Click here to visit LS1Tech
Click here to visit Performance Trucks
Click here to visit Mod Motor Tech
Click here to visit Modern Hemi
LS1Tech Wiki
LS1TECH
Go Back   LS1TECH > LS1-LS2-LS3-LS6-LS7 PERFORMANCE > Generation III Internal Engine
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into LS1Tech.com, click logo to login
Old 12-01-2008, 11:15 AM   #21
Super Speed's Avatar
Trader Rating: 8
I have that cam on a 112 as well... It's definitely DD friendly with a tune, go for it!
__________________
Mods - Lid, Smooth Bellow, SS Headers, ORYP, Borla, MSD 8.5 MM wires, LS7 Clutch, NGK Tr6's, spray and a 233/239 on a 112 LSA...
Super Speed is offline   Reply With Quote
Old 12-01-2008, 06:27 PM   #22
kngkahious's Avatar
Trader Rating: 0
Quote:
Originally Posted by BAN-LS1 View Post
Had patrick G spec me a cam for my car, ended up being a 227/231 614 618. Car runs AWESOME!
what kind of power did your car make ?
__________________
Quote:
Originally Posted by badjuju342 View Post
Hunter is the Chuck Norris of the LS1 world.... That is all....
Quote:
Originally Posted by 02 WS6 TA View Post
No harm, no foul...I'm just here for the comedy. If I could afford to be the fastest, you'd already know.
kngkahious is offline   Reply With Quote
Old 12-01-2008, 11:19 PM   #23
Trader Rating: 4
I had that cam in my nova....its rowdy but with a good tune it is driveable. Would i put it in my camaro i drive everyday...probably not. Its a darn good cam all around but like others have said how much can you stand.....?
__________________
64 rambler wagon....the summer cruiser
74 nova 350/th350 9" GT42 blow thru
86 GMC car hauler
98 ranger DD
twin74s is offline   Reply With Quote
Old 12-01-2008, 11:32 PM   #24
lilbuddy1587's Avatar
Trader Rating: 1
Send a message via AIM to lilbuddy1587
The BEST street cam, hands down, is either the TR224 OR the old MTI "hammer" cam (222/222 114+4).
Not only are both of these cams easy on the valvetrain but;
  • They make great power under the curve
  • Don't need to be run out to 6800-7k RPMs to make power/carry it
  • Are 100% DD friendly
  • Easy to tune
  • etc. etc.
Just remember, K.I.S.S.
__________________
2001 NBM SS M6 Sold
2006 Spice red GTO, M6
Do you have a pair of SHITTY "budget" heads? "Toss a FAST intake on, IT WILL MAKE IT ALL BETTER!"
Do you have a terrible head/cam setup? "Just throw a FAST intake in the mix, IT WILL FIX EVERYTHING!"
lilbuddy1587 is offline   Reply With Quote
Old 12-02-2008, 04:45 AM   #25
PREDATOR-Z's Avatar
Trader Rating: 0
TR 224 has a 50 variance rate on intake, XE-R is 49 and XE 53.
Hardly what I would call non agressive and "easy" on valvetrain
The 222/222 I forgot, but either XE (high lift) or XE-R
__________________
Tech Anarchist
PREDATOR-Z is offline   Reply With Quote
Old 12-02-2008, 02:37 PM   #26
Trader Rating: 1
Hammer is XE high lift lobes. As far as the TR224 goes, its a whole lot easier on the valve train than the "latest and greatest" XFI/LSL/LSK lobes that everyone seems to be infatuated with. Not only that but being that its in between the XE-R and XE lobes, I'd say that's pretty "non aggressive", wouldn't you?
I mean, a simple set of 918's or PAC 1518's and you won't need to worry about springs for 40-50k miles.
__________________
2001 NBM SS M6 Sold
Old 12-02-2008, 03:16 PM   #27
PREDATOR-Z's Avatar
Trader Rating: 0
No, les agressive than LSK at .200 lift but not less agressive than LSK,XFI, (the same at .006>.050), (XE-R is the harshest).
Both lobes TR, XFI have a variance rate of 50 intake and 51 Exhaust. TR just has less lift and profile, the intensity is similar.
You have to look at various lifts, .006,.050,.200,.400 (if available)
It is not infatuation, it is called progress. Even TR uses LSK,XE-R lobes.
Now mind you, back in the days, TR lobes actualy came on the market before XE-R. They are great lobes, but things evolve. All we can do is adapt and make more power.
As for the springs, they should all be tested, once a year or every 15K miles for pressures. If within tolerances, reuse, if below change.
you cannot just assume, this one is good for xxx miles and that one is yyy miles.
Modding internally means higher maintenance, it is like changing oil, has to be done for longer, reliable performance.
__________________
Tech Anarchist
Old 12-02-2008, 10:52 PM   #28
kngkahious's Avatar
Trader Rating: 0
wow that is way out of my league ! so i should just buy what ?
__________________
Old 12-04-2008, 09:59 AM   #29
Trader Rating: 2
233/239 is awsome. I have it, but it if your worried about its choppyness go with a 114 lsa, all though if you were truly badass youd do 112 LSA. As ive stated in here before, i went 11.53, hitting the limiter between 2-3 shift AND letting off (was actually racing in first round of a bracket race) so it woulda prolly gone a 11.45, this is all with 100% stock intake, throttle body, pulley and 241 heads. Id say that cam got the job done.
