Hot pipes make no difference on the size turbo or how much boost it will actually make or hold until you get way up there in the HP like 1000 plus, as long as the flange is the same t4 or t6
__________________ Old Stock setup 326RWHP 340RWTQ Custom 74mm Front mount in Progerss
|PTE74GTS | 317's | 918's | CC 7.4 PR's | Motron 60's | Walbro | GM MLS Head Gaskets | ARP Head studs | 02 Z06 Cam | Phamspeed Hot Pipes | Tial 38mm WG | Turbosmart BOV | All AEM Gauges | HPTuners | Moser 12 Bolt 3.73 33 Spline TruTrack | ls7/ls2 clutch |
Quote:
Originally Posted by LS6427
Do as much HP as the pocket book will allow...worry about traction later.
Actually this kit that is the largest turbo you can run. If you run a larger turbo you are going to have to have the downpipe exit on the opposite side and run a small filter because of the location of the turbo.
__________________
Ebay Turbo Kit l Cam l Moser 9" l th400
This is pretty interesting..... looks like an okay kit for what you pay for it.
98Camarod what kind of numbers and track times are you putting down with your set-up? You can PM if you dont want it posted.... thanks.
__________________ Just your everyday Camaro with a fouled plug or two.
Thanks to Vengeance Racing, Speed South, Speed Inc., Byunspeed, Dave's Nitrous Outlet and last but not least Coors Brewing Co.
i just dynoed mine, with A LOT of issues, it put 505 to the wheels at 10psi, the tuner was thinking more of the 550 range once evrything was worked out. this was with my 76mm .81a/r
i just blew up the motor though when boost crept to 15psi
__________________ 1999 Pewter Camaro Z28 M6 ENGINE: 404ci forged monster, oh and with a big turbo hanging off the front! SUSPENSION/BRAKES: Custom Brembo Big Brake kit w/ Hawk pads, Edelbrock Adjustable Coilover front shocks with Eibach springs, Hotchkis STB & Rear springs, full Energy Suspension kit
ouch....I had my wife go with me after I installed my eboost2 to do some tuning. I told her to tell me if the boost went over 10lbs when I hit it. Well the damn thing went to 17lbs. I guess the only good thing is that it pulled alot of timing, IIRC it was 8*. I told her it felt weird, how high did the boost go? She says to me, "it went to 17." I got lucky with that one I suppose.
__________________
So this is not the kit that comes with the intercooler and piping for 500? Anyone used that one yet?
curiosity, which kit r u refering too? if its the same one theyre mentioning, then it doesnt come with intercooler... but if it does, plz post link or message it if u can. would like to get my hands on it
yea, i used a prototype wastegate they made (aka cheap)
i guess thats what i get for not buying a nice one.
im now doing a fully forged 408 with every stud/bolt possible ARP. should be around 750rwhp for the street. hoping to get in the 900rwhp range once i beef up the fuel system a bit.
i learned my lesson on this one. yeah camarod, its weird, i think mine spiked to around 17psi too!!!!
total carnage: 4 broken pistons, 2 bent rods, and the block cracked in 3 places. woooooooo!
