just wondering if there is any real gain to switching to 1.8 rockers. Or is it just a waste of time and money.
__________________
2000 SS #6889 6 spd, patriot stg 2 heads 231/237- 589/595 112 lsa cam ls6 intake boltons ,centorforce duel friction with the tick, 436 hp 416 trq with stock ls1 clutch
TOTALED
99 vette centerforce dual friction clutch tick master, and american racing headers with x pipe. nitrous outlet plate kit, lingenfelter launch controller.
If you ever plan on doing a cam swap you will need to go back to the 1.7's. IMHO its a waste of money unless you NEVER want to cam it. Most (99%) of the cams recommend the 1.7's
+1 ^^^ Only for someone who will never to a Cam swap ever. Due to the fast ramp rate of most aftermarket camshafts the use of 1.8 rockers is not recommended. If you did choose to do them its probably worth around 10hp
Go with the 1.7's non-adjustables, they will still give you 8-10rwhp and then when you eventually get a cam, and you will, you can reuse them. I just installed HS 1.7's and they are great, I have never had them on any of my previous LSX's and I love them.
You can still pickup 8-10 rwhp just by switching to a full roller rocker? Never herd that before.
__________________ 2001 SOM Firebird Trans Am WS6 17,500 mi
Cam| bolt on's| 4.10's 1996 Red stepside S10 ZR2 268,000 mi
Bolt on's| 6" Superlift| 4.56's| Vette/ OD servo| 32" MT/R's on ZQ8 wheels 2002 Yellow stepside S10 Xtreme 1994 4wd S10 205,000 mi winter beater
I just looked at their site and didn't see anything. Where did you read this?
Your never gonna get that kind of power just going to a roller tip. Most of the friction is in the fulcrum pivit point which is already roller in the LSx motor. Full roller is cool and helps keep down valve guide wear with high lift cams, but that claim is just smoke.
It probably also says "gains up to 8-10 rwhp" 1-2 hp falls under the "up to" banner.
Re'
__________________ 2004 Pont GTO LS1/M6 Flowmaster 1 chambers & K&N CAI
1994 LS1/M6 Z28 PICS HERE 98+ SS clip, 2002 346 LS1, QTP LTs, Borla cat back, QTP E-cutout, MTI Stealth II, SLP Lid, LS6 intake, ported T/B, EFI Live tunning, B&M shifter, Centerforce Dual Friction clutch SOLD
