Click here to visit LS1Tech
Click here to visit Performance Trucks
Click here to visit Mod Motor Tech
Click here to visit Modern Hemi
LS1Tech Wiki
LS1TECH
Go Back   LS1TECH > CHASSIS, SUSPENSION, APPEARANCE > Gears & Axles
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into LS1Tech.com, click logo to login
Old 10-29-2009, 10:30 AM   #861
Trader Rating: 1
Yes my car is a 6-speed, I believe the axles are leaking though I was told last time I had the car checked out. How far away are you from Chicago and how long would it take if I were to to come down there one day to get it all installed?
CapoWS6 is offline   Reply With Quote
Old 10-29-2009, 11:52 AM   #862
Mike 02T/A's Avatar
Trader Rating: 0
Quote:
Originally Posted by CapoWS6 View Post
Id love to do a whole new rear end, but should I wait till I break my stock one? I only have 24k miles on my 00 WS6.
Keep it stock for awhile. Once you start getting worried, buy the new rear end before you break other parts with it.
__________________
2002 WS6 T/A A4 - TP built transmission w/ 4000 Vig, NX MAF kit and BMR suspension
11.515 @ 120.75 150 shot, Stock transmission and stall
Mike 02T/A is offline   Reply With Quote
Old 10-29-2009, 08:42 PM   #863
LS1Tech Premium Sponsor
Exotic Performance Plus's Avatar
Trader Rating: 21
We're several hours away directly down Hwy 30 from Chicago. We figure on a four to six hour install. Give us a call and we can get it ordered for you. Thanks. Bob
__________________
Check out our huge website! http://www.exoticperformanceplus.com
260 244-4808/260 244-4821
ATI ProCharger & Moser Engineering sales and installations
Over 1 million and three hundred thousand dollars worth of Moser rearends sold!
Over 1 million and four hundred thousand dollars worth of ATI ProChargers sold!
http://www.ls1tech.com/forums/image.php?type=sigpic&userid=11410&dateline=122468  4580
Exotic Performance Plus is offline   Reply With Quote
Old 11-02-2009, 11:24 AM   #864
Trader Rating: 22
Hey Bob, Could you please give me a price on a moser 9" housing. I would like Stock width for a 1994 Z28, torque arm bracket, backbrace, extra fill and drain plug, welded on lower control arm relocation brackets, welded on bmr xtreme anti roll bar brackets, Could you please give a total price shipped with it being powder coated black and a total price shipped with out it being powder coated. I will be having it shipped to 98230 WAshington.
Let me know as Im ready to purchase it. hope to hear from you today.
Thanks a lot
Ryan
__________________
94 Z28 Hardtop M6, LE2 H/C/I emissions cam, 391RWHP 369RWTQ.
airfix is online now   Reply With Quote
Old 11-02-2009, 01:18 PM   #865
Trader Rating: 21
Thumbs up
Thanks a lot
Ryan
PM'd you back. Thanks Ryan! Bob
__________________
Old 11-11-2009, 06:00 AM   #866
Trader Rating: 21
Our new Moser/EPP GTO M9 rear is advertised in the new issue of GM High-Tech Performance Magazine. Bob
__________________
Old 11-15-2009, 01:20 PM   #867
Trader Rating: 21
Quote:
Originally Posted by Exotic Performance Plus View Post
Moser 12 Bolt with Eaton Posi for F Body, your choice of gear ratio
Torque arm mount
30 spline axles
$2,450.00 Free Shipping by UPS
Options:
33 Spline Axles with 10 year warranty $65.00
ABS (3 channel) or ABS/TCS (4 channel) $100.00
Exciter rings installed on axles for four channel option $75.00
Performance aluminum cover $135.00
Powdercoated, choice of colors $200.00
Lower control arm relocation brackets supplied and welded on $Free
Anti-roll bar brackets supplied and welded on for using BMR anti-roll bar $50.00
http://www.exoticperformanceplus.com....html?item=146
Moser 9 Inch with Trac-Loc or Locker (your choice) for F Body, your choice of gear ratio
Torque arm mount
28 or 31 Spline Axles For Trac-Loc, 28, 31 or 35 spline axles for Locker
Options:
Aluminum center section $155.00
Drain plug $35.00
Extra fill plug for easier access $35.00
ABS 3 channel option $175.00 N/A with alum center
ABS/TCS 4 channel option $100.00
Exciter rings supplied for 4 channel option $75.00
http://www.exoticperformanceplus.com....html?item=145
Moser 9 Inch with spool, your choice of gear ratio
Torque arm mount
$2,300.00 Free Shipping by UPS
Options:
Drain Plug $35.00
http://www.exoticperformanceplus.com....html?item=148
Moser 9 Inch housing and axles with torque arm bracket
Your choice of axle spline
Narrowed housing, no extra charge.
