Click here to visit LS1Tech
Click here to visit Performance Trucks
Click here to visit Mod Motor Tech
Click here to visit Modern Hemi
LS1Tech Wiki
LS1TECH
Go Back   LS1TECH > LS1-LS2-LS3-LS6-LS7 PERFORMANCE > Generation III Internal Engine
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into LS1Tech.com, click logo to login
1997-2006 LS1 | LS6
Sponsored by
Texas Speed & Performance
Old 09-11-2009, 03:27 AM   #21
Stocktonz28's Avatar
Trader Rating: 0
you could always resort to sabatauge. just go remove 1 of his exshust stems
__________________
2000 z28 A4 RS ground package/rims MTI airbox lid/K&n filter ans MTI mass air censor.
304RWTQ@4300 RPMS (Daily driver)
saving for an lt5 corvette zr1 5.7L DOHC with 375hp/tq
Tech in training...So if im giving out bad info please correct me and explain how i was wrong (this is good pratice for me) Thank you
Stocktonz28 is offline   Reply With Quote
Old 09-11-2009, 08:03 AM   #22
Trader Rating: 0
Send a message via Yahoo to garygnu65
ls3 with cam upgrade or 402 with L92 heads.ls engines are lite and the heads flow is great.
garygnu65 is offline   Reply With Quote
Old 09-11-2009, 08:31 AM   #23
1CAMWNDR's Avatar
Trader Rating: 19
Quote:
Originally Posted by Stocktonz28 View Post
if you got the cash build you a nice 383 stroker with a billet 400 small block crank nice billet dome pistons 2.400in intake valve 1.800in exshust vavle thats the partical details on the powerplant id build to take it down perhaps a 600/570 cam set up of course from billet steel
i know im not going to into detail but i feel lazy tonight lol
Uh, what?
1CAMWNDR is offline   Reply With Quote
Old 09-11-2009, 09:20 AM   #24
Trader Rating: 64
Send a message via AIM to adam1803 Send a message via Yahoo to adam1803
if you don't want nitrous, then forced induction is your best bet IMO.
__________________
2000 WS6, H/C/I 6.0
470/430 on motor
adam1803 is offline   Reply With Quote
Old 09-11-2009, 09:30 AM   #25
fortmyerspolice's Avatar
Trader Rating: 6
Send a message via AIM to fortmyerspolice Send a message via MSN to fortmyerspolice
418 ls3 with afr heads, custom spec cam, and a big turbo
__________________
01 Pewter WS.6 M6
226/230 .598 .600 113+4 PatG cam, PAC 1518's. Pacesetter LT's, custom ORY, Hooker catback, PTB, SLP lid, manual cutout, Mike Norris tune, Prothane motor, T/A mounts, 1le LCA's, UMI adj. PH bar poly/rod. Fidanza Aluminum Flywheel + 4.3 clutch, TICK master, sound deadened, strano springs, KYB AGX's. 410/386 to the wheels
fortmyerspolice is offline   Reply With Quote
Old 09-11-2009, 12:25 PM   #26
kinglt-1's Avatar
Trader Rating: 11
Quote:
Originally Posted by matt1289 View Post
He doesn't want Nitrous
fail
fail
sorry I just had to point it out
Why don't you provide some useful info, instead of trolling around posting Fail everywhere, assneck. I never said nitrous specifically. A lsx427 or 454 na should get the job done, the 150 shot was stated for extra measure. I seen the op does not want spray, but hey it's a cheap way to hand someone thier ass lol. the guy prolly has a power adder on his fox body to make it fast anyways, most do.
__________________
2002 Z28, 1SC, A4, 13k mi, Bolted, 3.73's, HSW dry plate w/ Nano.
2000 Buick GS, gutted oe airbox, 3.4 pulley, 3" down pipe w/ stock exhaust, tuned. 13.81@101 dd
2003 Silverado LS x-cab, 5.3, Airaid cai, 3.73's.
kinglt-1 is offline   Reply With Quote
Old 09-11-2009, 12:45 PM   #27
02SOMWS6's Avatar
Trader Rating: 5
build a LS3 stroker = poor mans 427 stroker. Should be good for low 10's NA with a stick set up right. You need to know more about the 460. It could be junk or a beast. I think it's gotta be worth putting it in the car so I'm leaning towards a beast.
http://schwankeshortblocks.com/Short...rt%20Block.htm
this would be a good start
__________________
Best track time-10.5 @ 130 with a 1.45 60ft.
