I know im on an F Body website and all but can you get a G Body rear? If so how much would it be for a 12 bolt 33 spline spool 3.73 gears.
Yes indeed. I use to race two different G Body Malibu's, I'll get back with you when I get to the shop. Thanks for inquiring. Bob
__________________ Check out our huge website!http://www.exoticperformanceplus.com 260 244-4808/260 244-4821 ATI ProCharger & Moser Engineering sales and installations Over 1 million and three hundred thousand dollars worth of Moser rearends sold! Over 1 million and four hundred thousand dollars worth of ATI ProChargers sold!
12 Bolt for the G Body, with 33 spline axles, $1800.00 plus shipping. I'm going to say shipping to you would be approx $125.00 Thanks! Bob
We've communicated via PM, but I would like some more information, please.
9 Inch
4:30 gear
spool
iron center section
31 spline axle
torque arm bracket
shipped to 77449?
I don't know the exact dimensions, but can I get the longer and wider NHRA studs?
9 Inch
4:30 gear
spool
iron center section
31 spline axle
torque arm bracket
shipped to 77449?
9 Inch
4:30 gear
spool
iron center section
31 spline axle
torque arm bracket
Longer wheel studs
shipped to 77449
I'll do $2,100.00 shipped to you.
Thanks! Bob
Hey bob im sorry to be a pain in the a** but can you see how much a Moser 9 inch housing w/ 35 spline axles. no center section. And if i went to get a brake conversion for this 9" what do i need to get the brakes to fit? What kind of brakes did you use on your G body? If u have a set you want to sell I would buy them
__________________
Not a problem.
Moser 9 Inch housing and axles with torque arm bracket
Your choice of axle spline
Narrowed housing, no extra charge.
$1,000.00 shipped by UPS
We would need to know what brake manufacturer you are going to use, to get the right ends. I can get you Wilwood rear drag race brakes from Moser for the rear for $440.00. Rear Pro Street brakes are $520.00.
I ran the stock brakes on my Malibu's. Bob
I don't need a torque arm bracket and what ends would I need to run my stock setup?
Oops. $850.00 shipped for your G Body. We would just tell Moser you need it set up for stock brakes. Bob
Thank you for all your time .. i will be talking to you in about 2 weeks or so about getting it. Trust me it will be through u guys since you have done all the work in getting the price for me!
Can i get a price on a 9inch spool aluminum center 35 spline gun drilled axles and tq mount shipped to 22960 and will it come ready to install also will my brakes go on it
__________________ 98 SS TSP 408 full weight 4 sale $16,000
Not a problem, I'm glad to be able to quote the prices for you. Thanks! Bob
Moser 9 Inch with spool and torque arm mount, your choice of gear ratio
35 spline axles
Aluminum center section
Gun drilled axles
$2,340 shipped by UPS
Thanks! Bob
Couldn't we get some kind mod to sticky this thing for Bob?
Thanks, I agree! Bob
***SIG EDITED!!! 8 SINGLE-SPACED LINES OF TEXT --OR-- 500W x 150H PIC & 3 SINGLE-SPACED LINES OF TEXT IS THE MAX!!!*** >>>Signature Policy - Click Here<<< VIP1 - LS1TECH.com Staff
wondering if there is a price break on the 12 bolts if I dont need ABS or TCS? Also wondering if I need to send in my backing plates for either the 9" or 12 bolt? Will the stock driveshaft and suspension pieces work with both of these, and finally, what is a shipping estimate on the 12 bolt to SE Minnesota (56026)
__________________
Quote:
Originally Posted by flyin red TA
But most importantly, could you still see yourself peeing in her butt in 40 years?
Yes, deduct $100.00 for not using ABS or TCS.
You just install the backing plates yourself, instructions are included.
