Click here to visit LS1Tech
Click here to visit Performance Trucks
Click here to visit Mod Motor Tech
Click here to visit Modern Hemi
LS1Tech Wiki
LS1TECH
Go Back   LS1TECH > CHASSIS, SUSPENSION, APPEARANCE > Gears & Axles
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into LS1Tech.com, click logo to login
Old 07-06-2009, 11:48 PM   #21
99bluefirebird's Avatar
Trader Rating: 2
Midwest fabbed 9" will be $3300 or so with a 4.30 gear ratio, chromoly driveshaft, iron center section, detroit trutrac, and it includes a chromoly adjustable torque arm.
Strange s60 will be $2300+$300 driveshaft+$550 chromoly adj torque arm with cross brace+$150 powdercoat+$100 4ch ABS reluctor ring groove machining=$3400
So you see the price ends up about the same. The difference is the s60 you get 35 spline axles, 50 pounds more weight, and far less adjustability as far as gear setup and whine goes.
99bluefirebird is online now   Reply With Quote
Old 07-07-2009, 12:17 AM   #22
Trader Rating: 0
Oh yeah I see your point, well damn. Maybe the best thing would be when I finally get the car and after I actually do the LSX swap I'll decide which one would be best. Maybe by that time I'll have reached a decision. Ha ha. You make a good case though. I do want the most reliable and solid rear end I can afford, even if I'm not going to race, it can't hurt to have a little extra assurance, right?
TXSSIVE is offline   Reply With Quote
Tags
12, arm, axle, big, bolt, chassis, end, ends, engineeringhow, inch, narrow, noise, rear, rearend, s60, strange, torque
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
LS1TECH - Archive - Top
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Advertising - Terms of Service - Privacy Policy - JOBS
