New build/combo..F1/370 Dyno Vids/results MORE BOOST!
Well I'm currently in the middle of a new combo. New engine specs are:
LQ4 Block bored 4.030
Stock crank
Callies compstar rods 6.125
Weisco -12cc dished pistons with ductile iron top and napeir 2nd
Arp main and head studs
LS7 lifters
Patriot stage 3 LS6 heads with dual extreme springs (flow 320ish CFM)
Comp cam 235int 243exh .620int .623exh on a 115 LSA
LS6 intake with a 85mm throttle body
Motron 60lb hr injectors
Twin walbro 255's on stock lines for now
I'll take pics of the new motor and parts tomorrow. Now out with the old. Old motor is the stock bottom end with 317 heads and a ZO6 cam. The cyl walls even still have cross hatching...thats with 110K miles...over 65K were boosted. Lifters had some markings on them but nothing that could be felt. Still have to roll the pushrods to make sure their good. I'll finish pulling it out next weekend. All in all it was a good time lol...no time constraints and no rush for once.
Stock crank
LS7 lifters
I need to figure out an exhaust setup as well. I need something that'll flow decently yet can be pretty quiet. I'm open to the use of cutouts as well. I also want to get the aster bracket to help with belt slip. LS1RedZ did you ever dyno your new setup? What did you change? I'll try to take pics of the new motor in a little bit. 730rwhp or bust lol
Can you pm or post the graph? What dyno? The headders that are currently on the car are pacesetters (dont know size...probably 1-3/4ths) but i have ARH 2" race headders. Your setup gives me hope. Meth?. I'm worried about the fuel setup though lol. I want to get as far as I can before I spend a lot more money lol. Our temps here are a hell of a lot better then that.
