Click here to visit LS1Tech
Click here to visit Performance Trucks
Click here to visit Mod Motor Tech
Click here to visit Modern Hemi
LS1Tech Wiki
LS1TECH
Go Back   LS1TECH > LS1-LS2-LS3-LS6-LS7 PERFORMANCE > Forced Induction
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into LS1Tech.com, click logo to login
Old 09-29-2009, 05:58 AM   #241
LS1Tech Premium Sponsor
Exotic Performance Plus's Avatar
Trader Rating: 21
Quote:
Originally Posted by backchannel View Post
Did you ever calculate rotor rpm?
No we haven't. LeftCoast 32 sent us to overdrive kit that they use, and we installed it as is. Magnacharger assured us we could make big power with this blower, and we're pleased with the current performance, if we could just keep the water pump pulley from breaking apart we'd be set.
Video of the Hummer at the dragstrip.
it was very hot, the DA was 3850 plus the dragstrip was greasy, but the Hummer still did a 2.08 60 ft time and a 14.23 in the 1/4 mile. This was after driving the Hummer 75 miles to the track, so the engine was good and hot. With cooler temperatures this Hummer should get into the twelves in the 1/4 mile. Bob
__________________
Check out our huge website! http://www.exoticperformanceplus.com
260 244-4808/260 244-4821
ATI ProCharger & Moser Engineering sales and installations
Over 1 million and three hundred thousand dollars worth of Moser rearends sold!
Over 1 million and four hundred thousand dollars worth of ATI ProChargers sold!
http://www.ls1tech.com/forums/image.php?type=sigpic&userid=11410&dateline=122468  4580
Exotic Performance Plus is offline   Reply With Quote
Old 10-04-2009, 12:35 AM   #242
zippy's Avatar
Trader Rating: 0
If you have one of the broken pumps around it might be worth trying to find a 97' era Corvette pump and see if you can find a way to swap the pulley shaft and swich over to a bolt on pulley. Using the housing from the truck would make everything else work, but if you can make the Vette' pump shaft and bolt on pulley work it may live longer.
__________________
2006 Silverado RCSB 2wd: L59, GT4, G80, Z82, 41U. Outlaw CAI, Corsa catback, Zippy programming, LPE 160º thermostat, Precision Industries TBTC, Detroit Locker, Comp Cams 222º/224º .566"/.568" 112LSA, LS6 springs, flex fuel. 14.048@97.09 2.076 60' in full street trim on the 20's.
Wife's: 2002 Tahoe 2wd, LQ4, 4L60E, 3.42, Gov-Lock, 862 heads milled .015 with 2" Ferrara stainless intake valves, LS6 springs, TR224 112LSA, 160º thermostat, Zippy Programming, flex fuel.
zippy is offline   Reply With Quote
Old 10-04-2009, 09:41 AM   #243
Trader Rating: 0
What is the weight of that truck? A basic SC kit bolted to a 5.3 on a pickup runs low 14's
I hope you see 11's out of this package, there should be no reason not to..
DanO is offline   Reply With Quote
Old 10-04-2009, 07:19 PM   #244
Trader Rating: 21
The truck weighs about 7000 lbs, it's heavy. Bob
__________________
Old 10-05-2009, 08:20 AM   #245
Trader Rating: 0
Bob.How come you have not just gone with an electric waterpump?
BLNLS1/RX7 is offline   Reply With Quote
Old 10-06-2009, 05:48 AM   #246
Trader Rating: 21
Quote:
The belt still runs on the electric pump, and we really feel that having to drive the water pump is not what is causing the pulley to come loose on the shaft, but it is the belt tension that is causing the problem. Thanks. Bob
__________________
Old 10-25-2009, 12:14 PM   #247
12 Second Truck Club
supersub's Avatar
Trader Rating: 20
We're at 585 rwhp on our very conservative Mustang Chassis Dyno and this Hummer has 35" tall tires. Bob
And I found one as well....
I have absolutely no idea at what you're tying to get at. We are trying to make 14 psi with our combination... Bob
It can be done.
