Click here to visit LS1Tech
Click here to visit Performance Trucks
Click here to visit Mod Motor Tech
Click here to visit Modern Hemi
LS1Tech Wiki
LS1TECH
Go Back   LS1TECH > LS1-LS2-LS3-LS6-LS7 PERFORMANCE > Forced Induction
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into LS1Tech.com, click logo to login
Forced Induction
Superchargers | Turbochargers | Intercoolers
Sponsored by
RPM Motorsports
Old 04-26-2009, 10:47 AM   #41
veee8's Avatar
Trader Rating: 26
Quote:
Originally Posted by HUNTER02SS View Post
If you pushed water, you lifted the head's.This is why you overheated on the way back. You will need to change out your head gasket's.No since on doing a compression check until you do that.
Yeah I have been down that road before, I have come to the conclusion that it is not a specific boost level, but a power level when it does it. 21 psi on the dyno, compared to 17 psi under heavy load on the track. I am going to o-ring this time.
veee8 is online now   Reply With Quote
Old 04-26-2009, 10:54 AM   #42
Trader Rating: 0
Quote:
Originally Posted by veee8 View Post
Right now the exhaust is a 5" DP that dumps just past the passenger fender, it is fairly quiet.
You mean before or after the k-member? Kind of tight to squeeze 5" above k-member
Denali08 is offline   Reply With Quote
Old 04-26-2009, 11:34 AM   #43
382ssz28's Avatar
Trader Rating: 17
Great job Chris!! The guys up here in Michigan are pullin for you!
__________________
02 SS Ragtop-382-4L75E-Vig4000-Dana60-4.10-BMR Extreme front to rear-Strange shocks, driveshaft-Kooks 1 7/8" X 3"-Mufflex 4"-ETP Stage 2-FAST 55lb inj,92MM intake-Nick Williams 90 t/b-SLP sfi balancer,oil pump, smooth bellows, billet chain & gears,air intake-Comp Cams, pushrods,XER 281 cam,belt tensioner-Diamond,coated pistons,Callies crank,rods-ARP studs-DM Perf girdle-NX Gemini 2-NANO-Rev can-Innovate-Racetronix 255-HP Tuner MPVI PRO 486 RWHP-455RWT N/A
382ssz28 is offline   Reply With Quote
Old 04-26-2009, 12:21 PM   #44
98turbls1's Avatar
Trader Rating: 17
Send a message via AIM to 98turbls1 Send a message via Yahoo to 98turbls1
Great job man!!! that's definitely moving out..
__________________
http://www.fquick.com/98turbls1
In the works:Truck mani kit, TC78, 65lb motrons, Neal Chance 9.5" TC, TH400, Innovate LC-1,AIS progressive meth
New ride: 2002 C5 Z06; monster stage 4 clutch and looking where to go from there. "Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, Totally worn out, and loudly proclaiming. . .'Wow! What a ride!'"
98turbls1 is online now   Reply With Quote
Old 04-26-2009, 03:20 PM   #45
1972 Chevrolet Nova
My Garage
pwrtrip75's Avatar
Trader Rating: 6
Send a message via AIM to pwrtrip75
I think we raised some eyebrows with the little street car!
Street cars have chutes? lol.
__________________
99 Transam - 5.3L w/ GT45 -10.76 @ 128 w/ 1.83 60ft and broke something.
99 Vette FRC - stock
72 Nova -New twin setup in the works. (former turbo 5.3)
FS/Trade? 02 Yamaha R6 Red/Blk - $3600
pwrtrip75 is offline   Reply With Quote
Old 04-26-2009, 03:55 PM   #46
11 Second Truck Club
JJ_TURBO's Avatar
Trader Rating: 4
Send a message via Yahoo to JJ_TURBO
Congrats on your setup, car looks and runs bad azz. How do you like the BS3, do you tune it yourself?
__________________
Trick Turbo Kit Tuned/Installed By Nelson Performance 10.74 @ 127.62 60' 1.57
NORIBILT Twin 76gts kit cooming soon.
JJ_TURBO is offline   Reply With Quote
Old 04-26-2009, 04:19 PM   #47
Nimitz87's Avatar
Trader Rating: 15
Send a message via AIM to Nimitz87
The whole suspension is Midwest chassis drag setup, 9", LCA's, PHB, DR Anti Roll, long torque arm etc. Afco coilovers in the front Afco shocks, stock springs in the rear. 3.00 gear 28" tires, crossing the traps around 6200. The most boost I have lecft at was 8 psi with the 1.33 60ft. This track probably could have held more, it will be something to play with.
thanks for the info, what was your trap @ 6200ish rpm? seems your rpm's are way up there for the mph?
driving on the street, what is the max boost you see, and when do you see it?
