Click here to visit LS1Tech
Click here to visit Performance Trucks
Click here to visit Mod Motor Tech
Click here to visit Modern Hemi
LS1Tech Wiki
LS1TECH
Go Back   LS1TECH > LS1-LS2-LS3-LS6-LS7 PERFORMANCE > Forced Induction
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into LS1Tech.com, click logo to login
Old 09-28-2009, 01:53 AM   #61
1BAD_LS1's Avatar
Trader Rating: 26
Quote:
Originally Posted by zacht View Post
digging the build man!!!! keep up the good work...
just sucks cuz im going to have to do something big just to keep up with you.....
got it together.... but the damn seal is leaking so I gotta tear it apart again!
I bet you keep up with that nitrous.
1BAD_LS1 is offline   Reply With Quote
Old 09-28-2009, 07:07 PM   #62
Trader Rating: 14
Send a message via AIM to blazin Send a message via MSN to blazin Send a message via Yahoo to blazin
That sucks i havent had any leaks on any of the ones I put together. Right stuff is the shit.
__________________
96 Z28. Stock
99 Silverado
blazin is offline   Reply With Quote
Old 09-29-2009, 12:11 AM   #63
1BAD_LS1's Avatar
Trader Rating: 26
Quote:
ya i reused the timming cover seal.... the timming cover was sitting on the bottom of a box of parts and was damaged a little!
it was my fault for not checkng it... just assumed it was ok because it only had 6000 miles on it, never even thought to check it.
__________________
Wanna be fast? Check out BMR Fabrication and Nitrous Daves Nitrous Outlet they will help you HOOK & BOOK!!!
http://www.bmrfabrication.com/
http://www.nitrousoutlet.com/
Old 09-29-2009, 12:23 AM   #64
1BAD_LS1's Avatar
Trader Rating: 26
took some pictures with the cell phone...
I went with dual catch cans from each valve cover routed to turbo filter so i can have constant vaccume on the crank case...
Drivers side catch can (hose going across fuse boxes goes to airfilter):
Alluminum cut and bend for radiator cover:
alternator bolted to Waterpump and head:
STOCK Radiator hoses cut flipped and spliced with pipe:
Merge pipe and WG:
Cold pipe (charge side) and BOV, the BOV points directly out the vent below the marker light on the drives side (should be loud):
Everything together befor i knew i had the oil leak (with only 1 catch can installed lol):
After i get the timing cover seal replaced i will drive it to work and build/install the down pipe, install 3pt subframe connectors, install LCA brackets and it'll be time for tuning!!!!
__________________
Old 09-29-2009, 02:06 PM   #65
JAX04's Avatar
Trader Rating: 2
great progress man. great progress. keep it coming, time to see some numbers. lol. im going with a 5.3 truck motor for my build. let me know how much boost she holds.
__________________
KYLE/Jax04
2004 GTO PBM A4- "speed cost money...IM POOR"
Procharger with helical option---
Quote:
Originally Posted by xXxSilveradoxXx View Post
IDK, maybe it's just me but why the hell would you want to muffle the sound of pure sex under the hood?
JAX04 is online now   Reply With Quote
Old 09-29-2009, 05:23 PM   #66
Trader Rating: 1
Quote:
Now i just need to find a GOOD pusher fan on the CHEAP!
I don't know if you still need them, but if you do start scrounging the JY for Mercedes (late 80's-early 90's) They have some big thin pushers on them, I run one on my S10, works like a champ. I think they go for about $13 each out here. You could probably stuff 2 in front of the radiator, Ive got a second one on the floor waiting for my 5.3 turbo project. Keep up the good work.
Bacon505 is offline   Reply With Quote
Old 09-29-2009, 07:25 PM   #67
Pat-Man's Avatar
Trader Rating: 3
Love it! Good luck getting everything ironed out.
__________________
2001 GMC Sierra 1500 - 5.3L Vortec
* Straight Pipes
2007 Pontiac G6 GTP - 3.6L DOHC VVT
Stock DD
1998 Camaro Z28 - 6.0L 408cid LQ9
* Forged Rotating Assembly * TTi Street Kit w/ T76 Turbo @ 4psi * 3.73 Gears * Racetronix Fuel System * LS6 Intake * Motron 60# Injectors * 2 BAR MAP (SD Tune by Brian Reckhart) Not fast ... yet
Pat-Man is offline   Reply With Quote
Old 09-29-2009, 09:14 PM   #68
1BAD_LS1's Avatar
Trader Rating: 26
Quote:
will do hoping to make 550-600hp... not sure how much boost itll take to get there but ill find out!