Slowhawk tuned 473rwhp 407rwtq
10.6 pass http://video.ls1tech.com/video/f345e...3b0126a3be.htm
http://videos.streetfire.net/video/b...3b012749e1.htmhttp:/
GM hightech shootout photo's
http://www.gmhightechperformance.com..._trans_am.html
NBM 2000 convertable-under construction-6.0L
02SOMWS6 is offline   Reply With Quote
Old 09-11-2009, 04:03 PM   #28
transaman98's Avatar
Trader Rating: 7
Send a message via MSN to transaman98
f.i. is the way. Just build it to take a healthy amount of boost. Run him on low boost and if he beats you....more boost. Just makes it easier...not cheaper though.
__________________
Comp 224/230 .588/.592 114lsa,Hooker Longtubes-QTP ORY,4" QTP Cutout, Magnaflow Catback,LS6 Manifold, Stock Ported Heads, Comp 1.75's, Vigilante 3200, QA1 12ways all around w/ 275lb Springs up front and BMR out back, UMI SFC's, LCA's w/ relo. brackets, and a few other things.
TEA LS6 2.0's, 227/231 .614/.617 110+1, ss4000 awaiting install!
transaman98 is offline   Reply With Quote
Old 09-14-2009, 10:58 PM   #29
1997 Pontiac Trans Am
My Garage
ponyetr's Avatar
Trader Rating: 0
how big of a motor can i even drop in to my 2000 trans am with out hecking up my car i dont want to lose my stock stealth look
__________________
lt1 no more
ponyetr is offline   Reply With Quote
Old 09-14-2009, 11:59 PM   #30
2001 Chevrolet Camaro
MelScrilla's Avatar
Trader Rating: 2
Quote:
If you want to run all motor you can go 454 LSx, or with a little more money you could do a 496 Warhawk or a 500ci ERL block. With the last 2 you will have to run a intake spacer because they have taller than standard decks and you also will probably need custom headers. But check out the dyno section theres a 496 car in there that looks stealth.
You could do a 440 or 454 with a stroked LS7. You can pretty much run any ls block in your car without much modification to the car, maybe just modifying the motor mounts for the tall deck engines.
__________________
01 Z28- Magnaflow catback, A4, 4:10's, SLP Lid, more power coming soon......
94 Integra - daily driver
New Project: 275 Fox.......Details still in the works
MelScrilla is offline   Reply With Quote
Old 09-15-2009, 01:32 AM   #31
Pro_built7's Avatar
Trader Rating: 7
No, please go into details. I'd like to hear more about this setup.
__________________
1999 h/o z28, 4" vfn cowl, mti lid/k&n, umi short throw, hooker longtubes, true duals/ flowmaster super 40's, american racing torq thrusts/ sumitomo 315's.
-thanks Greg.
Last car down ! check it out ! (gallery pg. 15)
http://www.vfnfiberglass.com/site.htm
Pro_built7 is offline   Reply With Quote
Old 09-15-2009, 10:03 AM   #32
Chrome355z's Avatar
Trader Rating: 0
Quote:
I was thinking the same thing...
__________________
2002 Z28 A4
G5x2, Pacesetter LT/ORY, GMMG, P&P TB, SSRA, Lid, SS3600, 3:73. Tuned by Green Light Motorsports. 150shot in the works...
Chrome355z is offline   Reply With Quote
Old 09-15-2009, 10:21 AM   #33
wg871's Avatar
Trader Rating: 2
Think you could find another section to post in? The same thread posted 4 times in one day is a little excessive..
So before we can answer you question, what kind of budget are you looking at for this project "dream motor LS7 in a LT1"..
wg871 is online now   Reply With Quote
Old 09-15-2009, 01:01 PM   #34
BAD2000TA's Avatar
Trader Rating: 4
That's what I asked earlier as well!! Sounds more like someone that WANTS big power, but has no green to spend. We are all like that to an extent. So, op, just answer the questions and then we can give proper advise.
