Well...there are many people out there on stock CORVETTE fuel pumps that put down some serious power. They are actually pretty good for a stock fuel pump from what I've seen, unlike the ones that came in the F-body.
on stock pump (z06) im at 612rwhp and no meth with some more still go once i open restrictor plate some on inlet of s/c
Lol, popcorn and jar of marbles are two completely different sounds
Sorry for the confusion, same sound different terminology
Quote:
Originally Posted by slothy
why not take it to dr phil (roadrebel) hes in Michigan and deff knows his shiat
Never heard of the guy for one, and the oppurtunity I have with Ron at Vengeance I can guarantee is better then what dr phil would do for me.
What's the difference between an ls1 and an ls6 fuel pump if anything ??
I mentioned ealier that my fuel pressure is dropping significantly under full load ( wot ) so the pump is tired/going bad or something. Anyways she does drive well as long as I keep my foot out of it and shift very early. Only issues are some surging and stalling. Also when the a/c is turned on the idle jumps to 3000 rpms. Not cool. Just a few examples of incomplete / bad tuning.
__________________ 2000 FRC LS2 402 - 541 rwhp 505 rwtq Tuned by Vengeance Racing
TFS 215's (59cc) Custom Cam, 1 7/8 ARH, Ported FAST 92, UD Pully, EWP
RPS Street Twin Lite, and Pfadt Coil overs, Sways, bushings kit, RPM Stg III
For all your Performance needs:Vengeance Racing678 513 7105 http://www.ls1tech.com/forums/dynamo...s-results.html
Thanks for the link. Quite an impressive build. However he is using an ls6 pump not an ls1 pump (if it matters) , a KB bap, and 60# inj. If he was using a stock fuel pump and no bap, and only 42's I'd call bs, but the BAP is definately helping him out. Just curious how long a stock fuel pump is going to run WOT when the voltage hits 17.5 ??
Doug, do yourself a favor and start to learn about what exactly is going on with your car before you start paying more people, states away, to fix it. You'll feel so much better and will be reassured of what's going on. If not, you have no choice but to write the checks and trust who ever is working on your car.
Get a programmer (hptuners or efi live), get a wideband O2 sensor, and start to data log what exactly is going on.
The days of me paying someone else to diagnose and fix my car are over. So LG screwed you this time, who was it before LG? I hope it's not VR after they do this build.
Knowledge is power, and when you put up all of these posts, it only hurts your knowledge base with everyone speculating on what's wrong with your setup. If you were able to data log your car, you could see what cycle duty your injectors are at, and what AFR you're running and not be worried about the sounds.
Please don't take this as a bash, but more as a helping hand. Do you know what your AFR is? How about your injector cycle duty? How about how much timing your seeing at WOT? Those are all critical peices to your puzzle that you are relying on others to tell you. Who's to say they will be honest. Maybe they'll tell you that you need a new fuel pump and injectors and fuel lines when you really don't, but unfortunately, you have no idea.
i think you should take a ride to speed inc and let them dyno/scan the car and tell you what is actually going on, arent they near you? Im not saying to switch to them or anyone else but just a local shop to verify or set you straight on the issue at hand.
Going to vengeance it sounds like you are changing the set up drastically which will compare nothing at all
__________________ Edelbrock Victor Jr Heads,Edelbrock Race Headers,Edelbrock Y Pipe,Magnaflow, full BMR suspension, 9 MOSER, etc. etc GM High Tech Edelbrock LsX Head Install http://gmhightechperformance.com/tec..._installation/
Data was logged, fuel pressure drops quite a bit above 3800 rpms when throttle is open 100%. If you hold the throttle at an angle of just less then 1/2 the rpms will build safely without any strange noises that I have eluded too previously. Please don't take this as a smart ass response. Just make sure you read the posts before you tell me to do things that I've already done. My information will be checked and re verified once I go to Vengeance. As far as self tuning, not really interested. On the cost side, the sale fo my parts and the costs of the new parts were very "doable". More power for a small investment. BTW did you miss the part where Ron posted that he is giving me free street tuning, and free wot tuning on the dyno for the effort of coming to the shop from Michigan? Quite a nice gesture on his part.... Thanks again but all those bases had already been covered. Thats why I know its safe to drive on the bottom 1/2 of the tach. I shift at 3500 rpms now and keep in mind that its only temporary. Just glad its not hot yet, or I couldn't drive it at all. A/C on ='s 3000 rpm idle !!!
Is Speed INC going to do all the diagnosis that I've already done for FREE ? Please read before you post.
On the Vengeance swaps. The car will be baselined first and then individual swaps will be made so it will be a perfect real world a-b comparison. What are you smoking? Same day, same car, same dyno, what more could you ask for ??
To repeat myself, the car has been datalogged as far as Inj DC, fuel pressure etc. I am not going into anymore details. They will be released in a few weeks.
