Click here to visit LS1Tech
Click here to visit Performance Trucks
Click here to visit Mod Motor Tech
Click here to visit Modern Hemi
LS1Tech Wiki
LS1TECH
Go Back   LS1TECH > LS1-LS2-LS3-LS6-LS7 PERFORMANCE > Forced Induction
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into LS1Tech.com, click logo to login
Old 02-21-2009, 05:32 PM   #21
Trader Rating: 0
Bob when I saw it last time I was up there I was blown away by its looks sitting on the work bench and I thought this might be something I would build my next race motor around.NowI do not think so.
BLNLS1/RX7 is offline   Reply With Quote
Old 02-21-2009, 06:26 PM   #22
LS1Tech Premium Sponsor
Exotic Performance Plus's Avatar
Trader Rating: 21
Quote:
Time will tell but I'm hoping Steve the one Magnacharger is going to send us will do what we're looking from it. Bob
__________________
Check out our huge website! http://www.exoticperformanceplus.com
260 244-4808/260 244-4821
ATI ProCharger & Moser Engineering sales and installations
Over 1 million and three hundred thousand dollars worth of Moser rearends sold!
Over 1 million and four hundred thousand dollars worth of ATI ProChargers sold!
http://www.ls1tech.com/forums/image.php?type=sigpic&userid=11410&dateline=122468  4580
Exotic Performance Plus is online now   Reply With Quote
Old 02-22-2009, 02:42 PM   #23
LS1Tech Sponsor
Trader Rating: 0
i wouldnt worry bob,we made 67x rwhp and 68x rwtq with a lil 122 ,the 2300 is an animal...you got a great team at magnason to help you out youll be fine
Hendrix-Engineering is offline   Reply With Quote
Old 02-22-2009, 02:50 PM   #24
ninetres's Avatar
Trader Rating: 27
I am excited to see this build for several reasons:
1. EPP always has great pictorials of very compete ($$$) builds on great cars
2. This is a unique, new set-up
3. It will be bad ass with 700rwhp, let alone 1000rwhp
4. I can't wait to see who gets to say "I told ya so!".....either Hellbent or the Maggie guys lol
Keep up the good work Bob!
__________________
Caliber Customs ST80 turbo kit : Fresno Performance Shortblock : Synergy Tune
Best ET 9.29, Best MPH 153 18psi, 3600lb raceweight
BUY MY TURBO KIT, TH400, Custom Drag race ZR1s/tires!!!
ninetres is online now   Reply With Quote
Old 02-22-2009, 07:02 PM   #25
12 Second Truck Club
supersub's Avatar
Trader Rating: 20
Quote:
Quote:
the Team @ magnuson has been helping me for quite some time
You will not be disappointed! I currently have a unique 122HH front inlet/rear drive setup on my truck, It was one of only a few to help create the transition for the tvs2300's front inlet/rear drive set-up to our trucks.
My tvs2300 is being built as we type,the 122HH has performed outstandingly
well with 6500lbs behind it sitting on a well built thought out LSX 427.
On only its second pass pushed 12.83 ET 1.81 60ft,7.9 1/8th mile 103mph trap. 6500lbs. @ 12psi
Iat's were very respectable thru the run and recovered fast. mostly due to the Newly designed intercooler.
All that said, the New TVS2300 I assure you will out perform with less effort.
and in short order I will prove it as well.
A few pics:
Brain is a no B.S. kinda guy!
He follows thru!
__________________
LSX 427 S/C MPP2300 TVS 714 RWHP / 700 RWTQ LSX#00416 ||4L80E ||2500 Auto-trac T/case||Custom 14-Bolt w/ tru-trac|| WCCH Stage III L92's ||ARH 1 7/8 Long tubes||I West 8-Rib setup||Baer 6s Extreme's all four corners||3/5 drop on 22's||Full Silverado "SS" Body kit||12.46 on a 1.8 60' stuck in second gear||
supersub is offline   Reply With Quote
Old 02-22-2009, 10:23 PM   #26
leftcoast32's Avatar
Trader Rating: 3
The 6 rib belt will not make the boost you are trying to make before the belt gives up. We have been running as much as 17.5 psi from a Front Inlet/Rear Drive MP122HH on an 8 rib belt system. The TVS2300 in the same Font Inlet/Rear Drive can be built to meet your goals. We have a very similar build going on right now with a 427 Darton Sleeved LS2 and WCCH L92 Heads. The goal is 15 psi and we will get there with what we have learned from the 122HH builds to date.
This is a video of an MP122HH in the same Inlet Forward/Rear Drive configuration at 15 psi with the first 8 rib setup of this design. This same vehicle has seen 17.5 psi and is currently running just over 16 psi right now with no belt issues.
leftcoast32 is offline   Reply With Quote
Old 02-23-2009, 01:05 AM   #27
zippy's Avatar
Trader Rating: 0
I assume that since you picked the TVS2300 for a 416 that your goals were 8-10psi? With that blower it seems like you'd have wanted a bit more compression and less cam???
__________________
2006 Silverado RCSB 2wd: L59, GT4, G80, Z82, 41U. Outlaw CAI, Corsa catback, Zippy programming, LPE 160º thermostat, Precision Industries TBTC, Detroit Locker, Comp Cams 222º/224º .566"/.568" 112LSA, LS6 springs, flex fuel. 14.048@97.09 2.076 60' in full street trim on the 20's.
