Click here to visit LS1Tech
Click here to visit Performance Trucks
Click here to visit Mod Motor Tech
Click here to visit Modern Hemi
LS1Tech Wiki
LS1TECH
Go Back   LS1TECH > CHASSIS, SUSPENSION, APPEARANCE > Gears & Axles
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into LS1Tech.com, click logo to login
Old 08-14-2008, 03:22 PM   #141
SeaHawk's Avatar
Trader Rating: 1
Quote:
Originally Posted by Hennytime View Post
is anyone else getting that weird attack message when they go on the gears website?
Yes... What's that all about?
__________________
2001 Firehawk #310 - 10th Anniversary #54 M6/Bilstein Suspension
Speed Secrets LS2 402, L98+L76, Top Dollar TSP LTs, '95 Firehawk Bellows
http://tommyd.beeze.com/firehawk/
SeaHawk is offline   Reply With Quote
Old 08-19-2008, 11:06 PM   #142
hottrodz's Avatar
Trader Rating: 0
Quote:
Originally Posted by F-Body Lover View Post
I got a stupid question.... my friend got a 92 camaro RS with 2.73 open diff not LSD hes thinking of 3.73s is there a huge different on 305 TBI ? are the two wheels gonna burn or they will be the same one wheel burner?
yes & need to change carrier too for posi or lim slp
__________________
95 Z28 LT1/M6
91 RS A4/3.73 locker
88 LT R.I.P.
hottrodz is offline   Reply With Quote
Old 09-10-2008, 05:36 PM   #143
FMX05's Avatar
Trader Rating: 0
Yep. Firefox for the win...
__________________
99' NBM Formula M6 Patriot stage II LS6 style Heads, TTP Equalizer V3 cam, spec 3+ clutch, Lid, LT's, True duals, free mods, etc etc.Dynoed at 448rwhp and 418rwtq
11.93@119 1.83 60'
Idle & revs Video http://www.youtube.com/watch?v=9JDlfXHkRKk
FMX05 is offline   Reply With Quote
Old 11-24-2008, 12:42 AM   #144
camd01silv's Avatar
Trader Rating: 0
Send a message via MSN to camd01silv Send a message via Yahoo to camd01silv
Quote:
Originally Posted by SLP99sscamaro View Post
Yes I do kno M6 cars came with 3:42's stock and I kno I have the GU6 code. but then why at the beginning of this does it say 2000rpm @ 80 is a diff gear ?
Because it was quoting speeds for an A4. The A4 has a different overdrive ratio than the M6. I believe the A4's overdrive is something like .7:1 whereas the M6's 6th gear ratio is .5:1
__________________
2002 Arctic White SS, M6, TR224 cam, Comp 918 springs, PaceSetter LT headers, PaceSetter ORY, DMH electric cutout, Hooker catback, Strange 12 bolt w/ 4.11s, SLP linelock, 150hp of spray, SPEC stage 3+ clutch and SPEC steel FW
camd01silv is offline   Reply With Quote
Old 01-26-2009, 12:47 PM   #145
rusty2198's Avatar
Trader Rating: 0
A 4 with 2.73's 3500 vig stall with long tubes I shaved off 1.2 seconds off my 1/4 et but unfortunately I put in the stall and long tubes in at the same time so can't really give the converter all the glory but I can tell you go stall first it really woke my old tired LT1 up. Hopefully installing my 3.42's this week but at same time adding my new rims with DR's but either way will post my gains.
__________________
Hey Don't blame me I voted for McCain
rusty2198 is offline   Reply With Quote
Old 01-26-2009, 12:53 PM   #146
rusty2198's Avatar
Trader Rating: 0
Oh forgot to mention I have a really crappy 60' can't keep my street tires from roasting never had that prob with the factory converter. And one more thing to consider about going to a stall converter its smaller and lighter and frees up some reciprocating weight.
__________________
Old 02-10-2009, 12:46 AM   #147
Trader Rating: 0
i have 3.42 on my truck, how big of a difference will 4.11 make?
Quote:
Originally Posted by Ragtop 99 View Post
Stock Gear Ratios:
M6: 3.42
A4 Standard: 2.73 (GU2 code on the door sticker)
A4 Performance Axel: 3.23 (GU5 code on the door sticker)
WS6 and SS models came with 3.23s.
Your A4 did not come with 3.42s.
If your sticker is gone you tell which gears you have by your highway rpms:
3.23s @ 2000 rpm = 67 mph; 2.73s @ 2000 rpm = 80 mph
3.15s were available in A4 Vettes
The attached file has the mph & rpm for the most popular gear ratios for F-bodies:
M6:
3.73
3.90 (requires aftermarket rear)
4.10
A4:
3.42
3.73
4.10
The mph assume a stock 245/50/16 F-body tire. Those on 17" wheels will find this pretty close since your tires are a narrower aspect ratio. If you run ET Streets, they are generally larger than stock tires. Depending upon which tire you select, you can add 2% - 5% to the mph numbers to estimate your rpm for a given trap speed.
A stock A4's converter is unlocked at WOT. Therefore when you cross the line your rpms will be higher than shown in the chart. While the amount slip will vary by converter, you should figure an extra 5 - 8% above the rpm shown in chart when looking at the high rpm numbers where you are likely to be at WOT.
