Click here to visit LS1Tech
Click here to visit Performance Trucks
Click here to visit Mod Motor Tech
Click here to visit Modern Hemi
LS1Tech Wiki
LS1TECH
Go Back   LS1TECH > LS1-LS2-LS3-LS6-LS7 PERFORMANCE > Generation IV External Engine
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into LS1Tech.com, click logo to login
Old 11-06-2009, 08:18 PM   #1
Trader Rating: 1
Default anyone make aftermarket L-92 head
i need a set of L-92 heads. i bought a beck sheetmetal intake but they are built for L-92's. the only problem is that its going on a 434 with f1-r around 18 lbs. they said the deck was to thin to put gm heads on it what other heads will work with this
charged 434 is offline   Reply With Quote
Old 11-07-2009, 03:28 PM   #2
formula17's Avatar
Trader Rating: 2
Check out the Mast "Black Label" Heads MastMotorsports.com. They have a new 12 degree LS3/L92 head has thicker then stock decks on it.
Nick
__________________
93 Formula 02 front end conversion with Superhawk Hood-427CI, CNC'D L92'S+ A 200 Shot, In The Works! Looking for 9'S!!
"When This Baby Hits 88mph, You're Gonna See Some Serious Shit"
formula17 is offline   Reply With Quote
Old 11-07-2009, 10:02 PM   #3
Trader Rating: 1
thanks will call them monday
Old 11-08-2009, 01:01 PM   #4
Trader Rating: 0
For as much as your goinf to spend on the MAST heads, Id just go ahead and get a set of All Pro heads.....
What are you looking to spend?
__________________
Quote:
Originally Posted by John Lingenfelter
The world's best cam combined with a poor set of heads will produce an engine that's a dog. But bolt on a set of great heads even with a poor cam, and that engine will still make great power.
SweetS10V8 is online now   Reply With Quote
Old 11-17-2009, 09:42 PM   #5
1CAMWNDR's Avatar
Trader Rating: 19
Either way you go, Mast LS3/L92 or All Pro Cathedral you are going to need an intake manifold to keep up with them. And no, just throwing a FAST on there will not be adequate.
__________________
Mike
'99 Formula NBM hardtop 6-speed with a big heart transplant. Well WOT on BFG T/A KD tires is useless after 4500 rpm in 1st, 2nd, and 3rd. Guess the rest of my street tuning will be done on the slicks.
1CAMWNDR is online now   Reply With Quote
Old 11-17-2009, 10:27 PM   #6
Trader Rating: 0
What about LS9 heads? They are L92/LS3 style heads that obviously take boost?? Could you have someone CNC them for you?
__________________
Old 11-18-2009, 09:10 AM   #7
10 & 11 Second Club
Caveman's Avatar
Trader Rating: 2
Quote:
The Fast LS3 102 intake flows very good and I'm sure it will be adequate for the big cfm cylinder heads I'm about to get. The Mast heads dont flow any better then WCCH or PRC ported LS3 heads the only advantage would be the thicker deck which would be great for a 300- 400 shot or 20lbs of boost.
Dave
Caveman is offline   Reply With Quote
Old 11-18-2009, 07:39 PM   #8
Trader Rating: 1
the intake is a sheetmetal intake made by beck. it should flow enough. i know i will have 4500 in the heads with rocker arms with the mast heads . damn things are expensive
Old Yesterday, 12:07 PM   #9
1CAMWNDR's Avatar
Trader Rating: 19
Quote:
Right on.
__________________
Mike
Old Yesterday, 02:42 PM   #10
Trader Rating: 0
Yeah true story man i have TSP Ls3 heads they pull strong N/A from 3500 to redlind but my curve is really flat with a stock L/76 on it. I really need a vic jr. and a 4 barrel TB to keep up with the heads an cam cuz it's so big. I'd going with the Ls3's milled out.
LSWNDR is offline   Reply With Quote
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
LS1TECH - Archive - Top
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Advertising - Terms of Service - Privacy Policy - JOBS