Wife's: 2002 Tahoe 2wd, LQ4, 4L60E, 3.42, Gov-Lock, 862 heads milled .015 with 2" Ferrara stainless intake valves, LS6 springs, TR224 112LSA, 160º thermostat, Zippy Programming, flex fuel.
zippy is offline   Reply With Quote
Old 02-23-2009, 05:51 AM   #28
Trader Rating: 21
Sounds good, thanks!
Thanks, we appreciate it! I certainly hope we make the horsepower we're looking for, and it sounds like we will.
He follows thru!
Certainly looks very promising, thanks, nice pic's!
Looks good, we're being sent a 10 rib blower that we're swapping in for the one we had on it. Thanks.
Quote:
Our you talking about our build here? We're at 9.3/1 on the compression ratio, right where we want it to be. The cam is our EPP blower cam, which has worked great on many other builds, turbo, centrifical and positive displacement.
Here is the dyno sheet from a Cadillac CTS-V with an LS2 402, our blower cam and off the shelf AFR heads, stock LS2 intake/throttle body, with an ATI ProCharger F-1A at 14.4 psi of boost.
Bob
__________________
Old 02-24-2009, 06:11 AM   #29
Trader Rating: 21
Thumbs up
Update: Brian at Magnacharger called me yesterday and mentioned that we could do this as a cog drive kit. Cog drive it is! Bob
__________________
Old 02-25-2009, 12:21 PM   #30
Trader Rating: 0
Bob,
You have outstanding attention to detail! Thank you.
Will you please get some video of how your cam sounds with this setup? I imagine the idle would sound nuts!
Thanks, David
94 slow is offline   Reply With Quote
Old 02-25-2009, 01:00 PM   #31
Steel Chicken's Avatar
Trader Rating: 2
looks nice!
good to see Brian around to help work out the issues.
So much maggie hate though makes baby jesus cry.
__________________
2004 GTO : 655/598 HP/TRQ - Maggie 122 @10PSI, ETP 225 heads, SW LT's, electric cut-outs, magnaflow catback, 224/236/116 EDCam, RPS clutch, Meziere. NW 90mm TB. Pedders Track II/Konis & Hotchkis. GMM Ripshift. Banshee hood. Corn juice fed and 2 bar Self-tuned. Chock full of evil.
Steel Chicken is offline   Reply With Quote
Old 02-25-2009, 03:05 PM   #32
2005 Cadillac CTS
CTSV_510's Avatar
Trader Rating: 1
He follows thru!
If you call Magnuson, ask for Brian and you WILL be taken care of.
__________________
05 CTS-V / maggie 2.8 / b&m shifter / kooks lts 1 3/4 + cats / magnaflow / k&n cai / fg2 shocks / hotchkis sways / hawk hps
CTSV_510 is offline   Reply With Quote
Old 02-25-2009, 08:26 PM   #33
Trader Rating: 21
Thumbs up
Quote:
Originally Posted by 94 slow View Post
Bob,
Thanks, David
Thanks, we appreciate it! Will do with the video.
Quote:
Originally Posted by Steel Chicken View Post
looks nice!
Brian seems like a true car guy which is really cool!
Quote:
No doubt, ext 252! Bob
__________________
Old 02-27-2009, 10:14 PM   #34
2500HD > G8 FTW
moregrip's Avatar
Trader Rating: 5
I see Magnuson/Brian taking care of you, great service from a great company!
__________________
-2005 Chevrolet Silverado 2500HD ECSB 2WD.....Late Model Hot Rod.....Soon to be Tow Rig
365 CID motor built by "Rex", Magnuson TVS 2300,WCCH StageII LQ9 heads, EDC Cam, SW Headers, Magnaflow Exhaust, CPT 4L80E, PI 2800 TC, TRACK: Real Racing 16x12 wheels, M&H DOT Cheater Slicks, STREET: Intro Pentia 8 20x10 wheels, BFG KDW's
-2008 Toyota Tacoma X-Runner 6SPD V6 2WD.....Daily Driver
-Reserved for Pre-1975 Project Vehicle
-2002 Honda CBR954RR
.....FOR SALE $6500
moregrip is offline   Reply With Quote
Old 02-27-2009, 11:34 PM   #35
sultan(ZR-1)KSA's Avatar
Trader Rating: 0
a saudi customer MMMMMMMMM????? is it hanny ???
sultan(ZR-1)KSA is offline   Reply With Quote
Old 02-28-2009, 06:54 AM   #36
Trader Rating: 21
Quote:
We are building this H2 for a business in Saudi who is having it built for one of their customers. I don't know the actual customer's name. Bob
__________________
Old 03-03-2009, 05:44 AM   #37
Trader Rating: 21
We are hoping to get the upgraded blower from Magnacharger this week. We're anxious to get this truck back on the dyno! Bob
__________________
Old 03-03-2009, 09:37 AM   #38
Chris'stransam's Avatar
Trader Rating: 3
where can i get one of these for my 408 build for my Transam!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!
Chris'stransam is offline   Reply With Quote
Old 03-03-2009, 06:28 PM   #39
Z06PSI's Avatar
Trader Rating: 22
Quote:
Z06PSI is offline   Reply With Quote
Old 03-14-2009, 01:51 PM   #40
cam
Trader Rating: 6
Updates?
__________________
------- Five years strong! In many fast cars and ------- NOT ONE BREAKAGE YET!
cam is offline   Reply With Quote
Tags
2300, crank, drive, engine, kits, l59, ls3, magnuson, magnusson, motors, procharged, rear, stroker, superchargers, tvs, youtube
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
LS1TECH - Archive - Top
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Advertising - Terms of Service - Privacy Policy - JOBS
