Click here to visit LS1Tech
Click here to visit Performance Trucks
Click here to visit Mod Motor Tech
Click here to visit Modern Hemi
LS1Tech Wiki
LS1TECH
Go Back   LS1TECH > LS1-LS2-LS3-LS6-LS7 PERFORMANCE > Forced Induction
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into LS1Tech.com, click logo to login
Old 11-03-2009, 07:48 AM   #101
Trader Rating: 13
Quote:
Originally Posted by PaulC View Post
Here's a link to a 550RWHP 440LS7 that ran 196mph naturally aspirated.
http://www.v8rx7forum.com/scca-autoc...big-dawgs.html
I think he'll do okay with over twice the power.
I was down there and watched a couple of his runs. Pretty impressive for NA. I'm planning on using a bunch of aero tricks I learned while down at the TX Mile this year
__________________
RX7 FD, Sheetmetal Widebody, CandyPearl Orange Paint, Fiberglass hood, doors, trunk, wing, bumper, ported Warhawk headed forged LS7 427, Spec Twin Carbon, Tranzilla T56, Procharger F2, meth inj, Cobra 8.8 rear conversion w/TrueTrac, Makaveli 3pc Forged wheels 19f/20r, Nitto INVO 345/25/20r 305/30/19f
93formto98T/A is online now   Reply With Quote
Old 11-03-2009, 07:49 AM   #102
Trader Rating: 13
Quote:
Originally Posted by Beaflag VonRathburg View Post
Pictures?
I also hear you on the nickle and diming thing. That's why I changed my Formula's build to get it running. I was getting hit for a couple hundred on tons of things and it was just running me out of money and quickly.
I'm waiting for parts to arrive. I'll take pics this weekend when I'm installing everything.
__________________
Old 11-06-2009, 11:33 PM   #103
Trader Rating: 13
A2W is mounted. Got the IC back from the fab shop where they welded on the Procharger race valve. All the fittings and lines arrived today. Here are a few progress shots. Should get done running and fitting most the lines tomorrow. Besides a couple more fittings and a few sensors and relays, the car is ready to crank.
rx7-fd-sheetmetal-widebody-vaspeed-ls7-f2-cog-txmile-build-fuelsystem-001.jpg   rx7-fd-sheetmetal-widebody-vaspeed-ls7-f2-cog-txmile-build-fuelsystem-003.jpg   rx7-fd-sheetmetal-widebody-vaspeed-ls7-f2-cog-txmile-build-fuelsystem-004.jpg   rx7-fd-sheetmetal-widebody-vaspeed-ls7-f2-cog-txmile-build-fuelsystem-009.jpg   rx7-fd-sheetmetal-widebody-vaspeed-ls7-f2-cog-txmile-build-fuelsystem-014.jpg
__________________
Old 11-07-2009, 10:31 AM   #104
8 sec potential, 12 sec slip
2002 Pontiac Firebird
ChevyChad's Avatar
Trader Rating: 45
Looks good man.. One suggestion tho- it looks like you used the teflon tape on those fuel fittings. You would be better off using the liquid teflon pipe sealant. Any hardware store will have the liquid stuff and its way better for any sort of liquid. The tape is more for air fittings..
__________________
2002 Trans Am M6, forged 9.2:1 370, F1 procharger @ 12psi, comp SC2 cam, mild ported AFR 225 heads, MAC midlengths, Borla, full suspension, 3.73 12-bolt, Mecham Hood, 19x10 Polished CCW 505A's 700ish RWHP/ 600ish RWTQ (still ironing it out)
ChevyChad is offline   Reply With Quote
Old 11-07-2009, 10:53 AM   #105
Trader Rating: 13
Quote:
The shop I purchased all the lines and fittings from said to use the tape but keep it off the first 2 threads. I'll look into the liquid stuff.
__________________
Old 11-07-2009, 11:33 AM   #106
ChevyChad's Avatar
Trader Rating: 45
Yea, I'd look into it at the very least. From my understanding, all NPT threads used for any type of liquid should be coated with the liquid teflon pipe sealer. Also, AN fittings you shouldnt be using any type of thread sealer at all (tape or liquid). Its worth looking into and researching, but this is the way I've done it and it has worked out great for me.
