Click here to visit LS1Tech
Click here to visit Performance Trucks
Click here to visit Mod Motor Tech
Click here to visit Modern Hemi
LS1Tech Wiki
LS1TECH
Go Back   LS1TECH > LS1-LS2-LS3-LS6-LS7 PERFORMANCE > Forced Induction
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into LS1Tech.com, click logo to login
Forced Induction
Superchargers | Turbochargers | Intercoolers
Sponsored by
RPM Motorsports
Old 03-22-2009, 08:08 PM   #21
108dragon's Avatar
Trader Rating: 5
Belt lineup issues with any of these kits is almost solely dependant on what front drive you intend to go with (C5, F body, GTO, CTS-V, etc..)
Kenne Bell prides themselves on a front drive setup. The rear inlet is just one more problem to have to overcome in its installation in an F Body. The Kenne Bell unit is, from all available media and tests, more efficient than both the Magnuson or Whipple. In tests against the Magnuson, the Kenne Belle blower ran half as hot (important considering it is a roots type) and had a lot wider boost band.
The Whipple LS1 has NO provision or plan for mounting in an Fbody or Vette. Sad because they have some REALLY cool dual blower setups.
I'm STILL having problems installing my Paxton Novi2000 in the 4th gen Camaro.
108dragon is offline   Reply With Quote
Old 03-22-2009, 08:10 PM   #22
2002 Chevrolet Camaro
litemup02's Avatar
Trader Rating: 31
Here is the one from LMS...had to save that pic.....sweeeet
__________________
"02" Camaro SS M6 - #3203 - 224 Cam l LT's w/ORY l Corsa l C M E
l Built 6sp. l Moser 9in. w/4.11's l PST D/S l UMI susp. l Koni 4/4's & Hotchkis l
Tuned by Speed inc. l 12.1 at 113
litemup02 is offline   Reply With Quote
Old 03-23-2009, 12:25 AM   #23
DAVESS02's Avatar
Trader Rating: 26
Whipple offers a setup designed to be used in a sandrail. I've talked a few times with 2 different guys from there and was told that on a 10-15 PSI 3.3, I would need to run their 10 rib setup. The kit comes with the blower, manifold, heat exchanger, fuel rails, and drive kit, and I think a bypass valve. The drive is designed/recomended to be used with an ATI steel balancer. The intake is just a simple adapter from the blower housing to a 90 mm t-body. A usable inlet manifold would need to be fabricated to put the t-body out front similar to a kenne bell as the adapter they sens would be unusable in a car. I also talked with kenne bell about an f-body kit..... for 2 minutes. Got the brush off in short order as they want no part of doing an f-body kit.
At any rate, it can be done with either setup but you have to be willing to do serious metal fabricating as well as have a means to trim the glass if necessary. Also since the kenne bell setup only has a vette drive, you'd also have to modify your drive to the vette style. After looking at all the complex turbo and F-2 setups with all the mods and time invested to make big power I dont believe that a screw is much more involved. I do understand that its much more intimidating.
__________________
DAVESS02 is offline   Reply With Quote
Old 03-23-2009, 09:03 PM   #24
02SOMWS6's Avatar
Trader Rating: 5
I might be putting a Kenne Bell on my 3rd gen just because it has all the room in the world compared to the 4th gen
__________________
Best track time-10.5 @ 130 with a 1.45 60ft.
Slowhawk tuned 473rwhp 407rwtq
10.6 pass http://video.ls1tech.com/video/f345e...3b0126a3be.htm
http://videos.streetfire.net/video/b...3b012749e1.htmhttp:/
GM hightech shootout photo's
http://www.gmhightechperformance.com..._trans_am.html
NBM 2000 convertable-under construction-6.0L
02SOMWS6 is offline   Reply With Quote
Old 03-23-2009, 09:58 PM   #25
elias_799's Avatar
Trader Rating: 5
i think if you make the engine mounts shorter you will have some serious clearance issues with the oil pan and the road. but if it is not a street car then it is all good.
if i had the money for this project i would twincharge my camaro. Whipple being fed by twin turbos. pretty sure nobody did that on a camaro yet.
elias_799 is offline   Reply With Quote
Old 03-23-2009, 11:00 PM   #26
DAVESS02's Avatar
Trader Rating: 26
Hell, we're all still waiting for someone to produce pics of just the Whipple on a F-body!!!
__________________
Old 03-24-2009, 04:29 PM   #27
108dragon's Avatar
Trader Rating: 5
Quote:
The sheer size and height of the whipple blower precludes it from serious consideration for use on a 4th gen fbody. If you are cutting into the windshield to get it to fit, you are also cutting into the dash. Getting the whole thing to seal is going to be a nightmare. On top of everything else, the windshield is part of the unibody's structural integrity. Cutting a chunk out of it is going to cause it to crack everytime the body twists... been there and bought the t-shirt. hahaha Might work on a plexi windshield show car. But not the hot ticket for a daily driver.
Old 03-25-2009, 12:03 PM   #28
STEEPSS's Avatar
Trader Rating: 5
we're getting some good discussion going on here. Keep it coming
I know i saw a picture of someone who put a whipple on a camaro on this board. It would have been about a year ago.
+1 on NOT cutting the windshield
__________________
2002 SOM Z/28 - UMI - BMR - QA1 - Vig 4000 - AFR 205 - VRX4 - Moser - Strange
I have a 2002 Yamaha R1 for sale.http://www.ls1tech.com/forums/vehicl...l#post12295897
STEEPSS is offline   Reply With Quote
Old 03-25-2009, 12:43 PM   #29
THEMADTYPH00N's Avatar
Trader Rating: 1
Hell I'd be happy if someone could just get a TVS blower in one of these cars.