__________________
2001 Pontiac Trans Am WS6, 6-Speed - SCAT 4.00" forged crank, Mahle Pistons, SCAT H-beam rods, 383 cubes, '04 LS6 block, Comp Cams 224/230 cam, LS6 heads, Patriot Gold valve springs. Houston, TX USA
1980 Pontiac Trans Am - Y84 Bandit Edition, WS6 - 455 with #96 heads, 234/244 Wolverine cam, Dynomax headers
2008 Chevrolet HHR-SS. Soon with GMPP Stage 1 kit!
2001 Honda VFR - Micron exhaust
BAD2000TA is offline   Reply With Quote
Old 09-15-2009, 04:56 PM   #35
My Garage
ponyetr's Avatar
Trader Rating: 0
budget is still up in the air i im wanting to know what you guys would do and i posted four times in different areas to make sure i get alot of feed back and i and parts dealers and emc programmers would be nice
__________________
lt1 no more
Old 09-15-2009, 06:07 PM   #36
PowerShift408's Avatar
Trader Rating: 28
Send a message via AIM to PowerShift408
Look man, we can't give you any kind of definitive answer without knowing your budget and without knowing how that Mustang runs.
__________________
2001 NBM T/A ~ 408//4l80e//Moser 9" 10.60 @ 128
1999 HOSS ~ Torquer2//T56// Moser 12 bolt 11.83@ 116
2001 Subaru RSTi ~ EJ257//JDM RA 6-speed Times coming soon
My FQuick Garage
PowerShift408 is offline   Reply With Quote
Old 09-15-2009, 06:17 PM   #37
Trader Rating: 0
I would put my money on it that your friends Ford 460 powered car is still a slow ass piece of *beep*.
Without real info on the guys car and what it really has done to the engine....or track times...its anyones guess.
A stock LS1 might be able to beat it with bolt-ons. Or you might be dealing with a 650 RWHP N/A set-up.
All anyone here can really say is: Go build a 98mm single turbo 408ci LSX iron block and be sure you smoke him no matter what he has under the hood.
A better question would be: how can I build the best engine for my budget?
So....why not at least tell us EXACTLY how much money you have to spend?
__________________
1998 WS6 T/A 492 RWHP//495 RWTQ (w/cats)
LS6 427ci LPE short block, Ported stock TB, Ported LS6 intake, Ported LS1 heads, cam: 244/244 .610/.610 114 lsa, 1 7/8" Grotyohan LT's, 3" custom "Y" back to a Magnaflow Muffler, Built tranny...by a friend, Strange 12 bolt, 3.73 gears, Baer brakes, Hotchkis STB, LG Motorsports: Panhard Rod, LCA's, SFC's, G2 Super Springs, Hals all around, 315/rear, 275/front
Life may not be the party we hoped for, but while we're here we might as well DANCE.
LS6427 is offline   Reply With Quote
Old 09-15-2009, 09:24 PM   #38
HTX
HTX's Avatar
Trader Rating: 1
No one here can help you until you have goals.... IE what are you up against? Saying that he has a 460 in a foxbody doesnt mean anything. It could be a 13 second car or an 8 second car. Are you going to roll race this guy or drag him? Also we NEED to know a budget. If you have money to spend you could build a 427 pushing 1000hp N/A. If you are on a budget an Iron 408 is usually the budget favorite.
HTX is offline   Reply With Quote
Old 09-15-2009, 10:10 PM   #39
My Garage
ponyetr's Avatar
Trader Rating: 0
as far as the time being is $8,000 or less if i can get by with but u want the most horse for my buck and i want to shop around for parts. i wouldnt exatly be raceing on a track if you know what im mean
__________________
lt1 no more
Old 09-15-2009, 10:21 PM   #40
Trader Rating: 1
A fox is very light and without knowing what is done to the BBF you are flying blind until you know what you are up against. I have a mud race a truck with a 572 BBC that has dart heads pulling a little over 1000hp. I run against some trucks that has BBF engines and they have potential. Typically, there are about 50 to 100 hp below my engine. It is like any other engine, it just depends on the parts. His motor on pump gas, could be anywhere from 450fwhp to 800fwhp. You have to know what you are dealing with before you go after him. If you can find out what heads are on it, I can give you a general idea about what you are up against. Without knowing what he has, it's a guessing game.
peedeerooster is online now   Reply With Quote
Tags
10, 460, big, block, camshaft, chargeing, dyno, engines, ford, kits, lsx, na, nitrous, stroker, turbo
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
LS1TECH - Archive - Top
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Advertising - Terms of Service - Privacy Policy - JOBS
