383 ls1 rod bolt hitting oil shield???
my friend and I are putting his ls1 back together. He bought a new bottom end 383 stroker. putting it back together and one of the rod bolts is hitting the oil shield. Has anyone run into this problem and what should we do...
thanks guys
thanks guys
Its not always a direct fit, the Lunati crank will hit the block, well the crank wont but the rod bolts will. At leats thats what happened in the GM magazine 383 build.
Always check and double check the rotating assembly and valvetrain.
I havent experienced this problem but, I had ARP Studs on my old 3.8L Grand National engine and the dang oil dipstick would hit one and wouldnt go in very easy. It made my day whenever I checked oil!!!
Depending on the kit, the need to clearance/grinding the block is often necessary to run the 383 stroker.
https://ls1tech.com/forums/generatio...ing-block.html
hmm i was also unaware i thout all the kits would fit. but these guys are right no matter what kit u use always account for clearances and make sure it fits. last thing u want to do is fire it off and then.....boom....waste of 3000 dollars or more.
It would of been such a great help
if you guys would of listed your stats.
since some people say some clear and other people say some dont?
year of engine
and kit details would have been very appropriate!
year of engine
