Click here to visit LS1Tech
Click here to visit Performance Trucks
Click here to visit Mod Motor Tech
Click here to visit Modern Hemi
LS1Tech Wiki
LS1TECH
Go Back   LS1TECH > CHASSIS, SUSPENSION, APPEARANCE > Gears & Axles
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into LS1Tech.com, click logo to login
Old 07-21-2006, 06:38 AM   #1
LS1Tech Premium Sponsor
Exotic Performance Plus's Avatar
Trader Rating: 21
Thumbs up Moser Rear End Prices At Exotic Performance Plus
Moser 12 Bolt with Eaton Posi for F Body, your choice of gear ratio
Torque arm mount
30 spline axles
$2,450.00 Free Shipping by UPS
Options:
33 Spline Axles with 10 year warranty $65.00
ABS (3 channel) or ABS/TCS (4 channel) $100.00
Exciter rings installed on axles for four channel option $75.00
Performance aluminum cover $135.00
Powdercoated, choice of colors $200.00
Lower control arm relocation brackets supplied and welded on $Free
Anti-roll bar brackets supplied and welded on for using BMR anti-roll bar $50.00
http://www.exoticperformanceplus.com....html?item=146
Moser 9 Inch with Trac-Loc or Locker (your choice) for F Body, your choice of gear ratio
Torque arm mount
28 or 31 Spline Axles For Trac-Loc, 28, 31 or 35 spline axles for Locker
Options:
Aluminum center section $155.00
Drain plug $35.00
Extra fill plug for easier access $35.00
ABS 3 channel option $175.00 N/A with alum center
ABS/TCS 4 channel option $100.00
Exciter rings supplied for 4 channel option $75.00
http://www.exoticperformanceplus.com....html?item=145
Moser 9 Inch with spool, your choice of gear ratio
Torque arm mount
$2,300.00 Free Shipping by UPS
Options:
Drain Plug $35.00
http://www.exoticperformanceplus.com....html?item=148
Moser 9 Inch housing and axles with torque arm bracket
Your choice of axle spline
Narrowed housing, no extra charge.
$1,050.00 Free Shipping by UPS
Options:
Drain Plug $35.00
ABS 3 channel option $175.00 (Requires Moser center with optional 3 channel option)
http://www.exoticperformanceplus.com...html?item=1116
Moser M9 fabricated housing with axles and Trac-Loc in nodular iron center section $3,150.00 shipped
Includes chromoly torque arm and transmission crossmember
Same weight as 10 bolt!
Options:
Drain and Fill Plug (Free)
Many other options can be found here.
http://www.exoticperformanceplus.com...html?item=1324
I recommend the 9 inch rear for the higher horsepowered cars, and for those who have a manual transmission. Here is why.
Put a 12 bolt into a early Chevelle, Nova, Camaro, etc and you can beat the crap out of it, and not hurt anything. Put one into one of our cars with a torque arm, make a couple 4000 to 5000 dragstrip launches, and I can just about guarantee you'll pick up gear noise. If it is a drag only car, you'll never know or care about the gear noise. Drive your car home from the track, and the noise will drive you nuts. I feel the torque arm stresses the 12 bolt housing, causing distortion. We have never seen this happen with the 9 inch housing.
Call us at 260 244-4808, or order the Moser rear of your choice from our website. Rear ends are ready to ship two days after order is received, allow added time if rear is to be powdercoated. Thanks! Bob
New!! Moser/EPP M9 rear for the '04-'06 GTO!
http://www.exoticperformanceplus.com...html?item=1835
__________________
Check out our huge website! http://www.exoticperformanceplus.com
260 244-4808/260 244-4821
ATI ProCharger & Moser Engineering sales and installations
Over 1 million and three hundred thousand dollars worth of Moser rearends sold!
Over 1 million and four hundred thousand dollars worth of ATI ProChargers sold!
http://www.ls1tech.com/forums/image.php?type=sigpic&userid=11410&dateline=122468  4580
Exotic Performance Plus is offline   Reply With Quote
Old 07-26-2006, 06:12 PM   #2
TNTramair's Avatar
Trader Rating: 8
Send a message via AIM to TNTramair
whats shipping gonna cost to 18974??