__________________
Old 11-07-2009, 12:08 PM   #107
Haans249's Avatar
Trader Rating: 24
Send a message via AIM to Haans249
I hope you don't plan on running that honeycomb filter. It will definitely choke down some power, you would be better off running the largest KN you can on the front of that monster!
Chad is right, liquid thread sealant all the way when it comes to fuel items. Better safe than sorry at 210 mph.
__________________
Haans249 is offline   Reply With Quote
Old 11-07-2009, 12:46 PM   #108
Trader Rating: 1
that car is insane! good stuff man!
__________________
Please, call me ♠Cody™
http://i27.tinypic.com/2hmhjsy.jpg
LS1Tuner_06 is offline   Reply With Quote
Old 11-07-2009, 03:20 PM   #109
Trader Rating: 9
I find red locktite works well but I wouldn't do it on a car that I would be routinely taking lines on and off...
__________________
2000 Blk/Blk Firehawk/TA #173
Lythropus is offline   Reply With Quote
Old 11-07-2009, 03:22 PM   #110
Trader Rating: 13
Quote:
That was a filter I had laying around that happend to have a 4.5" inlet so I put it on for the time being. I'm planning on running a 90 elbow into a large filter but won't know where I have room till the radiator and heat exchangers are mounted.
__________________
Old 11-07-2009, 06:45 PM   #111
Trader Rating: 13
Here's the fuel system about 1/2 way there. Some of the fittings and angles didn't work out as planned so I have some unused fitting I'll bring back to the shop on Mon to get the right ones. I got the new optima battery relocated to the passenger rear storage bin with the Hinson kit and ran the premade cables. I put the fittings on the water tank, all 1" stuff, now just need to get more hose and run it. Also need to mount the rad fans.
Fuel system: -10 feeds to pump with pre-filters, -8 out of pump into 8/8/12 Y block with check valve on the secondary pump to prevent backflow when not in use. -12 all the way to the bay with -12 filter then 8/8/12 Y block, 90s, -8s and 90s into the back of the rails, front of the rails Ts to the Magnafuel boost regulator with -8 return.
rx7-fd-sheetmetal-widebody-vaspeed-ls7-f2-cog-txmile-build-fuelsystem-008.jpg   rx7-fd-sheetmetal-widebody-vaspeed-ls7-f2-cog-txmile-build-fuelsystem-009.jpg   rx7-fd-sheetmetal-widebody-vaspeed-ls7-f2-cog-txmile-build-fuelsystem-006.jpg   rx7-fd-sheetmetal-widebody-vaspeed-ls7-f2-cog-txmile-build-fuelsystem-007.jpg   rx7-fd-sheetmetal-widebody-vaspeed-ls7-f2-cog-txmile-build-fuelsystem-003.jpg
rx7-fd-sheetmetal-widebody-vaspeed-ls7-f2-cog-txmile-build-fuelsystem-004.jpg   rx7-fd-sheetmetal-widebody-vaspeed-ls7-f2-cog-txmile-build-fuelsystem-005.jpg   rx7-fd-sheetmetal-widebody-vaspeed-ls7-f2-cog-txmile-build-fuelsystem-002.jpg   rx7-fd-sheetmetal-widebody-vaspeed-ls7-f2-cog-txmile-build-fuelsystem-001.jpg   rx7-fd-sheetmetal-widebody-vaspeed-ls7-f2-cog-txmile-build-fuelsystem-012.jpg
__________________
Old 11-09-2009, 08:34 AM   #112
Trader Rating: 0
any reason you are using a A2A core fort he rad as opposed to a proper rad core??? Are there any differences??
Cheers
Chris.
chuntington101 is offline   Reply With Quote
Old 11-09-2009, 07:48 PM   #113
Trader Rating: 13
Quote:
Cheers
Chris.
