Click here to visit LS1Tech
Click here to visit Performance Trucks
Click here to visit Mod Motor Tech
Click here to visit Modern Hemi
LS1Tech Wiki
LS1TECH
Go Back   LS1TECH > CHASSIS, SUSPENSION, APPEARANCE > Gears & Axles
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into LS1Tech.com, click logo to login
Old 11-04-2009, 02:22 AM   #1
2002 Pontiac Trans Am
BigT2002's Avatar
Trader Rating: 2
Send a message via AIM to BigT2002
Default 1500 mile trip, rear end making small whine
So I'm in desperation at this point guys but I really needed to get some advice on this before anything. In 2 weeks I am heading from Columbia, SC to Minneapolis, MN in my car after being stationed down here for awhile. Lately I've been noticing that the rear end seems to make a small whine when the car is idle. I can then hear it get a little louder as the RPM's go up and then its all but silent when I actually hit the 45ish+ MPH (not sure if that is because of the exhaust or what). I haven't been able to check the fluid level yet, but my question is if I refill the fluid should I at least be able to get the car back up to Minnesota so I can actually install a 12-bolt? Or would it better to just get the thing completely looked at and if it is determined it needs a new ring & pinion, or anything else just do it that way? Guess I just don't want to fork $1k+ into something that will get replaced in like 2 weeks.
Car has bolt ons but nothing hardcore, hasn't seen the track at all, and hasn't had any hard launches in quite some time. Just getting up there in age (64k miles).
Suggestions/Tips/anything??
__________________
BigT2002 is offline   Reply With Quote
Old 11-04-2009, 06:37 AM   #2
LS1Tech Premium Sponsor
Exotic Performance Plus's Avatar
Trader Rating: 21
I'd drain and replace the gear lube and look for an abnormal amount of metallic particles in the gear oil. More than likely you'll be okay. You did mention noise at idle, which would not be from the rear, perhaps from something such as the exhaust rubbing the rear, etc. I'd get it up in the air and check it all out. Bob
__________________
Check out our huge website! http://www.exoticperformanceplus.com
260 244-4808/260 244-4821
ATI ProCharger & Moser Engineering sales and installations
Over 1 million and three hundred thousand dollars worth of Moser rearends sold!
Over 1 million and four hundred thousand dollars worth of ATI ProChargers sold!
http://www.ls1tech.com/forums/image.php?type=sigpic&userid=11410&dateline=122468  4580
Exotic Performance Plus is offline   Reply With Quote
Old 11-04-2009, 06:41 AM   #3
BigT2002's Avatar
Trader Rating: 2
Quote:
Thanks so much Bob I have to take it to my buddies place to get the oil changed (and he normally does all the other fluids as well for me) so I'll def. be on the lookout for it.
__________________
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
LS1TECH - Archive - Top
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Advertising - Terms of Service - Privacy Policy - JOBS