__________________
99 T/A Under the knife 10.9x or bust-
85 MM mas,Ram Air,Lid,Ported Fast 92/92,Fast Rails
12 bolt 3.73's,TSP 233/239,Hooker 1.75 LT's,ORY,LM1 !Egr,!Air,160 Thermo,Yank PT4000,SVO 38LB injectors. Flt Stage 5, 4' Alum DS. BMR Trakpak, LCA's,Relo brakets,Dragbar,Panhard,Subframe's, Custom loop. QA1's in all 4. 300# fronts. ARP everything,Rings,Bearings,Lifters,11:1 compression.
Old setup -11.539@ 118.82 1.649 60'
1969 z28 - 406SBC 9.77 @ 135.8 (1.413 60')
Dragkid1917 is offline   Reply With Quote
Old 12-04-2008, 10:19 AM   #30
krobinson123's Avatar
Trader Rating: 3
I have a 232/236 on a 112 in my h/c/i M6 100% street car with 4:11s and I'm very glad I didn't go any smaller. Driveability is perfectly fine, now I would never drive cross country in my car but thats because of the miles I would be putting on it. If I was really picky about street manners, while cruising around town I could just go from a stop in 2nd and skip to 4th and then to 5th if necessary... or 1st to 3rd. I drive my car alot during the summer BUT it is definetly not a daily driver
__________________
2002 Z28
krobinson123 is offline   Reply With Quote
Old 12-05-2008, 12:36 AM   #31
kngkahious's Avatar
Trader Rating: 0
what size cam sould i get to drive daily but run a 10.9-11.0 on a 150-175 hit ,yank 3500 ,sticky tires ,and a decent tune ! or will that not happen? that is all i want i dont really care about the size of the cam as long as it works .
__________________
Old 12-05-2008, 10:25 AM   #32
Trader Rating: 2
you can go faster than that with a 233/239 on a 150 hit. After my motor goes back together im lookin at 10.9-11.0 cam only no spray (Mods in sig)... Ill even provide you with a nice clip to show you what my baby sounds like on a 112 LSA.
Also by Daily Driver do you actually drive it like 40 miles a day? Mine wasnt the greatest DD however, i did DD it for a long time.
Excuse the music in the beginning... i didnt make the video
http://videos.streetfire.net/video/T...ORY_136380.htm
__________________
Old 12-06-2008, 02:24 AM   #33
kngkahious's Avatar
Trader Rating: 0
yeah like it is my only way of going right now! i drive it everywhere to be honest . that is kinda why i am wanting to sray the car instead of all motor i can run a smaller stall cam and a more streetable tune.and i can still put down a low 11 sec pass street trim . i think people get carried away when they say there car is a daily driver . they have a to town and back hot rod not a get in a drive it on vacation. if my car stock run's a 13.3 n20 is good for about 1.00 a stall .5 or more sticky tires .3-.5 cam and tune .75-1.00 that would be about a high 10.80 pass . nit that i am trying to say each will give me this much on my car but should have me close . am i right or am i right !!!!!!!! what about the tr224 cam is it a good all around cam.
__________________
Old 12-06-2008, 09:23 AM   #34
BIGB4015's Avatar
Trader Rating: 0
Quote:
This is what im trying to get out of my car through a m6.Looking for high 10s on the spray. I am currently running a 244/242 on a 112w/ 150 shot and looking to go smaller I need more power under the curve to move the heavy gto. I was thinking about the FTI street sweeper HT 228/232 111lsa.
__________________
04 YJ M6
HPE MEGADEATH 244/242 .612 .610 112
COMP DOUBLE ROLLER
PACESETTER 1 3/4 CATLESS MIDS
POWERBOND UD PULLY,PORTED & POLISHED TB
NEW ERA CAI, MSD WIRES, NGK TR55, SLP 160 STAT
CENTERFORCE, HURST SHIFTER ,HWS PLATE
BIGB4015 is offline   Reply With Quote
Old 12-06-2008, 09:25 AM   #35
LS1C5Vette's Avatar
Trader Rating: 8
I have a 233/239 with tea ls6 heads and did a 11.9 @121 on a shitty 60'
__________________
2000 MN6 Z51 Coupe -
TEA Stg 2 LS6 Heads, TSP 233/239 112 Cam, Vararam Intake, 85mm MAF, YT UL RR's, Ported TB, LS6 Manifold, 58lb Injectors, 160* T-Stat, U.D. Pulley, TSP 1 3/4 LT Headers, 3" H-Pipe, Z06 Ti Exhaust, DMH Cutouts, Centerforce DF Clutch (12") & a Hurst Short Shifter.
439 RWHP 397 RWTQ - DYNOJET
410 RWHP 379 RWTQ - MUSTANG DYNO
11.50 @ 122MPH 1.80 60'
LS1C5Vette is offline   Reply With Quote
Old 12-07-2008, 02:44 AM   #36
kngkahious's Avatar
Trader Rating: 0
i really like the cam performance wise and for a seekend hot rod. i am starting to get the idea that this is entirely to much for a true daily driver.
__________________
Old 12-07-2008, 02:51 AM   #37
Trader Rating: 8
I don't know man, I daily drive mine every day, I think any bigger would be TOO big though...
__________________
Tags
111lsa, 114, 231, 232, 233239, 612, 618, biggest, cam, cams, lobes, lsa, run, street, sweeper
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
LS1TECH - Archive - Top
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Advertising - Terms of Service - Privacy Policy - JOBS