__________________
Old 09-29-2009, 09:14 PM   #69
1BAD_LS1's Avatar
Trader Rating: 26
Quote:
Thanks for the info ill keep an eye out for one!
__________________
Old 09-29-2009, 09:16 PM   #70
1BAD_LS1's Avatar
Trader Rating: 26
Quote:
Thanks... ya there are always little things to work out after a build like this...
__________________
Old 09-29-2009, 10:08 PM   #71
Trader Rating: 14
Looks good did you copy my alt bracket or did you add a tensioner?
__________________
96 Z28. Stock
99 Silverado
Old 09-29-2009, 10:37 PM   #72
1BAD_LS1's Avatar
Trader Rating: 26
ya i have to fight the belt on right now but will be figuring something out for a tensioner, might just keep it simple and use a slide type bracket for alt to tension the belt like others have done..... but i would like to have a stock type tensioner though.
__________________
Old 10-01-2009, 08:09 PM   #73
enigmah's Avatar
Trader Rating: 0
Send a message via MSN to enigmah Send a message via Yahoo to enigmah
Id love to do this one day but i want to keep my AC
__________________
Lid, Cutout, Flows, Pacesetter LTS
Mods 1/4: Comming Soon
No Mods 1/4: 13.30 at 106.99
124,000 miles and climbing
enigmah is offline   Reply With Quote
Old 10-01-2009, 10:42 PM   #74
RS_SS69's Avatar
Trader Rating: 23
Quote:
LOL I wanted to keep it too but oh well, I made a way for it not to have DD duty anymore.
RS_SS69 is offline   Reply With Quote
Old 10-01-2009, 11:30 PM   #75
1BAD_LS1's Avatar
Trader Rating: 26
ITS ALIVE!!!!!!!!!!! Got the darned seal leak fixed....
Took it for an EASY drive to go fill it with gas so i can drive it to work tomorrow and get the downpipe/WB02 done and start tuning!
Cant wait!! Ill keep posted! I wont have any dyno numbers for quite a while though... gotta get it tuned then come up with the cash/time to dyno it...
i am going to need some new fans also.... stockers arent gonna work i dont think.
__________________
Old 10-05-2009, 10:14 AM   #76
JAX04's Avatar
Trader Rating: 2
get any tuning done this weekend?
__________________
KYLE/Jax04
Old 10-05-2009, 03:16 PM   #77
1BAD_LS1's Avatar
Trader Rating: 26
got a little tuning done but had to work saturday and rained all sunday.
will work on it tonight and hopefully get into some boost.
Old 10-06-2009, 01:56 PM   #78
1BAD_LS1's Avatar
Trader Rating: 26
Well i planned on getting some tuning done last night but i got a flu shot at work yesterday morning... I had an alergic reaction to the damn thing! Couldn't breath or stand up! I still feel like shit this morning.
I got a present in the mail today though. I got my 16" fan (off ebay from Hot Rod USA) I was a little worried about the quality.... BUT THIS THING SUCKS/BLOWS like crazy! I dont think ill have to worry about cooling problems i bet it makes every bit of 2200 cfm it claims! It only cost $56 shipped also!
I will have a 12" puller fan on my intercooler and tranny cooler.... and a 16" pusher fan on the radiator....
If i start to feel better this afternoon i might get out and do some tuning...
__________________
Old 10-06-2009, 02:06 PM   #79
RS_SS69's Avatar
Trader Rating: 23
Good to hear man, let us know if you have any problems with cooling with that fan, could you pm me the link ive been looking for one.
Old 10-06-2009, 02:48 PM   #80
TX RED's Avatar
Trader Rating: 11
Quote:
2x on that send me a link as well
__________________
2000 A4 /LT's/3'y/NGK/MSD/LID/P&PTB/3.73/lv2 Trans/Edge 3300 stall/TSP TRQ V3/ls6 intake/
Tuned by 1320 performance
TX RED is offline   Reply With Quote
Tags
53, 53l, blanket, boost, bottom, budget, ebay, end, intake, kit, ls6, manifold, pull, silverado, stock, truck, turbo
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
LS1TECH - Archive - Top
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Advertising - Terms of Service - Privacy Policy - JOBS