You need to expand on your thought's.
This is where i got with mine.
714.0 RWHP @ 5967 RPM 700.8 RWTQ 4096 RPM
14 PSI SOLID!
LSX # 416 427ci (7.0) TVS 2300
Thru A 4L80, 2500 HD Transfercase,14 bolt rear on 22" BFG's. Just the way I roll.
On a Mustang dyno.
Video:
graph was scanned in by a fellow member.
yes i have witnesses
If you wish to Contact me I will be glad to offer all the help i can.
Ray
__________________
LSX 427 S/C MPP2300 TVS 714 RWHP / 700 RWTQ LSX#00416 ||4L80E ||2500 Auto-trac T/case||Custom 14-Bolt w/ tru-trac|| WCCH Stage III L92's ||ARH 1 7/8 Long tubes||I West 8-Rib setup||Baer 6s Extreme's all four corners||3/5 drop on 22's||Full Silverado "SS" Body kit||12.46 on a 1.8 60' stuck in second gear||
supersub is offline   Reply With Quote
Old 10-25-2009, 12:35 PM   #248
Trader Rating: 21
Thumbs up
Quote:
It can be done.
14 PSI SOLID!
On a Mustang dyno.
Video:
Ray
Looks good Ray, I'll give you a call back this week. We were really busy with a GTO we put together for the Shootout, and then I had to catch up on business once I got back from the Shootout.
We consistently make over 800 rwhp with pretty much the same engine combination we have in the Hummer in other vehicles. Same cam, etc.
LS2/402 with AFR 225 heads, EPP blower cam, ProCharger F-1A at 12.5 psi of boost, in CTS-V
LS2/402 with Patriot Stage 2 LQ9 heads (customers decision to stay with his old heads) EPP blower cam, ProCharger F-1C at 15.9 psi of boost, in 2004 Corvette.
At this point, we just want to get the Hummer to be dependable without yanking off the water pump pulley. It has plenty of power to blow all four tires off of it from a standing start, not bad for a 7000 lb vehicle. Maybe the cats are hurting power, but we just want it to be dependable. We don't care if we have to drop the boost down to 10 psi to keep the pulley on it. We don't want to put a carbonite finish on the blower pulley, that may require a new belt every 300 miles. Belt alignment has been good, but we were having to run the belt much tighter than we even run the ProCharger belts to keep slippage down. It took to guys to wrestle the belt on half way, then we rotated the engine to get it all the way on. This was after using longer belts that would end up with slippage. This was after we tried Left Coast 32 overdrive kit too.
Max at Cartec is working on a Flip Drive design for us, but these designs don't happen overnight, and the customer just wants us to try to help him sell the Hummer. Like I said, I'll give you a call. Thanks! Bob
__________________
Old 10-25-2009, 02:18 PM   #249
December '07 TOTM
2001 Chevrolet Silverado 1500
Spoolin's Avatar
Trader Rating: 6
Send a message via AIM to Spoolin
Kinda interesting to see the the Torque curves of the 2300 vs the Procharger. Both make good power that's for sure!
__________________
Everyone is entitled to their own opinion. It's just that yours is stupid.
Spoolin is offline   Reply With Quote
Old 10-25-2009, 02:24 PM   #250
Trader Rating: 21
Quote:
Yes, I agree. The Magnacharger works well to get this toad moving, maybe it needs one of each on it... lol Bob
__________________
Old 10-25-2009, 02:33 PM   #251
December '07 TOTM
Spoolin's Avatar
Trader Rating: 6
and you think you have belt issues NOW!!!
__________________
Old 10-26-2009, 06:10 AM   #252
Trader Rating: 21
No doubt! lol Bob
__________________
Tags
2300, crank, drive, engine, kits, l59, ls3, magnuson, magnusson, motors, procharged, rear, stroker, superchargers, tvs, youtube
« Previous Thread | Next Thread »
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
LS1TECH - Archive - Top
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Advertising - Terms of Service - Privacy Policy - JOBS