__________________
2000 Trans Am Ws.6 M6 402TT
1999 Formula M6 Hardtop stock
GO BIRDS!
TNTramair is online now   Reply With Quote
Old 07-27-2006, 05:48 AM   #3
Trader Rating: 21
Smile
Quote:
Moser 9 Inch with Truetrac for F Body, your choice of gear ratio
31 Spline Axles
$2,400.00 Shipped by UPS
31 Spline Axles
ABS/TCS (4 channel) 3 channel not offered
$2,500.00 Shipped by UPS
The nine inch prices include shipping. Bob
__________________
Old 07-27-2006, 03:01 PM   #4
TNTramair's Avatar
Trader Rating: 8
im sorry...i should have specified for the 12 bolt.
__________________
GO BIRDS!
Old 07-27-2006, 03:54 PM   #5
Shamson5.7's Avatar
Trader Rating: 3
Send a message via AIM to Shamson5.7
10 year warranty? :-x
Have they always come with that? I bought mine back in Dec.
__________________
98 Trans Am Convertible -
Pacesetter LT's | SLP Lid | LS6 intake | Custom Dual setup | Moser 12bolt w/ 4.11s | LS7/LS2 combo clutch with Mcleod adj MC | Spohn TA | Walbro Fuel Pump | BMR suspension all the way around and street tuned.
96 Hardtop Firebird - Stock
Shamson5.7 is offline   Reply With Quote
Old 07-27-2006, 05:20 PM   #6
black01_WS6's Avatar
Trader Rating: 10
Send a message via AIM to black01_WS6
the axles have the 10 year warranty.
__________________
2001 WS.6 A3 Black on Black. ASC# 4231
Tv2 cam, stage 2.5 ls6 heads, Moser 12 bolt and some juice
98 dodge Ram- the DD and pull
black01_WS6 is offline   Reply With Quote
Old 07-28-2006, 05:11 AM   #7
Trader Rating: 21
Thumbs up
Not a problem. Approx $100 to $125.00. Bob
__________________
Old 07-28-2006, 05:13 AM   #8
Trader Rating: 21
Thumbs up
Quote:
Yes, the axles carry the 10 year warranty. Bob
__________________
Old 07-28-2006, 11:49 PM   #9
cws T/A's Avatar
Trader Rating: 3
why no 3channel how do i delete this abs shit
__________________
2000 Trans Am ws6
cws T/A is offline   Reply With Quote
Old 07-29-2006, 07:56 AM   #10
Trader Rating: 21
Question
Quote:
The 12 bolt has the ABS option, the nine inch does not.
You'll have to disconnect your ABS to run a nine inch. We've done this on many installs, and the car just won't have ABS, which isn't a problem if you know how to threshold brake. Bob
__________________
Old 08-03-2006, 05:59 AM   #11
Trader Rating: 21
Thumbs up
DETROIT TRUETRAC TORQUE PROPORTIONING DIFFERENTIAL
The Detroit Truetrac is the first gear type limited slip differential in the industry. Its’ patented design of parallel axis planetary helical gears provide a quiet, automatic splitting of torque. Power transfer goes literally unnoticed by the driver – even in front wheel drive axles.
The Detroit Truetrac performs like an open differential under normal driving conditions and automatically transfers torque to the wheel with better traction when ground conditions warrant. The limited slip responds instantly to torque feedback, anytime, at any speed.
MOSER 9" HOUSING
In competitive racing, you can’t leave anything to chance. The proper setup using quality hi-performance parts is the only way to ensure that the time you spend setting up your vehicle is not wasted. Why spend a ton of money on a new engine that could fuel a rocket to the moon, and then turnaround and buy an old rusted out rear end that is probably going blow up in the water box? Doesn’t make much sense. At Moser Engineering, only the best materials are used when producing our 9” Housings. Our heavy-duty banjos are reinforced in critical stress-point areas, thickened up considerably when compared to its’ OEM counterpart. New, seamless housing tube is essential in assuring ultimate housing strength, which our 3” in diameter tubing is not only seamless, but also a 1⁄4” thick. We also use newly stamped high-strength brackets that are considerably thicker than used OEM brackets. Included with each housing produced are newly forged housing ends, as well as new bushings. Call EPP today and step-up to the best 9” housing available.