Supposedly the A2A cores are slightly less efficient than a dedicated water core but due to my size contraints the A2A was the only core that would work. Since my A2W IC is where the radiator normally goes, I made the A2A IC a radiator- should work fine. It's a bit of a trick...when you see the "small" A2A on the front you won't be thinking BIG power...
__________________
Old 11-09-2009, 08:41 PM   #114
kikass_z28's Avatar
Trader Rating: 0
Quote:
yeah...........until you start it
kikass_z28 is offline   Reply With Quote
Old 11-09-2009, 09:45 PM   #115
Trader Rating: 13
A bit more progress today. Got a few fittings today but not all. Still need one for the front end and a few for the rear. Fueling is 90% there now. All lines are full teflon with braided sheath except for the 12AN because I couldn't find anyone that makes it...Maybe in the future.
rx7-fd-sheetmetal-widebody-vaspeed-ls7-f2-cog-txmile-build-fuelsystem-003.jpg   rx7-fd-sheetmetal-widebody-vaspeed-ls7-f2-cog-txmile-build-fuelsystem-013.jpg
__________________
Old 11-10-2009, 08:07 AM   #116
Trader Rating: 0
It will be intresting to see how the core cooles the water. have you seen the rear mounted rad setups in RX7s?? Very intresting and they work a treat. Plus you could have 2 small and one LARGE heat exchange for the SC!
Chris.
Old 11-14-2009, 11:17 AM   #117
Trader Rating: 13
Update: I went back through the fuel system and removed all the teflon tape and fixed a couple lines that weren't looking right. I got the rest of the fittings in and the fuel system is now complete. I ordered the rest of the sensors, hoses, and relays I need to bring her to life. I don't know if the car will start without a MAF (I'm going speed density) but imagine it will at least turn over (the ecu has cags! vats! and base tune loaded)
The plan is to turn the fuel pumps on and test the fuel system for leaks, test the A2W system for leaks, re-test the radiator cooling system for leaks, and get the car turning over. I'll tow it to the shop where they'll do a custom SS exhaust dual 3.5" that Y into a 5" at the muffler. Then they'll strap it down and tune it in on the dyno. If all goes well I'll bring it to the shop before thanksgiving and have it back finished before christmas.
__________________
Old 11-15-2009, 01:26 AM   #118
Trader Rating: 0
You may need to use 2 procharger race valve's if you going to drive it in the street. I had to use 3 race valves to keep my engine temps down due to drag on the blower ( lots of cfm, 2700 )
good luck on tx mile I will see you there in march
topgun1000 is offline   Reply With Quote
Old 11-17-2009, 05:55 PM   #119
Trader Rating: 4
Send a message via AIM to theantirotor
Good.
It should run with the MAF unplugged. It will not run though if the MAF is plugged in and not in the air stream. (at least this is what I have found)
theantirotor is offline   Reply With Quote
Old 11-17-2009, 08:31 PM   #120
Trader Rating: 13
Quote:
Sounds good!
Update: I got the rx7 oil pressure sender hooked up after many trips to home depot for adapter fittings.. Had the break the plastic piece off the ls1 oil pressure sender, drill out the threaded metal part and tap it for 1/8npt, buy a 2" threaded 1/8 pipe, flex the ABS lines up a bit, and crank the assembly into the back of the valley cover where there's NO room. I've got the radiator mocked up and have found some radiator hoses that will work with the setup with minimal modification. I found a good place to put a 2" hole saw in the firewall to run both the 1" hoses from the A2W tank up to the A2W IC and back. Put oil in the SC, filled the PS fluid, and picked up misc bolts and hose clamps. I'm waiting on a couple sensors to arrive then I can hook them up, bolt in the starter and wire it in, wire the fuel pumps and water pump and see if she'll turn over or better yet come to life. I finally see the light at the end...
__________________
Tags
build, builds, dealers, difference, forums, gtm, ls1, ls7, nitto, orange, procharger, rx7, supercar, tech, toronto, warhawk, widebody
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
LS1TECH - Archive - Top
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Advertising - Terms of Service - Privacy Policy - JOBS
