Click here to visit LS1Tech
Click here to visit Performance Trucks
Click here to visit Mod Motor Tech
Click here to visit Modern Hemi
LS1Tech Wiki
LS1TECH
Go Back   LS1TECH > LS1-LS2-LS3-LS6-LS7 PERFORMANCE > Generation III Internal Engine
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into LS1Tech.com, click logo to login
1997-2006 LS1 | LS6
Sponsored by
Texas Speed & Performance
Old 03-28-2009, 05:25 PM   #1
killerinparadise's Avatar
Trader Rating: 2
Default LQ4 build needs your advice...
I wanted to get some input from people on this site about a combo I'm thinking of putting together. It's a semi budget build because I'm not replacing anything in the bottom end apart from the rod bolts. I was originally going to do a turbo build with the low compression LQ4 block but other things have came up and I'm no longer able to follow this route. My goals for this combo are a reliable 450+ rwhp and mid-low 11's, let me know where you see anything that can be improved upon or changed and if my goals are realistic.
Basics:
'99 Z28
Pacesetter 1 3/4 longtube headers
Hooker Cat-back
Performabuilt 4L60E Tranny
3500 Stall
Stock 10 bolt
Engine Build:
Low mileage '04 LQ4
CNC'd L92 Cylinder heads milled to 65cc chambers (hoping to pump up the compression closer to 10:1)
LS7 Lifters
All ARP hardware Head/Rod/Crank bolt etc.
GM MLS head gaskets
ls6 oil pump
GMPP Carb style intake or Car Intake (still undecided on this)
Custom ground cam
Trying to keep the build somewhere around $4k. If you've got ideas on a cam profile to use let me know. I've already sold most of the turbo stuff I had and want to get started on this soon, spring is here and my car is still sitting in the garage not running
__________________
1999 Camaro z28
killerinparadise is online now   Reply With Quote
Old 03-28-2009, 08:11 PM   #2
Soul TKR's Avatar
Trader Rating: 4
Send a message via AIM to Soul TKR Send a message via Yahoo to Soul TKR
Quote:
Basics:
'99 Z28
Hooker Cat-back
3500 Stall
Stock 10 bolt
Engine Build:
Low mileage '04 LQ4
LS7 Lifters
GM MLS head gaskets
ls6 oil pump
Custom ground cam
why don't you mill the heads to 59cc instead of 65cc??? up that compression...
look at my build
Soul TKR is offline   Reply With Quote
Old 03-28-2009, 09:23 PM   #3
djsanchez2's Avatar
Trader Rating: 10
What head gasket did you use Soul?
I'm using 5.3 heads and a .40 gasket for 10.9:1 on mine, also using a slightly larger cam too. I'm shooting for 450hp to the wheels, but it will be carbed so it should make things a lil easier. 224/236 .612/.609 117+2
For the OP- the cam specs will differ depending on the intake used. The lift on the L92 heads will also be lower for clearance reasons because of the large valves.
__________________
www.Fquick.com/djsanchez2
"Spending money I don't have, to buy parts I don't need, to impress people I don't know!" - Grumpy Jenkins
djsanchez2 is online now   Reply With Quote
Old 03-28-2009, 09:32 PM   #4
sroach20's Avatar
Trader Rating: 31
make sure you prepare for the passenger side valve cover. your stock one will not clear without grinding the baffles because of the offset rockers. if you go car intake make sure you get the right extensions and plugs. the l76 you need to extend the map, ls3 you need an ls3 map and you need to extend/wire the new pigtail.
__________________
01 z28
"floats like a butterfly, stings like when i pee."
Peter Griffin
sroach20 is offline   Reply With Quote
Old 03-28-2009, 09:34 PM   #5
sroach20's Avatar
Trader Rating: 31
Quote:
look at my build
he would need to change the pistons to mill those heads to 59cc. i took .030 off and my ptv was right a close to the limit.
__________________
01 z28
Peter Griffin
Old 03-28-2009, 09:46 PM   #6
djsanchez2's Avatar
Trader Rating: 10
Not if you use 5.3 heads that come with a 59cc chamber Also depending on how bad the interference, he MIGHT be able to get away w/ a simple flycut.
__________________
Old 03-28-2009, 09:55 PM   #7
sroach20's Avatar
Trader Rating: 31
Quote:
but the 5.3s dont come close to the flow of some l92s.
__________________
01 z28
Peter Griffin
Old 03-28-2009, 10:14 PM   #8
djsanchez2's Avatar
Trader Rating: 10
Hell no they don't but they can be ported to flow ~300cfm if valve size is increased. Just don't see the point of using heads that huge on a stock bottomend if they come with compromises and restrictions.
Can mill them too much, Can go big boy cam, hard to get good compression numbers (11+) for a solid combo, thus can't really tap into the huge flow numbers anyways.
