Click here to visit LS1Tech
Click here to visit Performance Trucks
Click here to visit Mod Motor Tech
Click here to visit Modern Hemi
LS1Tech Wiki
LS1TECH
Go Back   LS1TECH > LS1-LS2-LS3-LS6-LS7 PERFORMANCE > Generation III Internal Engine
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into LS1Tech.com, click logo to login
1997-2006 LS1 | LS6
Sponsored by
Texas Speed & Performance
Old 09-19-2008, 03:23 PM   #1
1SWT95Z's Avatar
Trader Rating: 0
Default MS4 & HPE Mega Death Camshaft questions/suggestions
Ok I'm looking to buy an LS1 car soon (a 98-02 SS). At my work we have CNC'd LS6 heads avaliable, so I'm planning to get a set of those. So my question is what is everyone's expierence with stock short blocks and big duration cams. I'm looking at the MS4 cam(magic stick 4) or the HPE megadeath cam. I've heard depending on the duration, you'd need to fly cut the pistons. That would be no problem. Does anyone out there have either of these two cams and CNCd heads with a manual trans? If so what kind of chassis dyno numbers did you make. Ideally I would run mid tube or long tube headers and GMMG or Hooker catback. What other mods would you guys recommend? Air lid? MAF? TB?Thanks for the help.
__________________
1SWT95Z- A4-355ci, heads,cam,headers,etc.. 336rwhp/325lbs/ft tq.
1SWT95Z is offline   Reply With Quote
Old 09-19-2008, 03:26 PM   #2
s346k's Avatar
Trader Rating: 2
trex with those heads milled to 59cc and flycut pistons, ported & portmatched vic jr with accufab 105mm tb and long tubes. looking at 500+ through an m6 10 bolt car.
__________________
99 WS6 M6
89 Firebird
s346k is online now   Reply With Quote
Old 09-19-2008, 03:39 PM   #3
Johnnystock's Avatar
Trader Rating: 3
MS4 you have to fly cut yes..what spec on the hpe cam? sounds scary...
humm, good luck with the 500rwhp goal...hope you have every supporting mods in the world and the typical dynojet. Anyway, the car will pull tih that T-rex whatever the dyno number!
__________________
1998 SS
juiced H/C/I
Originally Posted by sprapsu
How do I activate the turbo in my car? Is there a turbo boost button I need to press? I tried locating the turbo boost button but can't seem to find it anywhere.
Can anybody in here help??
Johnnystock is offline   Reply With Quote
Old 09-19-2008, 05:01 PM   #4
BIGB4015's Avatar
Trader Rating: 0
The megadeath specs are in sig. Great cam lots of power up top. The clearence is tight with 243 heads you will have to flycut with milled heads.Its around .40-.50 cold with the stock deck height and stock head gaskets.There is a new big boy cam by tick performance called the polluter the spec are 240's duration and lift over .600 on 112lsa.The specs are not given but it seemes to make about 30rwtq more than my megadeath on pretty much the same setup ls6 intake+boltons and it has a little more clearence than the megadeath.Sounds like a good stock bottom end cam for max power!
__________________
04 YJ M6
HPE MEGADEATH 244/242 .612 .610 112
COMP DOUBLE ROLLER
PACESETTER 1 3/4 CATLESS MIDS
POWERBOND UD PULLY,PORTED & POLISHED TB
NEW ERA CAI, MSD WIRES, NGK TR55, SLP 160 STAT
CENTERFORCE, HURST SHIFTER ,HWS PLATE
BIGB4015 is offline   Reply With Quote
Old 09-19-2008, 05:04 PM   #5
BIGB4015's Avatar
Trader Rating: 0
The ms4 on 112 lsa will fit a stock bottom without fly cutting.
__________________
04 YJ M6
COMP DOUBLE ROLLER
Old 09-19-2008, 05:41 PM   #6
Gordon0652's Avatar
Trader Rating: 3
Send a message via AIM to Gordon0652
Quote:
__________________
2000 Maple Red Metallic Trans Am A4, Grandfather Left It To Me
LME 440 LS7|PRC LS7|246 258 .675" .657" 114|60lb Siemens|ARP
2006 Trailblazer 3SS AWD Tuned Winter Car||2008 Acura TL Type-S
Gordon0652 is offline   Reply With Quote
Old 09-19-2008, 05:47 PM   #7
BRAKE's Avatar
Trader Rating: 10
MS4 on a 111 will too
__________________
2002 Trans Am
PRC 215 heads 59cc/MS4/FAST 92/92/shit-ass longtubes/NX 150 shot/GMMG
1997 Grand Prix GTP
Bolt ons.
BRAKE is offline   Reply With Quote
Old 09-19-2008, 06:08 PM   #8
b00sted's Avatar
Trader Rating: 7
That's scary.
b00sted is offline   Reply With Quote
Old 09-19-2008, 06:19 PM   #9
Trader Rating: 3
my bad, thought you had to with cnc ls6 heads; confused with 5.3l heads..ok then next year I'm going MS4
__________________
1998 SS
juiced H/C/I
Old 09-19-2008, 10:24 PM   #10
BIGB4015's Avatar
Trader Rating: 0
.PRC stage 1 heads are the best bang for the buck. They are stock deck height and stock valve size and still flow 305@.600 and price out for about a grand. These heads work great for both cams.I will be adding these heads to my megadeath for my next mod I am expecting 30+ over my stock 241s.The stage 2 ls6 heads run bigger valves and clearence becomes a problem.
