Click here to visit LS1Tech
Click here to visit Performance Trucks
Click here to visit Mod Motor Tech
Click here to visit Modern Hemi
LS1Tech Wiki
LS1TECH
Go Back   LS1TECH > LS1-LS2-LS3-LS6-LS7 PERFORMANCE > Generation III External Engine
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into LS1Tech.com, click logo to login
Old 03-07-2009, 10:19 PM   #1
Trader Rating: 0
Default Throttle Body and oil pan questions
I was replacing the water pump on the 99TA and noticed a few things.. the throttle body flap had build up on it.. and when i removed the TB noticed that there was build up behind it also.. now im new to the TA and not familiar enough to determine what may be causing this.. now i know that the car has over 100,000 miles on it.. wasnt taken care of to much, besides the regular oil changes.
Here are 2 images of what im talking about.. can anyone offer suggestions on what to check or do to help with this.
Also wanted to know if its easy to complete a oil pan gasket replacement alone as a weekend thing.. i have heard you have to jack the motor up in order to do the replacement..
If there are any sites that show or list out the steps that woudl be great..
im use to working on the old school motors.. those were easy enough to take off the pan and replace pretty quick..
CubanGT is offline   Reply With Quote
Old 10-18-2009, 01:39 AM   #2
Trader Rating: 0
Can anyone offer some suggestions? If i need to lift the motor out, i finally have a engine lift.. and can do it next weekend. just want to make sure i have to go thru all that before actually doing it.. and since ill be down there, ill be checking and replacing any other gaskets that need replacing, i know she has some leaks so i can clean everything up during the week and check for leaks before starting the work..
thanks.
Old 10-18-2009, 12:02 PM   #3
LS69TA's Avatar
Trader Rating: 29
Send a message via AIM to LS69TA
If you have a K&N filter that could explain the oil buildup on the front of the tb blade. The pcv valves on these cars are notorious for allowing oil past them and into the intake. A cheap way to fix it is to get some rubber hose and a cheap small air&oil separator for air tanks at Home Depot. Search "Home Depot catchcan" in the External Engine section and you can find some pics. Put it after the pcv valve and before the TB and it'll catch any oil that gets past the pcv valve before it goes into the intake.
One thing I'd do if I were you (cheap free mod) is pull out the EGR tube that's right behind your TB in the pic..be careful not to kink it when pulling it out..and take a dremel or something and cut off the part that hangs down into the intake blocking the airflow. Then just re-install the tube.
Not sure about the oil pan gasket in the car, I haven't had to do one of those yet.
__________________
"A SS looks like it could kick your ass if it wanted to, but a WS6 looks like it's coming over to do it!"
'05 Ram 1500 QC 4x4yellow, hemi,1chamber,cutout, Superchips 3815, 305/50/20 Goodyears.
SOLD '69 T/A clone project,LS1/6spd,FM15,4th gen T/A interior, Hotchkis suspension, 17x9.5/18x10.5 Z06 wheels, etc. etc.
Previous LSXs: red '01 T/A M6, black '02 Z28 M6, red '01 WS6 A4, red '00 RCSB 5.3 A4
LS69TA is offline   Reply With Quote
Old 10-18-2009, 04:17 PM   #4
Casper9T9's Avatar
Trader Rating: 1
Send a message via AIM to Casper9T9
To replace the oil pan gasket, you need to get some space between the engine and the k-member since it will only drop down about an inch before hitting it. Are you sure the it's leaking from the oil pan? The gasket is metal and reusable and I've never heard of leaky pans being a problem on these cars. Rear main seal is more likely.
__________________
1999 Formula A4
2004 Sierra Z71
Casper9T9 is offline   Reply With Quote
Old 11-07-2009, 05:28 PM   #5
Trader Rating: 0
well when the car wouldnt start some time back and having issues running when it would start we took it to a shop so we could find out what the issue was.. oil pan, main seal and something else i cant remember..
where can i find steps to replace the main seal?
I finally got a cherry picker so if i need to lift the motor, im set.. just need to see how much time i need to devote to the job..
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
LS1TECH - Archive - Top
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Advertising - Terms of Service - Privacy Policy - JOBS
