Click here to visit LS1Tech
Click here to visit Performance Trucks
Click here to visit Mod Motor Tech
Click here to visit Modern Hemi
LS1Tech Wiki
LS1TECH
Go Back   LS1TECH > LS1-LS2-LS3-LS6-LS7 PERFORMANCE > Generation III Internal Engine
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into LS1Tech.com, click logo to login
Old 10-21-2009, 03:44 AM   #1
Trader Rating: 0
Default Questions about the LQ4 motor.
First being, will pre-04 LQ4 motors bolt up to the 4L60E? I heard once from someone that they wont due to a spacer in the flywheel/crank.
Secondly, What is the deal with the LQ4 heads? Are they LS1 heads? If not then are they any better than LS1 heads? I believe their Compression is lower than LS1's so they're probably not the same heads, that or the pistons arn't the same. Why are they rated 25 HP less than the LS1 when its supposedly the same motor only in cast iron?
Third, What would be a budget complete N/A build for 450 RWHP out of a LQ4? What kind of heads / cam would you recommend?
Need4Camaro is offline   Reply With Quote
Old 10-21-2009, 11:40 AM   #2
1995 Pontiac Trans Am
ORedRoc4's Avatar
Trader Rating: 12
Send a message via AIM to ORedRoc4
Ill take a stab at this:
#1: There isn't a spacer, but the crank sealing lip is a bigger/wider than the '04 up (For some reason i thought it was '03 up)
#2: You are right, compression, compression, compression. You can mill the heads to get that extra oomph that lacks the LS
#3: Not to sure as i have no real world experience with them. However I was researching LQ's before i found my LS1. With that being said, I read that the 5.3 head flow 300+/CFM in stock form and make for excellent stock heads to throw onto the LQ4. As for a cam, you'll have to decide what else you want from it...
-Someone correct me if I am wrong...
-Justin
__________________
1996 Camaro Z28 CRM
'03 Vette Ls1 swap in progress, Tubular K-Member, Poly bushings, more parts on its way...
1995 Pontiac Trans Am Dark Silver/Black
LT1, LT's, ORY, Magnaflow Catback, poly bushings, lowered, KYB's, The New DD
ORedRoc4 is offline   Reply With Quote
Old 10-21-2009, 01:48 PM   #3
Trader Rating: 0
-Justin
I see, so LQ4's prior to 03/04 will NOT bolt up to the 4L60E correct? What about the T56?
What are the specs between the LS1 and LQ4 heads? Will LS3 heads make for a good replacement on the LQ4 followed with a mild cam?
Old 10-21-2009, 02:06 PM   #4
2002 Chevrolet Camaro
Trader Rating: 0
Actually I have an 02 LQ4 in my Camaro and my 4L60 bolted right up, only some of the engines had a larger lip on the back of the crankshaft. This is just one of the things to look for when you go looking at these engines. The 6.0 heads (casting 317 iirc) have larger combustion chambers then LS1 heads (casting 241,853) but the LQ4 also has dished pistons being the only difference between an LQ9 (flat-top pistons) and LQ4.
LS3 heads would be a great option, but would need milled considerably to get the compression up and you'd still be at a loss due to the dished pistons. Keep in mind that the LS3 heads will require different rocker arms, and intake manifold so this may not be as budget minded as you might want. When I build mine I swapped out the pistons for some Mahle flat-tops to get compression up and used the LS1 heads I had laying around. With the TSP 233/239 cam I put 420hp down to the wheels everthing else being pretty stock.
__________________
02 Z28, forged LQ4, built 4l60, current best of 11.08, but I haven't had this engine to the track yet
ND2RACE is offline   Reply With Quote
Old 10-21-2009, 06:13 PM   #5
Trader Rating: 0
I see. LS1 Heads it will be in that case. Did you change the valve springs for that cam or are your heads completely stock? The only problem is the LQ4's I'm looking at are all on Ebay so there's no way I would be able to tell if they would have the larger lip or not, in fact I wouldn't even know exactly what the larger lip looks like as I've never seen the smaller lip lol. I still think an LQ4 would be a much better choice than an LS1 due to the slightly cheaper price and larger displacement. Where did you get your LQ4 block and how did you know the difference in the lip size?
Old 10-21-2009, 06:13 PM   #6
Trader Rating: 0
The 317 heads on the LQ4 and LQ9 are based off the LS6 head with larger combustion chambers. They flow pretty much identical to the LS6 heads which are a step above the LS1 heads. Because of their larger chambers they're one of the best picks for forced induction applications.
ss454327 is offline   Reply With Quote
Old 10-21-2009, 07:31 PM   #7
OUTLWZ's Avatar
Trader Rating: 0
Its the 99-2000 LQ4's that use the spacer, 01+ will work just fine.
__________________
2001 Z28 6.0-LQ4, ASA cam, SLP Lid, LS6 Intake, Circle-D 3200, Pacesetter LT, O/R Y-pipe, Magnaflow CB
OUTLWZ is offline   Reply With Quote
Old 10-21-2009, 08:20 PM   #8
Trader Rating: 54
Send a message via AIM to adam1803 Send a message via Yahoo to adam1803
Quote:
Thats correct, the 01+ lq4's do have a spacer though if it was mated to a
4l80e transmission, but it comes right off, where as the earlier ones it was cast into the crank.
__________________
2000 WS6, H/C 6.0 and a little shot of gas.
470/430 on motor
adam1803 is offline   Reply With Quote
Old 10-22-2009, 04:42 AM   #9
Trader Rating: 0
Quote:
What about running N/A? What would be a good cam choice to run with these? I MIGHT go forced induction but it will be much later and most likely just a procharger so I want a N/A cam for now. - Also will I need to replace the valve springs?
Old 10-22-2009, 09:35 AM   #10
Trader Rating: 0
You'll have to change valve springs with any cam you put in, other then that yes the heads are stock. I forget the measurements but if you've seen the back of an LS1 the larger lip is pretty obvious. The only other thing I had to do was drill and tap a hole in the front of the block for the alternator bracket, as trucks use a different accesory drive (but this is a really easy fix). I got my LQ4 block and crank off of another member here on LS1tech, just kept watching the for sale section. Unless you are going forced induction, I'd be milling down the 6.0 heads or putting on LS1 or LS6 heads. Everything will just work out for the better by at least getting compression up to 10:1, off the shelf LS1 cams are designed for this.
I think you're on the right track, LS1s are a great engine but I'd go the iron 6.0 route again. Besides if you use the stock bottom end in a LQ4 you'll easily get a couple rebuilds out of an iron block, just not the case with an LS1 you'd be lucky to get one.
__________________
Tags
400, 4l60e, 53, bolt, compression, crank, heads, lq4, ls6, motors, number, procharger, replacement, specs, throw, transmission
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
LS1TECH - Archive - Top
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Advertising - Terms of Service - Privacy Policy - JOBS
