Click here to visit LS1Tech
Click here to visit Performance Trucks
Click here to visit Mod Motor Tech
Click here to visit Modern Hemi
LS1Tech Wiki
LS1TECH
Go Back   LS1TECH > LS1-LS2-LS3-LS6-LS7 PERFORMANCE > Forced Induction
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into LS1Tech.com, click logo to login
Old 03-22-2009, 05:58 PM   #21
7 Second Club
Phil99vette's Avatar
Trader Rating: 11
Quote:
Originally Posted by crf538 View Post
did you try to hold it back with the 2 step and no trans brake at 2400 or whenever you said it started moving? I ask because Ive got bs3 and no brake and i was wondering if the 2 step would make much of a difference foot braking. seems like it would build boost faster if you could open up the throttle blade all the way sitting at the line.
There is definitely a huge difference between footbrake + as much gas as you can go before it pulls vs footbrake + 2/3 step. 2/3 step and WOT will build boost way quicker.
__________________
Phil - ProStreet Motorsports - Current Project "The Renegade "
Best 60' 1.25 | Best 330' 3.18 | Best 1/8 4.701 Best MPH: 164 | Best 1/4 7.29 | Best 1/4 MPH 198
2000 Mustang - LSx - ETP LS7 heads - BIG STUFF 3 - Precision 106mm Turbo - Custom fabricated headers - WolfeRaceCraft 25.5 Chassis
Virginia Speed - Kurt Urban Performance - MADMAN Racing and Co. - Precision turbo - Wolfe Racecraft -
Phil99vette is online now   Reply With Quote
Old 04-01-2009, 02:44 PM   #22
cjg454ss's Avatar
Trader Rating: 21
i have a lingenfelter 2 step with timing retard and a stock pcm. how could i add timing to build boost? anyone know a trick
__________________
2002 SS A3 88mm
2006 SRT8 Jeep Vortech
2006 F350 6.0 DRW
cjg454ss is offline   Reply With Quote
Old 04-01-2009, 03:04 PM   #23
Trader Rating: 0
You want to retard the timing to build more boost. At a set rpm the more retard = + psi
cause4panic is offline   Reply With Quote
Old 04-01-2009, 04:10 PM   #24
Zombie's Avatar
Trader Rating: 2
Send a message via AIM to Zombie
Quote:
That is correct if you have a manual trans, he has a Auto so he needs to ADD timing.
__________________
SX80 butt mounted, Rossler TH400, PTC 3600 stall, forged 8.7:1 6.0L, Moser 9", 2.75 Gears.
SX80 Best pass 10.D0HD0H1 @ 135.2[1.49 60'] 15psi
The Heretic of the LS1Tech.com FI section
Zombie is offline   Reply With Quote
Old 04-01-2009, 04:22 PM   #25
98Camarod's Avatar
Trader Rating: 24
What 2 step is it and what the hell is a 3 step?
__________________
Ebay Turbo Kit l Cam l Moser 9" l th400 swap in progress
98Camarod is online now   Reply With Quote
Old 04-01-2009, 05:47 PM   #26
patriotformula's Avatar
Trader Rating: 22
Send a message via AIM to patriotformula
Quote:
Your lingenfelter 2 step should have a retard function that can be setup to work while on the brake... IF not you can send your lingenfelter 2 step in for an update (not sure on extra expense).
__________________
98 Camaro SS MS4 cam only, TH400 w/ transbrake, Midwest Chassis Fabricated 9 inch
patriotformula is offline   Reply With Quote
Old 04-01-2009, 10:32 PM   #27
cjg454ss's Avatar
Trader Rating: 21
yeah i have the retard function. but i dont have the advance function. being an auto most say ad timing. is it possible?
__________________
2002 SS A3 88mm
2006 F350 6.0 DRW
Old 04-02-2009, 12:33 AM   #28
Trader Rating: 22
For that I think you're gonna have to get something similar to what Veee8 has... sorry I missed that on your post
__________________
Old 04-02-2009, 03:36 PM   #29
veee8's Avatar
Trader Rating: 25
My 2-step is built in to the Big Stuff 3, and has full control over timing when engaged.
__________________
388ci C5R block, Virginia Speed Double O-Ring, ETP 265's, Solid Roller, Jesel, Callies, Oliver, BS3, TH400, MWC Race 9" and a big ass turbo!
http://www.virginiaspeed.com
www.midwestchassis.com
veee8 is offline   Reply With Quote
Old 04-02-2009, 04:13 PM   #30
Trader Rating: 0
Quote:
Which one is it?
What other 2 step will do the same with stock PCM?
Denali08 is offline   Reply With Quote
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
LS1TECH - Archive - Top
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Advertising - Terms of Service - Privacy Policy - JOBS