COMPLETE MOSER 12 BOLT
Moser Engineering offers the best aftermarket 12 Bolt on the market. Our 12 Bolt housings are newly cast nodular iron housing units that are direct replacements for most leaf-spring, coil-spring, and torque arm General Motors OEM applications. The extremely durable housing units have giant caps utilizing half inch Allen bolts, and include perches or brackets. You have a choice of axles with pressed on ball bearings, or OEM style c-clip with c-clip retention. The units can be set up for anti-lock brakes and work with many OEM GM brake setups. Utilizing new housing ends adds to the simplicity and ease of installation, which is unparalleled in the industry. The complete package includes a Moser 12 Bolt housing, Custom Alloy Axles with ball bearings, studs and retainer plates. Also includes either a Moser full spool or a posi unit, Pro Street gears, 1350 series pinion yoke, chrome cover, and assembly. Brakes are not included. When ordering with a Moser full spool or a posi unit, you have the option of 30 spline axles or upgrade to our 33 spline axles, which carry a 10 year replacement warranty. However, if you are ordering the package with c-clip axles you can only order 30 spline axles. TWO-DAY TURNAROUND ON ALL ORDERS!
__________________
Old 08-03-2006, 06:46 AM   #12
Trader Rating: 0
9 inc with no center section with 31spline to 64024
__________________
[font=Comic Sans MS] 9.53@142 mphin my g body[/color]
badnuz is offline   Reply With Quote
Old 08-03-2006, 06:49 AM   #13
Trader Rating: 0
Quote:
that is with a 4 pin
__________________
Old 08-03-2006, 08:33 AM   #14
Trader Rating: 21
Thumbs up
$950.00 shipped to Mo. Thanks for inquiring. Bob
__________________
Old 08-03-2006, 08:35 AM   #15
Trader Rating: 21
Thumbs up
Add $100.00 for four channel. Bob
__________________
Old 08-03-2006, 09:04 PM   #16
Trader Rating: 0
Send a message via AIM to tman2006
Moser Complete 12 bolt Rearend w/ Truetrac, 33 spline upgrade. How do I know if it is 3 or 4 channel and if I get abs and tcs?
tman2006 is offline   Reply With Quote
Old 08-04-2006, 06:24 AM   #17
Trader Rating: 21
Smile
Quote:
3 channel is ABS, 4 channel is ABS and TCS. ABS stands for automatic braking system and TCS stands for traction control system. If you have a TCS switch on the dash then you have ABS/TCS. Hopefully this helps. Bob
__________________
Old 08-04-2006, 07:08 AM   #18
Trader Rating: 0
Send a message via AIM to TATER Send a message via MSN to TATER
9" Housing for 1998 F-Body shipped to 72834?
(Housing with axle tubes, suspension/torque arm mounts, stock GM caliper brackets. I have a center section.)
Also, what would the axle lengths be? I don't need it narrowed any, just whatever fits under a 4th gen F-Body.
TATER is offline   Reply With Quote
Old 08-04-2006, 09:44 AM   #19
Trader Rating: 21
$950.00 shipped. Moser has these set up to exactly fit and to be the same width as the factory 10 bolt. Bob
__________________
Old 08-05-2006, 12:16 AM   #20
FAST LS1's Avatar
Trader Rating: 1
I'd like to pick up the Moser 9", but I'm concerned about the trq arm. I already have an LG trq arm that cost $500, and don't really want to have to get another trq arm. Will the Moser 9" bolt up to the LG trq arm?
__________________
00' Chameleon Formula M6
Ram Air, Whisper Lid, Fernco, Jantzer TB, ASP Pulley, QTP HVMC LT's, ORY-pipe, Catback, BMR tubular SFC's, LCA reloc brackets, Strano 35mm & 22mm sway bars, Trackbird PHR, LG trq arm, Koni SA shocks, Ground Control Coilovers, Bear GT+ brakes, Eradispeed rotors, Chrome Y2K 17x9.5 wheels
60' 2.06 1/4 12.62 @114.72mph
351rwhp
FAST LS1 is offline   Reply With Quote
Tags
9, abs, axle, channel, complete, end, exciter, gasket, moser, pn, rear, rearendscom, rears, rings, trans
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
LS1TECH - Archive - Top
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Advertising - Terms of Service - Privacy Policy - JOBS
