Click here to visit LS1Tech
Click here to visit Performance Trucks
Click here to visit Mod Motor Tech
Click here to visit Modern Hemi
LS1Tech Wiki
LS1TECH
Go Back   LS1TECH > LS1-LS2-LS3-LS6-LS7 PERFORMANCE > Forced Induction
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into LS1Tech.com, click logo to login
Old 09-27-2009, 11:37 AM   #1
1998 Pontiac Firebird
Spd-Kilz's Avatar
Trader Rating: 12
Send a message via AIM to Spd-Kilz Send a message via MSN to Spd-Kilz Send a message via Yahoo to Spd-Kilz
Question High Compression + Low Boost: Your Thoughts
I had never planned to play with boost, but it's becoming increasingly attractive to me. I'm getting used to the setup I have now and would like more power.
My main problem is my compression ratio is 11.5:1.
Is the only main issue with high compression + boost pre-ignition? If so, could I counteract this with 94 octane pump gas and methanol injection?
Can this be done relatively safely?
I realize there is another thread, but I'm really looking to get more insight into the issue.
I'm not looking for people to say "buy new, thicker gaskets" or "get bigger chamber heads" etc. I'd like to keep the setup I have now.
__________________
Spending money I don't have, to buy parts I don't need, to impress people I don't know.
1998 NBM Formula M6
*PHK Canada*
Idle Clip
<a href=http://i296.photobucket.com/albums/mm176/SVTBAIT/SPd-Kilz2.jpg target=_blank>http://i296.photobucket.com/albums/m.../SPd-Kilz2.jpg</a>
Spd-Kilz is offline   Reply With Quote
Old 09-27-2009, 12:59 PM   #2
383lt1impala's Avatar
Trader Rating: 27
Send a message via AIM to 383lt1impala Send a message via Yahoo to 383lt1impala
Well u can run low amount of psi with pump gas without meth. Me I plan to run 7-10 psi on c16 but im running 12.56 compression.
__________________
1995 PIMPALA SS #419
MY BUILT LS1/TH400 SWAP THREAD!
383lt1impala is online now   Reply With Quote
Old 09-27-2009, 02:54 PM   #3
DevonsZ's Avatar
Trader Rating: 16
I ran 11.3cr with 10-11lbs of boost on 91oct and meth.
__________________
White 2001 Z-28 A4: Ran 10.7@132mph @ 3960lbs then sold it. Pics:http://community.webshots.com/album/520267881asjLuf
DevonsZ is offline   Reply With Quote
Old 09-27-2009, 03:12 PM   #4
fknsmshn's Avatar
Trader Rating: 0
My favorite thing about high comp and low boost is the spool times. Lag is pretty much non existant.
From what I know, tuning is a bitch so dont slouch on that. Just watch for detonation and if you do run meth, keep an eye on the bottle.
__________________
Locate Approzimatley As Shown
'98 Hard Top A4 Z28
fknsmshn is offline   Reply With Quote
Old 09-27-2009, 03:29 PM   #5
BoostnTBSS's Avatar
Trader Rating: 0
Send a message via AIM to BoostnTBSS
I run 10.6-1 with 15psi with E85 and no I/C and 25*'s timing. and it spools great 348 ci with Gt42 w/ 1.15 ex i see 7 psi as soon as i touch the throttle. like 1/8 throttle... it is instant..
__________________
E85 powered
2000 S10 xtreme - pro street
87 StarQuest - forged 348,LS1X Heads,S88 turbo,TH400,8.8 Rear,2500LBS Should be a fun street Car with 800ftlbs @3300 @10.5 PSI
BoostnTBSS is online now   Reply With Quote
Old 09-27-2009, 04:35 PM   #6
Got Me SOM's Avatar
Trader Rating: 2
Send a message via AIM to Got Me SOM Send a message via MSN to Got Me SOM Send a message via Yahoo to Got Me SOM
You may have to run higher than 94 to be safe, more like 100 octane. It'll want to detonate, but the cool thing is it'll be responsive. With 94 you'll be able to run about 4 psi depending on what blower/turbo you use. kinda defeats the purpose if you ask me.
when i had 10:1 compression with 9-10 lbs on my vortech my car was fun.
__________________
Gone but not forgotten 2002 SOM SUPERCHARGED SS A4
www.fquick.com/GotMeSOM Add me!!!
Stock parts For Sale!!
http://ls1tech.com/forums/showthread.php?t=932452
Got Me SOM is offline   Reply With Quote
Old 09-27-2009, 06:12 PM   #7
Spd-Kilz's Avatar
Trader Rating: 12
Interesting. I'd really like to use pump gas and stay away from using race fuel since the car is a street car, and that can get rather expensive. I really don't have much of an issue running about 4psi...that would put me around 570rwhp which imho is not bad at all. As a general rule of thumb, how much are the stock internals good for? I really don't want to exceed that anyways. I don't want to play with fire. What supercharger would be good for low boost levels? A P1SC?
__________________
1998 NBM Formula M6
*PHK Canada*
Idle Clip
Old 09-27-2009, 06:32 PM   #8
Got Me SOM's Avatar
Trader Rating: 2
I would use the SEARCH feature as this has been asked many times before. It's almost impossible to run only 4 psi, you have to run a super large pulley unless you go custom. Most kits start off at 6-7 psi.