__________________
04 YJ M6
COMP DOUBLE ROLLER
Old 09-23-2008, 12:22 PM   #11
1SWT95Z's Avatar
Trader Rating: 0
Thanks for the replies guys. So bascially I'll be running CNC'd 4243 castings, an LS6 manifold, stock TB and headers&catback and stock bottom end.With these mods does anyone know if the stock injectors will work? In reality, are the megadeath and MS4 going to run about the same? Does anyone out there have either one of these cams with stock exhaust manifolds? I live about 10mins from Tick Performance but havn't spoken to them about their poulliter cam yet. I'm going to be building on a budget(because the wife says so) so I'd like to get the best "big" cam for stock bottom end and limited mods. If either of these cams will run like crap with only the CNCd heads and LS6 intake with only headers and catback, then would a smaller cam work better? Thanks
__________________
Old 09-23-2008, 01:03 PM   #12
BIGB4015's Avatar
Trader Rating: 0
I would go talk to tick performance about that new cam if you only live 10 min away.
__________________
04 YJ M6
COMP DOUBLE ROLLER
Old 09-23-2008, 04:04 PM   #13
fauslpss's Avatar
Trader Rating: 6
Peak flow #'s on heads arent a concern for most of us that run LS6 or FAST intakes since they dont flow over 270cfm. .200-.500 are the area we need to look at.
You might want to look at the cam I'm getting. PM since hes not a sponsor. It made the same HP as the streetsweeper but made 35 more TQ at 3000.
All the big cams are going to suck down low I would consider talking to someone and let them know your goals so they can better lead you in the right direction.
Eric
__________________
2001 NBM M6 SS dyno #'s 325hp 336tq
1/4 #'s 13.18 @ 108.56 2.18 60ft
Mods: SLP lid and CME, pro 5.0, More in the making!
"I feel like this "Road to Recovery" is paved with yellow bricks and has evil monkeys flying above it."-Vincent Merlino
fauslpss is offline   Reply With Quote
Old 09-23-2008, 04:09 PM   #14
fauslpss's Avatar
Trader Rating: 6
The streetsweeper car had a home ported FAST 78mm, 1 7/8 ARH's and made 420hp 389TQ
The cam he spec'd me made 420hp 386tq but it had a LS6 intake with a ported TB and 1 7/8 headers.
Eric
__________________
Old 09-23-2008, 08:40 PM   #15
1SWT95Z's Avatar
Trader Rating: 0
thanks again for the help. anyone out there know what lt1 head/cam (car is an 8.5 out of 10 in condition) camaros have been selling for?
__________________
Old 09-24-2008, 10:19 AM   #16
LS1TECH Sponsor
Jason 98 TA's Avatar
Trader Rating: 3
The MS4 is the result of tons of design & dyno testing time. We've dyno tested so many different large camshafts next to the MS4 & it constanly does very well. Here's a dyno sheet from before & after MS4 on a stock setup.
Baseline
http://www.precisionracecomponents.com/stock.jpg
Magic Stick 4
http://www.precisionracecomponents.com/ms4.jpg
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Jason 98 TA is offline   Reply With Quote
Old 09-24-2008, 11:55 AM   #17
silverbandit0996's Avatar
Trader Rating: 2
Send a message via AIM to silverbandit0996
Quote:
Baseline
Magic Stick 4
wow that car picked up almost 100 hp.
__________________
2002 SSM Trans Am M6. L/T's, 2.5" T/D's with hi-flos single chambers and h-pipe dumped, lid, 150 wet shot.
silverbandit0996 is offline   Reply With Quote
Old 09-24-2008, 12:25 PM   #18
fauslpss's Avatar
Trader Rating: 6
The MS4 doesnt make more power till 4500rpm thats over a stock cam. 1 reason why I dont understand the trend towards BIG cams. For a street car thats around 3600lbs its going to be a dog down low.
It picked up 95hp but only gained 18ftlbs.
Eric
__________________
Old 09-24-2008, 01:41 PM   #19
ZFSix's Avatar
Trader Rating: 13
Send a message via AIM to ZFSix
I picked up 126rwhp and 70rwtq with full bolt ons, fast 90, NW 90, 1-3/4" long tubes and the Megadeath cam.
I have both dyno graphs I can post up once I get home if I remember. 310rwhp bone stock and 436rwhp/400rwtq with the above mods. Did not need to fly cut the pistons but I will say get a stronger timing chain...
__________________
It's not because he is BLACK. It's because he is RED.
ZFSix is offline   Reply With Quote
Old 09-24-2008, 01:44 PM   #20
ZFSix's Avatar
Trader Rating: 13
Looking at that engine dyno for the MS4, the Megadeath makes much more torque. 440 at the motor equates to around 374 to the wheels, my car dyno'd 400 at the tires which is about 470 at the motor. Unfortunately I never got any track times before the stock timing chain split in half, but it did run very strong on the street.
I came from a 224/230 cam, ls6 intake, ported TB to what I just mentioned.
__________________
Tags
04, 53l, cam, death, dyno, exhaust, heads, hpe, magic, mega, megadeath, ms4, prc, sheets, spec, stick, stock
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
LS1TECH - Archive - Top
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Advertising - Terms of Service - Privacy Policy - JOBS
