Yep, during a burnout at the track last week only one of my tires spun while the other was completely still. A local gear shop told me that it sounded like my "locker" was going out. I dont kno alot about rearends and I dont wanna spend alot of money but if this is the case what are some of my options?
being that its a 98 it should the Auburn posi unit in it. its a clutch type that i heard can be rebuilt. now 99 and up got the Torsen and it has worm gears so when it breaks it just breaks. i say look for a replacement Auburn posi or see if you can find someone local who can put new clutch packs in it.
__________________ 01 SS Rally Red A4 #4987
Whats your future plans for the car? If you have plans for much power don't wast $$ into a 10 bolt, less maybe its an automatic, but even then DO YOUR RESEARCH. But yeah, your Auburn posi unit is worn and needs replaced or rebuilt!
__________________ 2000 Camaro SS 6-speed, MS3 cam, PRC 5.3 stage 2.5 heads, OBX headers, Typhoon intake, 85mm TB, DLove tuned in SD, Magnaflow catback w/3.5" cut-out, 4.10's, Centerforce DFX clutch, 441Rwhp 385RWTQ, on the bottle. 9" coming soon.
Try changing the oil and friction additive. Mine does this at the end of every season and when I bring it out in the spring I change the oil and it is fine for a while.
__________________ 1998 Camaro Z28, 5177 kit, Spec 3+clutch, k&n, Wings West kit, TT II's, suncoast creations SS hood.
PRC stage 2.5 heads, 237/242 MS3 cam, 90/90 NW TB,Hooker headers, MagnaFlow catback, LS6 oil pump, forged pistons, ARP rod bolts. UD pulley, slp subframe connectors, UMI adj panhard, UMI adj LCA's.
421rwhp, 383rwtq N/A, With out 90/90 setup. New number to come this spring. With 90/90 and 200shot.
welcome to the 10 bolt woes club! my car is an 02 and it does the same shit (stock 10 bolt). the only way i could keep the posi locked was to start in 1st, and bump it to 2nd while still in the water box, spin it to like 5 K and roll out. my buddy's 00 M6 car had the same issue. 2nd gear burnout kept it locked as well. Then he launched it at 3500 with a dump and MT's. Toasted the rear and broke the driveshaft all at once. Needless to say, we're going to buy two 9" rears and be done with this shit.