$1,050.00 Free Shipping by UPS
Options:
Drain Plug $35.00
ABS 3 channel option $175.00 (Requires Moser center with optional 3 channel option)
http://www.exoticperformanceplus.com...html?item=1116
Moser M9 fabricated housing with axles and Trac-Loc in nodular iron center section $3,150.00 shipped
Includes chromoly torque arm and transmission crossmember
Same weight as 10 bolt!
Options:
Drain and Fill Plug (Free)
Many other options can be found here.
http://www.exoticperformanceplus.com...html?item=1324
I recommend the 9 inch rear for the higher horsepowered cars, and for those who have a manual transmission. Here is why.
Put a 12 bolt into a early Chevelle, Nova, Camaro, etc and you can beat the crap out of it, and not hurt anything. Put one into one of our cars with a torque arm, make a couple 4000 to 5000 dragstrip launches, and I can just about guarantee you'll pick up gear noise. If it is a drag only car, you'll never know or care about the gear noise. Drive your car home from the track, and the noise will drive you nuts. I feel the torque arm stresses the 12 bolt housing, causing distortion. We have never seen this happen with the 9 inch housing.
Call us at 260 244-4808, or order the Moser rear of your choice from our website. Rear ends are ready to ship two days after order is received, allow added time if rear is to be powdercoated. Thanks! Bob
New!! Moser/EPP M9 rear for the '04-'06 GTO!
http://www.exoticperformanceplus.com...html?item=1835
Updated to not include the Truetrac for the time being, as I have been seeing too many problems with them. Bob
__________________
Old 11-22-2009, 05:40 PM   #868
Trader Rating: 4
is epp going to have any christmas sales or anything like that for moser 9 inchs coming up?
__________________
2000 Black SS M6
ms3, prc valvetrain, pacesetter lts, pacesetter ory, asp underdrive pulley,ls6 intake,magnaflow catback with flowmaster muffler, SSRA, 4.10s, mikey t et streets.
12.5 at 115 on 10 bolt so far lol
00 black ss is online now   Reply With Quote
Old 11-22-2009, 07:35 PM   #869
sixpack_2_go's Avatar
Trader Rating: 0
i already have a 9"...but... you guys should run a sale on d-1 procharger kits for 98-02 f-body. i would be interested in that...hint...hint...
__________________
2002 S.O.M. M6 CAMARO "THE DIRT MERCHANT"
12.97@111.08(stock) - dyno-325.6rwhp/339.9rwtq(stock)
NOW: 480rwhp&512rwtq | CAMMED | CAGED | DAILY DRIVEN |
new build comming soon...
http://profile.myspace.com/index.cfm...endid=97834361
sixpack_2_go is offline   Reply With Quote
Old Yesterday, 05:46 AM   #870
Trader Rating: 21
Quote:
With the free shipping, sometimes when the rears are shipped out to the West Coast I break even as it is. If you wire transfer us the money, I deduct $100 from the total. The reason is we have to pay approx 3% on credit card transactions, it usually amounts to $3,500 a month! Thanks. Bob
__________________
Old Yesterday, 05:48 AM   #871
Trader Rating: 21
Quote:
http://www.exoticperformanceplus.com....html?item=798
Wire transfer us the money and we'll deduct $100 from the total. Thanks. Bob
__________________
Old Yesterday, 03:42 PM   #872
Trader Rating: 0
sounds good but, i don't my tax check untill late december. offer still good for then? i'll also be getting a few other things from you guys like epp boost cam, guages, exc.
__________________
Old Today, 06:08 AM   #873
Trader Rating: 21
Yes it will be, thanks! Bob
__________________
Tags
9, abs, axle, channel, complete, end, exciter, gasket, moser, pn, rear, rearendscom, rears, rings, trans
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
LS1TECH - Archive - Top
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Advertising - Terms of Service - Privacy Policy - JOBS
