Click here to visit LS1Tech
Click here to visit Performance Trucks
Click here to visit Mod Motor Tech
Click here to visit Modern Hemi
LS1Tech Wiki
LS1TECH
Go Back   LS1TECH > LS1-LS2-LS3-LS6-LS7 PERFORMANCE > Fueling & Injection
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into LS1Tech.com, click logo to login
Old 07-02-2009, 05:07 PM   #1
Trader Rating: 1
Default as if u turned the key off?
once in a blue moon my car will experience a cycle after start up and driving along as if u turn key off? always starts back up and may not do it again for months. well been spraying the car for about a year now and decided to step up tune so went bigger shot and changed plugs to a colder version ngk8 form a tr6 style. ever since then i experience this same effect on the spray comes on for a brief moment and then kills the car. thought it was wiring but have been over it as well as new nitrous sol and tested them several times! went out a moment ago and car did the die on motor like u turned key off, so started back up and went on to try the spray with new nitrous sol. same effect died. you can purge thru the motor at 3000 rpm and does fine, but when open wot car shuts dwn again. well this time i shut spray off and tried to wot on motor and the car died w/out spray on this time.. not sure if someone has seen something as silly as this and may post some ideas up..of how or what may be the culprit.also ses came on and threw a b1000 code ecu malfuntion(restraints) this is new never did this till the dieing issues any relation?
__________________
370 LQ9 turbo stang build in the works!!
van383 is offline   Reply With Quote
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
LS1TECH - Archive - Top
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Advertising - Terms of Service - Privacy Policy - JOBS