__________________
1991 GMC Syclone
1993 GMC Typhoon
1995 Camaro Z28
1999 Firehawk
2008 Cobalt SS
2010 Corvette ZR1
THEMADTYPH00N is offline   Reply With Quote
Old 03-25-2009, 10:49 PM   #30
DAVESS02's Avatar
Trader Rating: 26
I had a chance to check out a 3.3 Whipple up close tonight and take a few measurements. 14.5" front of gear case housing to the inlet surface face, 6.5" from the base of the supercharger to the top, 7.5" if you include the adapter on the bottom for the manifold, and 9" wide.
__________________
Old 03-26-2009, 01:47 AM   #31
108dragon's Avatar
Trader Rating: 5
The Magnuson 112 and 122 measure 9.36" from the top of the block to the top of the blower. I can't imagine the TVS being any less. This includes the parallel drive system, intercooler, and thier low profile manifold.
From all the pics on Whipple's site, It looks to be taller than 9.36". Plus, it is a rear inlet. If you cut into the bottom of the cowl vent area and drew air in from that point. You MIGHT get it to work. But it would drown in rain or even if you washed your car. The Whipple is also the more efficient blower for the job. But the installation makes it impractical for an Fbody. Also a possiblity to draw the air in from under the dash from the inside of the car. But it would be awful noisy. And you would have to roll with the windows down to prevent suffocating the induction.
Old 03-26-2009, 03:38 AM   #32
RoDan's Avatar
Trader Rating: 0
Send a message via AIM to RoDan
Quote:
yeah and sucking your ear drums out of your head... lol
__________________
Black 2001 T/A M6, 4.10, Mac mids, HP Tuners. Ram Air: The faster you go, the faster you go.
Black 2001 Z28 Hardtop A4, 3.23, HP Tuners, 3/4 cam & headers -- 11.45 @ 116, 1.521 60' (Old Setup)
West Tennessee F-Body Association
RoDan is offline   Reply With Quote
Old 04-01-2009, 12:42 AM   #33
STEEPSS's Avatar
Trader Rating: 5
Quote:
haha so true. but as long as you're hacking up a car, what's another cut in the firewall for some intake tubing? just run it up through what's left of the cowl?
__________________
Old 04-09-2009, 06:15 PM   #34
kmracer's Avatar
Trader Rating: 1
i cant imagine how nuts a big wipple or KB would be in an ls1 car. 700rwtq at like what... 2300rpm?
kmracer is offline   Reply With Quote
Old 04-16-2009, 12:00 PM   #35
STEEPSS's Avatar
Trader Rating: 5
Quote:
Originally Posted by kmracer View Post
i cant imagine how nuts a big wipple or kb would be in an ls1 car. 700rwtq at like what... 2300rpm?
yup:d
__________________
Old 05-02-2009, 10:21 AM   #36
Pretyflywiteguy's Avatar
Trader Rating: 0
so 7.5" from the top of block to the top of the blower? Was this an intercooled unit?
__________________
Rebuilding..
Pretyflywiteguy is offline   Reply With Quote
Old 05-02-2009, 12:09 PM   #37
Trader Rating: 6
Send a message via Yahoo to Black FormulaLs1
sounds like the perfect idea to build w/ a roller car... do your own 408 h/c/ whipple ...thatd just be titts
__________________
346 Forged bottom end,P&P 241's, Lunati cam, Ram VDS Pkg, Stage 2 TICK PERFORMANCE T56, moser 12 bolt...sooon #'s and 200 shot
old times with just exhaust and Dr's..
12.56 @ 110 - 1.85 60ft
Black FormulaLs1 is online now   Reply With Quote
Old 05-02-2009, 03:49 PM   #38
DAVESS02's Avatar
Trader Rating: 26
Quote:
It was on a ford GT with a whipple conversion. I only measured the blower itself and the adapter plate. The intake with intercooler would be additional but I couldnt really get a relevant measurement since the modular and LS manifold are totally different. I'm betting another 4" for the manifold for an overall height of 11.5".
__________________
Old 05-02-2009, 06:54 PM   #39
Soul Crusher's Avatar
Trader Rating: 0
I bleieve it's the KB 2.8.
kenne-bell-camaro-fabd-k-member-dsc0008500.jpg   kenne-bell-camaro-fabd-k-member-306433706_1042953638_0.jpg
Soul Crusher is offline   Reply With Quote
Old 05-03-2009, 08:36 AM   #40
Trader Rating: 0
Send a message via AIM to Killer_Z Send a message via Yahoo to Killer_Z
whipple for a few years now redisigned their intercooler/manifold to a much lower profile, so its shorter, not sure if its for the LSX's though. I think a 2.3 whipple would have better chances of fitting in the engine bay of an f-body, and still be able to put out some great numbers.
oh and whipple for several years now has been making all their own stuff. they dont have lysholm make them any more. the "new" whipple's out perform the old lysholm units.
__________________
no replacement for displacement.. end of story
Killer_Z is online now   Reply With Quote
Tags
1991, 4th, adapter, bell, camaro, fbody, gen, height, kenne, kennebell, kenny, magnuson, member, supercharger, tubular, whipple
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
LS1TECH - Archive - Top
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Advertising - Terms of Service - Privacy Policy - JOBS