Stock bottom ends are limited by the cast pistons and the ringlands. they go when they go, they don't fail at a certain amount of hp.
Your compression is really pushing it and asking for detonation. Make sure you have a credit card when not if the bottom end fails. Also invest in a good fuel system.
There is no such thing as cutting corners or cheaping out when you go forced induction so either do it right or don't do it at all.
__________________
Old 09-27-2009, 06:50 PM   #9
black_z's Avatar
Trader Rating: 4
Send a message via AIM to black_z Send a message via MSN to black_z
Is E85 an option? If not, I would definitely mix race gas. Tuning and good fuel will hold it together.
__________________
Quote:
Originally Posted by flyin red TA
But most importantly, could you still see yourself peeing in her butt in 40 years?
black_z is offline   Reply With Quote
Old 09-27-2009, 09:09 PM   #10
Zombie's Avatar
Trader Rating: 2
Send a message via AIM to Zombie
without higher octane it's not the greatest of ideas. On 100 oct or e85 it's possible (especially e85) but it's far from ideal and limits you.
__________________
SX80 butt mounted, Rossler TH400, PTC 3600 stall, forged 8.7:1 6.0L, Moser 9", 2.75 Gears.
SX80 Best pass 10.D0HD0H1 @ 135.2[1.49 60'] 15psi
The Heretic of the LS1Tech.com FI section
Zombie is offline   Reply With Quote
Old 09-27-2009, 10:29 PM   #11
Spd-Kilz's Avatar
Trader Rating: 12
What all is involved with getting the car to run E85?
__________________
1998 NBM Formula M6
*PHK Canada*
Idle Clip
Old 09-28-2009, 02:21 AM   #12
1999 Pontiac Trans Am
DVS99TRANS's Avatar
Trader Rating: 7
I am in the same boat as you Spd-Kilz, i have been researching which is the best route. I just had my 408 built and am running a static 11-1cr. Should have had it built 9.5-1 I'm thinking about getting a new set of heads, and dropping the cr as low as I can without having to swap pistons. Even if that is the case I would only be able to run around 7-8psi max on pump gas if I'm lucky.
Stock internals: you shouldn't really go above 8psi is the norm. Hell you'll still net over 500whp
__________________
1999 BLACK TA M6-408/Built t56/FAST/ARH/BMR/S60/Etc.. 495/471 SAE#'s 508/479 uncorrected
Race Proven Motorsports Motor- Thanks Fran
2001 RED WS6 M6 #6101 -309whp/320wtq
2008 Black Trailblazer SS-RWD/daily driver
DVS99TRANS is offline   Reply With Quote
Old 09-28-2009, 07:51 AM   #13
Spd-Kilz's Avatar
Trader Rating: 12
At least i'm not the only one. I really don't want to go through the hassle of taking off the heads. 8 pounds would be ridiculous on a 408. I figure i'll be at ~600rwhp with 5 pounds. Hell, i should be over 500 with 2psi.
__________________
1998 NBM Formula M6
*PHK Canada*
Idle Clip
Old 09-28-2009, 08:47 AM   #14
SSdreamz's Avatar
Trader Rating: 2
Send a message via AIM to SSdreamz
same boat as you...been kicking the idea around about the higher compression and boost... im at 11.7:1 but ive also have a forged bottem end.... ill be watching this thread to see where it goes
__________________
1999 SS#4156
Everything just bolts-on really...
SSdreamz is offline   Reply With Quote
Old 09-28-2009, 12:34 PM   #15
Trader Rating: 0
im kinda new still to the ls crowd, but im pretty sure u can get away with up to 10 psi at 11-11.5:1 ratio. i say this because back in the civic crowd (where i once resided till opening eyes to v8) many guys would run that on their all aluminum, thin-walled motors with as big as a gt35 turbo. so long as it is tuned properly to ~11:1 afr, u should be set. i only wish i had the resources so i can do my turbo build to help prove this... gl tho and keep us informed.
cfon159 is offline   Reply With Quote
Old 09-28-2009, 01:51 PM   #16
Zombie's Avatar
Trader Rating: 2
Quote:
The smaller bore of those motors are less prone to detonation. Larger bore = more likely to detonate.
__________________
Old 09-29-2009, 06:21 AM   #17
DVS99TRANS's Avatar
Trader Rating: 7
^^^exactly, my overall goal with the car is to run it on pump gas period. Just like Spd-Kilz is going for. The other good thing to do I think would be to swap up to a custom FI cam that might help out a higher compression motor on FI which will be a must IMHO. Meth is nice but am going to steer clear of it just in case. I am also running PRC 2.5 5.3 heads undecked also, which aren't the best and are going to have to be replaced. In that area, I am looking at getting the biggest combustion chambers possible getting me back into the 10-1cr range again which is easily possible. That and running a T76 @ 8-10psi-ish would become a possibility without detonating. You can always run race gas if you want to turn it up at the track or limited amounts of time. That is the direction I am thinking...
A buddy of mine that is on here is thinking the same thing. He has a high compression 408, and we have been talking about it quite a bit. Hopefully he sees this and adds to the thread too.
__________________
Tags
10, 101, 111, 15, boost, boosting, compression, high, lbs, low, max, meth, motor, psi, safe
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
LS1TECH - Archive - Top
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Advertising - Terms of Service - Privacy Policy - JOBS