It seems there are lots of opinions in this thread with very little actual facts... Let me see if I can even things up a bit.
* As Doug said above, the diagnosis has been made.. Fuel pressure is dropping off above 3800rpm. This has been verified by a fuel pressure gauge off the rail and a GM Tech II Scan Tool. Doug and I have PMd quite a bit since he sent his car to LG and purchased our ported FAST manifold. Doug has had questions from time to time that he either didnt ask LG or they simply didnt answer. I have always tried to be helpful as anyone can see Doug is a true enthusiast and he loves his car and this forum... Doug described the issues he was having and I suggested he take his car to a local shop or a GM dealer and run a few diagnostics, which he did......
* A stock C5 pump in a 99 Corvette is NOT the same pump you will find in an 01 and up C5 Z06...Its obvious Doug is having fuel pressure issues at his current power levels. That being said, I have never seen or worked on this car. It all could be related to a simple clogged fuel filter and the car could have been perfect when it left LG.. I dont know yet. I do know we do not build 600HP combos on stock fuel pumps at Vengeance Im a bit surprised LG didnt want to atleast throw a Walbro 255 in the tank for insurance since Doug is so far away. Im not questioning their build Im just a bit surprised.
*I explained this before, but Ill do it again. When Doug aproached Vengeance about swapping heads on his combo I gave him a full quote and told him I would do the tuning for free. I did this because having paid LG for a complete tune I figured the car would be pretty close already and there wouldnt be alot of tuning required. I did not feel it was fair to charge him another 600.00 to make some minor tweaks if he was already happy with the way LG tuned the combo.
* As far as "useless comparisons" we have quite a week planned for Dougs combo when he comes in with quite a few A/B changes including:
Baseline customer vehicle upon delivery
Installation of Racetronix fuel pump/harness
Back on dyno/street for comparison of data logs
Remove LG 1 3/4 longtubes and install ARH 1 7/8 Longtubes.
Back to the dyno for A/B comparison
Remove AFR 205cc Cylinder Heads. Install TrickFlow 215cc Cylinder Heads
Remove G6X3 camshaft
Install Vengeance custom camshaft
Back to dyno for A/B comparison
Complete Vengeance Tuning
This is ALOT more work than it needs to be, BUT we want to make the comparisons useful/valid/and most importantly imformative!!!! Doing things step by step should make for some useful information.
* In regard to tuning, FWIW, Doug will be driving his car while Mike is in the passenger comparment logging/tuning. Not only can Doug look at the logs/changes being made but he will also get a complete spreadsheet with the majority of the changes made in his PCM. We do not "lie" to our customers nor do we sell them stuff they dont need. We didnt build our reputation off of antics like that and we dont intend on changing.
I gotta get back to work.. I hope I cleared the air on atleast a few things. Remember, not every enthusiast likes to turn his own wrenches.. If he did there would be no speed shops
Doug, I read every single post, but didn't see you post any data at all. So how much is the pressure dropping? What cycle duty are your injectors at? How much timing is in the car when you start to hear the popping sound/crackling sounds?
Fact is, you're still relying on everyone else to figure out what's wrong with you car.
It certainly sounds like Ron is going to help you out and take care of the issues. I've had nothing but limited positive interactions with Ron and am not bashing him or you at all. Just trying to help you help yourself, but I guess you're not interested.
EDIT: Ron I wasn't bashing you or Doug. I actually feel bad for Doug or any enthusist who gets treated like this. It's the reason why I try to be as informed as possible prior to any discussions so that I'm an educated consumer with as much data as possible. I guess that's just the scientist in me.
Best of luck Doug. Hopefully you'll be enjoying your car, more than half throttle and more than 3800 rpms.
Really looking forward to your adventures with Vengeance Doug! Too bad I couldn't see the car before I moved down to TX! I wish the best of luck to you.
Reading what you posted again, maybe it's running way way to rich when you go above 1/2 throttle an go into PE. Maybe that's why it sounds like popping/crackling as well, and it would also explain why your fuel pressure drops as well.
Just thinking through this and theorizing, that's all.
Ok bro (ALCHEMIST) Sorry I snapped at you. I have tons of data but don't feel it necessary to post it all. I have all the answers to my problems and they will be presented after I am done at Vengeance.
RON ! Holy shit do you have a great ability to communicate in print. I unfortunately don't. thanks for stepping up and clearing a few issues.
Specifics will be shared after its all said and done. Please be patient.
knowlege is power, for sure. What are you doing with the afrs, Doug??
__________________ 98 T/A M6 11.23@124 stock motor on n20,new 402, fast90/90 full weight 12 bolt 4.11, efi-live (thanks to DRKPHX) 619/658 150 shot Under the knife, "Mamofied AFR 225s, custom cam, #s and track times in the spring. Wifes new ride 05 GTO m6, torrid red, kooks muffler deletes, engine stock as a rock, for now.
