Nice BUILD...have a quick question for you guys. Does your Tranny run via micro squirt or mega squirt. Also you do the MS setup to run your tranny yourself or did you get it from DYIAUTOTUNE.COM ready to run your 4L80E. I'm just trying to run the same tranny and I'm looking for different ideas. I already have MSII to run the fuel and spark.... now I want to see if I could run the Tranny with what I have...
First let me say nice build! Now for the bad news. With the turbos at that angle your gona have issues with oil filling up the ex side. Bearing housings will fill with oil then puke past the piston ring on turbine shaft. Turbos need to be mounted level. Just my 2 cents.
we have been running it all year like this. 6 or so trips to the local track driving it there and then making 8 or so runs each time. then a 1300mile road trip hitting the track 6 times and making about 40 runs. then there is the dyno time.
no issues yet.
i have seen more and more turbos mounted at angles lately.
__________________ nova is almost done. thanks C&S, DIYAUTOTUNE, Circle D, intakeelbows.com, Drive Train Specialists
I forgot to ask you gus something...I got a tranny80E the guy that I got it from he said that the tranny was just rebuild by GM an he said that the tranny has a warranty of 10kmiles...You guys think I should put aTransgo kit or leave it alone this is going in a LQ4 with Twins 70mm........
i would do the shift kit, we did. i am not much of a tranny expert so maybe ask some tranny guys.
Yes do the shift kit. You will burn up 3rd over 500hp otherwise.
with just a shift kit i ran for a long time in my blue truck at around 600rwhp. the wagon is at 600rwhp on a mustang dyno and doing well with just a shift kit.
wagon has a vacuum modulator for line pressure too but i dont think this is needed as long as things are programed right.
Exactly. A TG -2 kit dual feeds 3rd gear, otherwise the directs burn up.
