rwhp 513rwtq
You don't want too small of a bore. In my case it would not match up to the custom combustion chamber of my heads. With large valves you could run into some shrouding issues too.
The LS9 gaskets should work fine for you, but take my advice, check them on the block and the heads to make sure you won't have any issues before cinching them down for good.
It will be interesting to see what the different rear gear does as well as a the trans brake. Third gear was toast in the trans too.
The great thing is that was only 8psi.
have you brought the boost up past 8psi yet? any water pushing issues?
__________________ 64 Chevy II, forged 346 with Cartek stg 2 LS6 heads, 230/236 598/610 on 113, T56 6-speed, mini tubbed, Dana 60, Heidt's front end, 17 Boyds
The never ending project!
Pics of my Chevy II
Bringing back an old thread, but I have a question. Is it possible to run LS9 gaskets on 317 heads on a 5.7 block? or should i stick with the standard 6.0 gaskets?
