I've been doing a bit of research in the world of FI and I've gotten to the point where I understand the schematics and technology alot more that I did before. My question is what A/R are your turbos and what influenced the you to use that selection? I'm planing a stock cubed TT build and I've concluded that a Stage V T3/T4 Hybrid with .63 A/R would do the trick. My understanding is the the Stage 5 Turbine, which is 62mm, will allow me to make adequate power with a stock LS1 as well as all me to turn up the boost once I forge my bottom end. The 0.63 A/R will spool early, but the only thing I'm concerned about is if they will consistently produce boost up to 7k. So please, share you experiences with me.
__________________
Information Technology Super Sport Suspension|T56|5.3|Twin TC66s|
Summer 2010 Build
I run a .96 a/r hotside with a 6.0 litre and I shift around 6k. I chose it because a .68 would have fallin off a little early and I still have full boost by around 3500/3600
the best thing to do would be to find out how much air those turbos can push each then find out how much air your engine will need at 7k. Forcedinductions.com has a chart that goes up to 6800 rpm and 15psi.
but with a twin turbo using to small turbos that will spool fast anyway you might want to think about a higher ar. call sponsers and ask them.
__________________ 01 Z28- Magnaflow catback, A4, 4:10's, SLP Lid, more power coming soon......
94 Integra - daily driver
New Project: 275 Fox.......Details still in the works
My twin .68 AR stage V 60-1 Garretts get full boost as early as 3500 and hold to 7200. The ability to spool sooner or later can be controlled with an EBC as well.
__________________ Final Solution Performance
^^^Built and Tuned by^^^
725Rwhp / 640Rwtq @ 17psi
Twin 60-1 Front mount Turbos
Forged 347 / Stock heads
Meth
Correct. You can change the way it spools to a degree. By changing the gate pressure ( what psi it starts to open the wastegate ) you can move the spool time. For my application, my low boost is on spring pressure ( 7# ) the factory GP set was 3#. By holding the gate closed longer ( say 4# ) I can make it reach full boost sooner. Change it to say 2# and it will reach later.
Other things to consider is what is the AF while going into boost? By maker it slightly richer ( from what Ive been told ) it will achieve boost faster. Just some more things to look at.
Meth
So an ebc can do more than just hold boost @ x psi....
hmmm... thanks for the useful info, I might be picking up the twins this weekend; Turbonetics T3/T4 Stage 5 (62mm c.w.) .81 A/R; hopefully i can start my build thread by Halloween....
__________________
Summer 2010 Build
I run a 76mm T4 with a .96AR on the hot side, stock motor.
I went with that because thats what my friend had and he made me a good deal, turns out its a pretty good choice for my motor.
__________________ 99 WS6 T/A:Single 76mm T4 Garrett setup built by me, Stock ls1 with a TR224 cam, & MadMan suspended. Best ET 10.70 @ 133.47 on 93 octane, no meth, on 275 drag radials with the M6. Now RVMB TH400 with a CK ProTree brake also built by me (With JakeShoe coaching over the phone) My DIY turbo build
on stock compression as well?? when does boost build and peak?
Yes stock compression, it starts building boost at about 1800 and hits max boost at about 4400.
lol, like you can notice a drop in boost @ wot from 4k thru 7k
Not right now, its been bleeding off 1.5 to 2 psi. I did find that the v band flange was leaking on the wastegate and a torn o-ring in the gate. Just got all that straight this morning before work and hope to give it a try soon.
Not trying to hijack the thread but will my turbo be to small? Its a forged 347 with a precision t76 .75 compressor and .96 ar hot side. I plan on running 16-18 psi will it not do that? Will it max to early?
can anyone explain those numbers in bold? i think the .96 determines how large the tubo flows or am i dead wrong? i don't know crap about what a compressor does on a turbo?
Check out the stickies and also www.forcedinductions.com for some good info. Basically the turbine AR determines how quick you spool up vs. how much top end power you are going to make. It's a delicate balancing act so you still spool well, but don't choke yourself out on top.
__________________ 2005 Pontiac GTO, FTI TH400 w/transbrake, FTI 4200 stall, ported 243's, Comp 921 springs, 243/247 .624/.624 on a 116, forged ironblock 9.25:1 370.
4200lb heifer w/ 3.46 gears and 26" tires
Quote:
Originally Posted by subarubill96
Lots of ways to skin a cat, i just prefer a chainsaw.