Chad
__________________
Engine: heads/cam dart/torquerV2 stock bottom end HS rockers, ls6 intake
Drivetrain: M6(soon to be A3) Moser 9 inch, strange pro case 4.11's
Suspension: UMI LCA's/SFC's/PHB QA1's, midwest Chassis torque arm !front swaybar
Nimitz87 is online now   Reply With Quote
Old 04-26-2009, 08:42 PM   #48
HUNTER02SS's Avatar
Trader Rating: 21
It has always been about the power level. I wonder if you can get a set of those gaskets or o-rings like they use in canada, I believe. A "pyramid " style head gasket or o-ring setup I think it is called? I had my old heads o-ringed and it helped out alot, but it eventually pushed water as well. How much timing are you at. It seems like 15-16deg. seemed to help out alot as well.
18 and over mine started to push water sooner.
__________________
LSX 427-FI-94mm Turbo,
Turbo Kit by Josh@ Kentucky Turbo
Hunter's Performance Solution's.com
HUNTER02SS is online now   Reply With Quote
Old 04-26-2009, 09:14 PM   #49
veee8's Avatar
Trader Rating: 26
Quote:
Chute is easily removable
Chad
155mph, I have a boost controller, I adjust the boost all the time, as little as 8 as much as 21, full boost by 4000 or so.
I am going to be looking into orings this week. 21-24* on E85 and it was perfect for a long time, until we ran in cooler air, and 17 psi.
It pushed before at 12* on 93 and 118 cocktail. It always seems to be right around the 1000 hp level on this setup with the L92's.
Old 04-26-2009, 09:15 PM   #50
veee8's Avatar
Trader Rating: 26
Here is some photos from Friday....
This one if for the nay sayers, that a 3.0 gear wont work, 1.33 60 ft. 8 psi of boost on launch at 3500 rpm.
Old 04-26-2009, 11:43 PM   #51
fast582's Avatar
Trader Rating: 0
Default 8 seconds
Damm Chris you got that bird flying !! congrats very impressive ! wish i was there to see it. You have came a long way you should be proud ! keep up the great work !!! SAM
fast582 is offline   Reply With Quote
Old 04-26-2009, 11:49 PM   #52
fitz98ta's Avatar
Trader Rating: 17
Very nice man!! I have been following your build and you only keep impressing me.
have you thought about trying the L19 head studs? pricey but may be an option as well. I have a buddy with them and he is running patriot heads making 1000 to the ground with no head lifting. I'm pulling for you to figure out the head lifting problems since i am running the L92 heads as well
congrats again
__________________
RIP - 1998 Transam
10.06@141 w/ 1.64 60 ft on drag radials
forged 370, L92 heads, 238/242 605/610 114 comp cam
417 Motorsports twin turbo kit, victor jr. intake Face plated T-56 & 12-bolt w/ 3.73's
fitz98ta is offline   Reply With Quote
Old 04-27-2009, 09:12 AM   #53
HUNTER02SS's Avatar
Trader Rating: 21
Those are some good pics. I am going with a 2.75 gear in mine this time.
Your car is looking good!
__________________
Old 04-27-2009, 10:06 AM   #54
veee8's Avatar
Trader Rating: 26
Thanks guys, I will do some research this week on the head lifting issue, and weigh all the options.
Old 04-27-2009, 10:58 AM   #55
Trader Rating: 12
Congrats on the new time! Car is hauling ass for sure.
LS1RedZ is offline   Reply With Quote
Old 04-27-2009, 11:36 AM   #56
HUNTER02SS's Avatar
Trader Rating: 21
Check with VINCE, he is goin bottom eight at 170mph and has a 4 bolt head setup. From what I understand he had very minimal head gasket issues?
__________________
Old 04-27-2009, 05:05 PM   #57
tomz28's Avatar
Trader Rating: 11
dude those pics rock
those back tires are screaming help me LOL
im going auto for sure no more M6 for this guy
__________________
2000 Z28, APS W/LG turbos, LS2, TFS 225, Viper M6, Strange 12 bolt, 3.42, 630rwhp 660tq @ 12psi,on Meth, on stock bottom end (new numbers coming soon)
tomz28 is offline   Reply With Quote
Old 04-27-2009, 06:05 PM   #58
veee8's Avatar
Trader Rating: 26
Shawn at Virgina Speed has a couple of tricks we are going to try.
Old 04-27-2009, 09:00 PM   #59
HUNTER02SS's Avatar
Trader Rating: 21
I may be mistaken, but I think Shawn did Vince's motor as well? You are in good hand's!
__________________
Old 04-27-2009, 11:31 PM   #60
Trader Rating: 0
Send a message via AIM to turbociv910
"fairly" is what your calling it now?
turbociv910 is offline   Reply With Quote
Tags
mor20140
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
LS1TECH - Archive - Top
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Advertising - Terms of Service - Privacy Policy - JOBS