__________________
Old 03-28-2009, 10:20 PM   #9
sroach20's Avatar
Trader Rating: 31
they dont need a big cam to run, just the right cam. ive got a stock bottom lq4 and the l92s made it wake the hell up. its night and day difference between these and the 317s.
__________________
01 z28
Peter Griffin
Old 03-28-2009, 10:24 PM   #10
djsanchez2's Avatar
Trader Rating: 10
Hmmm cuz i was on the fence between the two and had a cam spec'd for both set-up and got these two stealth cams
Carbed LQ4, TH400, 9", 2800lb Nova wagon
P&P 5.3 heads w/ ls1 intake valves: 224/236 .612"/.609" 117+2
out of the box L92's: 218/230 .595”/.600” 116+3
__________________
Old 03-28-2009, 10:55 PM   #11
sroach20's Avatar
Trader Rating: 31
i havent even had a chance to really tune it (work and school). i cant wait to see how it does when i get everything dialed in.
__________________
01 z28
Peter Griffin
Old 03-29-2009, 12:17 AM   #12
Soul TKR's Avatar
Trader Rating: 4
Just the regular 6.0 LS2 Head Gasket... don't remember the actual specs on thickness...
Quote:
Really? I didn't have to change mine... the dished pistons that come in the LQ4 should give him enough clearance... course he didn't mention his cam specs, and i'm not that knowledgeable about the heads he's using so I don't know if that would make a difference compared to my setup...
Old 03-29-2009, 12:27 AM   #13
sroach20's Avatar
Trader Rating: 31
the exhaust had allot of clearance, but the gigantic intake valves on the l92s are what cut it close.
__________________
01 z28
Peter Griffin
Old 03-29-2009, 01:30 AM   #14
djsanchez2's Avatar
Trader Rating: 10
FYI the stock gasket is .051" thick and the dish on the piston is -6cc
And going off ur specs you should have a 10.8:1 compression Soul, not 11:1
__________________
Old 03-29-2009, 02:29 AM   #15
Soul TKR's Avatar
Trader Rating: 4
eh... it's what my builder told me... maybe i can get him to chime in. I'm really not knowledgeable in the whole compression reading thing to know
just being honest...
Old 03-29-2009, 03:08 AM   #16
LS1TECH Sponsor
Ryne @ CMS's Avatar
Trader Rating: 8
Send a message via AIM to Ryne @ CMS
with a 59cc chamber, 4" bore, .051" gasket w/ 4.065" bore, -6cc dish, plus with the pistons on his motor being .008" out of the hole i got his compression at 11.05:1
__________________
Ryne Cunningham
Cunningham Motorsports
Specializing In Late Model LSX Performance.
Lake Elsinore, CA
Shop: (951)471-2898
www.Cunningham-Motorsports.com/new
Ryne-CMS@Hotmail.com
Ryne @ CMS is offline   Reply With Quote
Old 03-29-2009, 12:59 PM   #17
Soul TKR's Avatar
Trader Rating: 4
Thanks Ryne
Old 03-29-2009, 02:01 PM   #18
djsanchez2's Avatar
Trader Rating: 10
I got everything else right though, dish cc, piston outta the whole, etc. Not questioning ur math, i'm just looking to make the same compression on my motor.
Oh i see, looks like the L92 gasket has a 4.065 bore. Did that replace the ls2 gasket?
__________________
Old 03-29-2009, 03:53 PM   #19
Trader Rating: 2
look at my build
I want to use the l92 heads because of their great flow numbers and plan to eventually use these heads on a 402/408 setup. I figured with a 65cc chamber they would still work well on my stock LQ4 and I'd be able to run flat tops and make around 11:1 on a 408 setup in the future without having to have the heads redone and worry about even worse ptv issues.
Thanks for the advice, so the stock valve covers can be made to work with the l92 heads? Or would it be easier to switch to a different style valve cover? Also what intake did you end up going with? I haven't looked to much into them. I'm thinking that the ls3 intake will be the best performing and easiest to swap and make fit under the hood but I'm not apposed to the GMPP Carb style intake.
I want to use the stock bottom end right now without having to flycut or pull out the pistons.
Glad to hear that, were your 317's milled and ported? How about your L92's, did you get them cnc'd or are they stock milled?
I know the Intake valve on the L92's are pretty massive and are what would cause ptv issues first. I'll be getting my cam spec'd to fit safely without having to flycut the pistons.
__________________
1999 Camaro z28
Old 03-29-2009, 04:03 PM   #20
djsanchez2's Avatar
Trader Rating: 10
I figured out what i was doing wrong on the calculator, i was putting the deck height as a positive number instead of a negative number DUH!! It comes out at 11.05:1 every time now.
__________________
Tags
3500, 408, 59cc, body, build, carbed, clearance, deck, engine, gasket, head, heads, lq4, ls1, piston, thickness
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
LS1TECH - Archive - Top
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Advertising - Terms of Service - Privacy Policy - JOBS
