Click here to visit LS1Tech
Click here to visit Performance Trucks
Click here to visit Mod Motor Tech
Click here to visit Modern Hemi
LS1Tech Wiki
LS1TECH
Go Back   LS1TECH > CHASSIS, SUSPENSION, APPEARANCE > Gears & Axles
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into LS1Tech.com, click logo to login
Old 11-02-2009, 07:52 PM   #1
Moderator
thechef's Avatar
Trader Rating: 9
Send a message via AIM to thechef
Default Axle bearing for MOSER 9 inch
help need part number for axle bearing
i need the part number for a axle bearing for my MOSER 9 inch 31 spline axle mine has a o-ring, the ID is 1.53 and the OD os 3.149
can i use a bearing that doesnt have a o ring?
where can i get this bearing locally?
__________________
Edelbrock Victor Jr Heads,Edelbrock Race Headers,Edelbrock Y Pipe,Magnaflow
GM High Tech Edelbrock LsX Head Install
http://gmhightechperformance.com/tec..._installation/
Originally Posted by Damian
Coming up on a turn thats got a 70 degree slope at 170+ mph will make your asshole pucker
thechef is offline   Reply With Quote
Old 11-02-2009, 09:40 PM   #2
DutchmanZ's Avatar
Trader Rating: 3
here is some irony. try a 2 sec. search
ford 9" moser axle bearing part number?
__________________
Monteray Maroon Met, LQ4 6.0L, M6, Pacesetter LT & ORY, Hooker Aerochamber Exhaust, Ported TB, LS6 intake & injectors, 85mm MAF, SLP Lid, Speartech Tuned
DutchmanZ is offline   Reply With Quote
Old 11-03-2009, 07:21 AM   #3
Moderator
thechef's Avatar
Trader Rating: 9
thanks, already did that, and NAPA doesnt recognize those numbers, and if you read they/ dont list show the bearing with the o ring in their computers
__________________
Old 11-03-2009, 07:31 AM   #4
Moderator
thechef's Avatar
Trader Rating: 9
Thanks Jaw Gears, BCS or Timken Bearing #514003
__________________
Old 11-03-2009, 07:42 AM   #5
danhr's Avatar
Trader Rating: 16
all you have to do is go to the parts store and ask for an axle bearing for a early style (66-79) ford bronco.
The o-ring is just an aftermarket solution to try to fight off the typical axle bearing leaks. You can use a bearing without an o-ring, just remember to put a light coat of silicone around the outside of the bearing to help seal it with the housing, so you don't leak gear oil on to your wheels/tires.
__________________
1997 Z28: iron block, cam, ported gm casting heads, edelbrock intake, moser 9"....
danhr is offline   Reply With Quote
Tags
9, axle, bearing, bearings, ford, inch, instal, install, installation, leak, leaking, moser, package, seal
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
LS1TECH - Archive - Top
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Advertising - Terms of Service - Privacy Policy - JOBS
