Click here to visit LS1Tech
Click here to visit Performance Trucks
Click here to visit Mod Motor Tech
Click here to visit Modern Hemi
LS1Tech Wiki
LS1TECH
Go Back   LS1TECH > LS1-LS2-LS3-LS6-LS7 PERFORMANCE > Forced Induction
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into LS1Tech.com, click logo to login
Old 06-24-2009, 02:05 PM   #1
GFORCE1320's Avatar
Trader Rating: 15
Send a message via MSN to GFORCE1320
Default Gforce Engineering's GTO Turbo build
I wasnt going to do the turbo build thread thing but some of the vendors that make the parts I'll be using twisted my arm so here it is.
It wont be a real fast build as I have been swamped so I'll be farming some of the work out so I can get it done this summer.
I not only have a turbo system to fab up but I also have to start from scratch on a new engine after grenading it this spring.
This build is the reason I have started the big 33 spline spool and stub product line. I'll need them when I try putting 1300+ hp to the ground.
First stop is Holzman Racecars in Wichita KS for the parachute, front and mid motor plates and some misc fab work.
Holzman is also helping us with the development work on the tubular suspension parts.
Here are the plans.
ez94x billet turbo form Forced Inductions www.forcedinductions.com
twin 50mm bov's from Turbo Smart (Forced Inductions is a dealer)
64 mm Turbo Smart waste gate
Edelbrock Super Victor intake
427 ci engine (Either ERL or LSx block), 235 Trick Flow heads, Oliver billet rods, Callies Dragon slayer crank, Wiseco turbo pistons.
Aeromotive Belt drive fuel pump
The car will also be going on a major diet getting a Gforce Engineering tubular front k-member, coil overs all the way around, Gforce Engineering manual steering kit, Rocksand Racing manual brake kit, Gforce Engineering rear tubular cradle, Gforce Engineering tubular rear control arms and some other light weight suspension pieces.
Edelbrock sent me a Jr instead of a Super Victor so this one is for sale
First on the removal list is the ABS system and those dam pesky brake lines
Holzman Racecars got a good start on the motor plates today.
Went with the new Comp Engineering front and mid plates.
__________________
Gforce Engineering AKA GFORCE1320.com
403ci LS2, Dart CNC 225's, direct port, TH400 & 9" Chance Converter
GFORCE1320 Level 2 HALF SHAFTS and stubs
9.41 @ 144mph, 1.41 60ft on the spray
Proving the stock GTO IRS can hang with anything!
Fastest OEM IRS GTO in the USA
GFORCE1320 is offline   Reply With Quote
Old 06-25-2009, 01:05 AM   #2
Turbo Director
NA$TY-TA's Avatar
Trader Rating: 18
Send a message via AIM to NA$TY-TA Send a message via MSN to NA$TY-TA
gunna be fun
__________________
1998 Bright Green Metallic TA. SOLD
STENOD Single S88 Turbo Kit,370ci,Glide, S60.
1132rwhp / 970rwtq
9.26 @ 150.58 MPH
2005 IBM GTO
Just a couple mods for this one.. I swear
NA$TY-TA is offline   Reply With Quote
Old 06-25-2009, 01:24 AM   #3
LS1Silverado05's Avatar
Trader Rating: 31
Look forward to watching this one!
__________________
1994 Z28 A4 Bolt-Ons/4.10s SOLD
2001 SS A4/M6 Bolt-Ons,4000stall,231/237 592/603 111.5, Moser 9" 4.30s SOLD
1993 Z28 M6 Full Bolt Ons/ 3.73s SOLD
1998 SS A4 Single T70 Turbo http://www.ls1tech.com/forums/forced...old-build.html
LS1Silverado05 is offline   Reply With Quote
Old 06-25-2009, 06:11 PM   #4
LS1TECH Sponsor
DrTurbo's Avatar
Trader Rating: 3
Our Billet EZ94X should easily take you to your goal. That turbo is sick...
One of our customers that runs ORSCA EZ street, won last weekend with that turbo. Great unit and makes big power....he's not even pushed it all the way yet.
__________________
www.ForcedInductions.com
www.TurboDiesels.net
We will beat or match anyone with a lower in-stock advertised price!
1-(256)-658-5798
1-(256)-796-1230
DrTurbo is offline   Reply With Quote
Old 06-25-2009, 08:01 PM   #5
GFORCE1320's Avatar
Trader Rating: 15
Got the chute mount pretty much done today. I'll throw some pics up later.
Next is the mini tubs and reworking the rear control arms to use hiem ends, replacing some of the heavy arm with tubing so we can run a 325 drag radial.
Going to also install some double adjustable QA1 coil overs on the back and get rid of the coil springs and drag bags.
This stuff will later be available from us in a kit form of course
__________________
Old 06-26-2009, 10:38 AM   #6
Trader Rating: 0
Send a message via AIM to Blownz28man
Lookin good! Lil off supject but i'm diggin those wheels..what brand? What sixe and where did you get them?? They clear your brakes ok? Thanks
Blownz28man is offline   Reply With Quote
Old 06-26-2009, 10:44 AM   #7
GFORCE1320's Avatar
Trader Rating: 15
They are Bogarts, not cheap but very good quality and light weight.
__________________
Old 07-15-2009, 10:01 PM   #8
GFORCE1320's Avatar
Trader Rating: 15
Havent gotten much of the turbo work done yet, still doing the chassis mods for larger tires and beefing everything up to hold 1300+hp.
Got the rear control arms modified to accept a 325 drag radial (after a mini tub).
I'll also be switching to a double adjustable set of Strange Engineering coil overs.
By doing the tubular arm and the hiem joint position at an angle in the bracket, you'll gain about 2" of tire clearance.
The control arm you see here still has the coil spring mount. The ones I will be running will not have the coil spring mount.
Here is what we are doing for the mini tub.
We pretty much went with the largest mini tub possible, clear to the frame.
We took out the coil spring mount too.
This is the biggest mini tub you can do without cutting into the frame rails.
__________________
Tags
gto, kits, mini, tub
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
LS1TECH - Archive - Top
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Advertising - Terms of Service - Privacy Policy - JOBS