If you want to play further with tire sizes and gear ratios go here:
http://www.f-body.org/gears/
Additional Info for A4's:
Swapping from 3.23s to 3.42s is a waste of money. There is barely enough gain to justify the cost of a bottle of gear oil and additive, no less buying the gears. If you have 3.23s your next move is to 3.73s.
If you don't have a high stall torque converter, you really should look at that first. The big gains come from a converter, not from gears. You'll be amazed what a 3000 stall converter will do to the launch of a 2.73 geared car. Look in the automatic transmission forum for more info on them.
mr.08 is offline   Reply With Quote
Old 02-24-2009, 03:24 PM   #148
1998 Pontiac Firebird
erickprouty's Avatar
Trader Rating: 0
What is the viscosity of differential gear oil for a 98 Trans am ws6 ?
erickprouty is offline   Reply With Quote
Old 04-11-2009, 12:00 PM   #149
01ssreda4's Avatar
Trader Rating: 41
motive gear carries the 3.90 gear for the 10 bolts....
__________________
01 SS Rally Red A4 #4987
01ssreda4 is offline   Reply With Quote
Old 05-27-2009, 03:08 PM   #150
Shoulder Shaker's Avatar
Trader Rating: 33
This was a good read. I have questions regarding performance so I will keep searching
__________________
WRE Built 408ci, FAST 90/90, MTI lid, Hooker 1 7/8 LT w/ORP, NX Direct Port kit NOW jetted for 300hp and some other things. Number's to come Soon
Shoulder Shaker is offline   Reply With Quote
Old 05-27-2009, 06:34 PM   #151
Trader Rating: 0
Default Gears vs Convertor
You convertor guys say put the convertor in first but i don't see how in the world you can drive a car around with a 4000 stall without it screaming and burning a pile of fuel. Sounds great for a race car but not if you want to drive it around all the time. Convertor guys chime in and give me your input. It seems like it would be screaming and you darn sure cannot fly down the freeway without cooking it with heat. Am I wrong? Drive it from Houston to Dallas cruising at 80 and it will burn twice as much fuel and produce so much heat even with a motorhome size trans cooler,,,it aint gonna live. Is the advice convertor for a race car and gears for a DD or weekend cruiser??? Chime on in.
Footlead is offline   Reply With Quote
Old 05-28-2009, 02:29 AM   #152
Trader Rating: 2
Quote:
Not sure who mis-informed you about converters but lets answer some questions from your post.
I would hands down put a converter in first before I put in gears. I have a Yank PT4400 and I DAILY DRIVE my Trans Am to work, to my g/fs, store, what ever city, highway anything.
It doesnt scream what so ever, it doesn't cook on the highway or rev out crazy either once I get going over 45 MPH the converter will lock and bring the RPM's all the way down like a stock car. I could easily drive from Houston to Dallas if I lived in Texas, I don't lost any gas mileage on the highway but some in the city. I run a B&M 24,000 GVW Trans cooler and have no issues.
Hope this helps you out some if you have any more questions feel free to PM me!!!
XxApollynxX is offline   Reply With Quote
Old 05-28-2009, 04:44 AM   #153
1999 Chevrolet Camaro
Trader Rating: 0
I have learned a lot from this thread. I have a 99 SS M 6. I am trying to get a kick in my pants more than I am worried about drag times or gas milage. I know the 410 gears will feel fast and cause higher revs through out the gears. I think the car will feel more torquey (if that is a word). Can I simulate 410 gears by driving at say 750 RPMs higher than I normaly would through out the gears? I feel like I am missing something I can't put my finger on. I feel vulnerable at the top and bottom of my gears when I am driving, like if I am eying someone up or comming to a possible yellow light I want to down shift. I kind of feel like I need gears since I can not get into major mods yet. Any advice or info would be great. Any M6 feed back on the motive 390 gears or 410 gears in general would be great. Thanks in advance
BOONEY7750 is offline   Reply With Quote
Old 11-06-2009, 12:32 PM   #154
2001 Chevrolet Camaro
Trader Rating: 0
got a howling in the rear end and have narrowed it down to my ring and pinion. so its time for some new gears. i have a m6 with 3.42 and i want to go to 4.10s but ive got a buddy who has them in his t/a and he blows the tires off 1-3 gear.....and he dont even have a 2nd gear! and thats what concerns me. so i wanna say 3.73 but ive heard theres no difference between them and the stocker. any suggestions?
01stngkiller is offline   Reply With Quote
Old 11-06-2009, 03:08 PM   #155
Crash00527's Avatar
Trader Rating: 2
3.73's are only meant for autos. think you need 4.10's
__________________
2002 Camaro SLP#1651/ SS 35th Anniversary
The "Blue Blur"
5.7 V8 350 Pure American Muscle
Navy Blue Metallic ~Auto ~T-Tops ~1 of 117
Click here for pics and Mods:
http://www.cardomain.com/ride/2426150
Crash00527 is offline   Reply With Quote
Tags
273, 390, 6th, 88, affect, big, changing, gear, gearing, gears, ls1, motive, ratio, rpms, speed, tires, trans, trap
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
LS1TECH - Archive - Top
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Advertising - Terms of Service - Privacy Policy - JOBS
