Click here to visit LS1Tech
Click here to visit Performance Trucks
Click here to visit Mod Motor Tech
Click here to visit Modern Hemi
LS1Tech Wiki
LS1TECH
Go Back   LS1TECH > LS1-LS2-LS3-LS6-LS7 PERFORMANCE > Generation IV Internal Engine
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into LS1Tech.com, click logo to login
Old 10-23-2009, 02:51 PM   #1
Trader Rating: 0
Post Hp numbers for 438 ci. L92
I would like to hear some HP numbers for the following engine:
LQ9 2000 yr bored .10 over
eagle 4.200 in. crank, rod journal turned down
eagle 6.125 Honda rod journal
Weisco 11.70 compression
WCCH L92 heads ,compcams LSR valvesprings
Comp cams LSR 251/267 .624/.624
Comp cams short travel lifters
Yella terra 1.8 shaft mounted rockerarm
Elderbrock L92 intake Dr. J ported
Race Deamon 825 annular boosters
andrelossem is offline   Reply With Quote
Old 10-23-2009, 04:21 PM   #2
Trader Rating: 0
570-580 RWHP...M6
But don't you need at least 4.1" bore to use L92 heads?
__________________
1998 WS6 T/A 492 RWHP//495 RWTQ (w/cats)
LS6 427ci LPE short block, Ported stock TB, Ported LS6 intake, Ported LS1 heads, cam: 244/244 .610/.610 114 lsa, 1 7/8" Grotyohan LT's, 3" custom "Y" back to a Magnaflow Muffler, Built tranny...by a friend, Strange 12 bolt, 3.73 gears, Baer brakes, Hotchkis STB, LG Motorsports: Panhard Rod, LCA's, SFC's, G2 Super Springs, Hals all around, 315/rear, 275/front
Life may not be the party we hoped for, but while we're here we might as well DANCE.
LS6427 is offline   Reply With Quote
Old 10-23-2009, 04:26 PM   #3
Trader Rating: 2
4.1=ls7 4.0=ls3
__________________
98 Trans Am
ls3, g6x3!
t/a98 is offline   Reply With Quote
Old 10-23-2009, 04:37 PM   #4
Trader Rating: 0
Quote:
Originally Posted by t/a98 View Post
4.1=ls7 4.0=ls3
LS7 = 4.125 stock....right?
4.0 = LS3.........but if he goes .10 over to 4.010, will the L92 head work?
If he's doing a 438ci and using a 4.2 stroke, the bore has to be about 4.060 to make 435ci.
__________________
Old 10-23-2009, 04:54 PM   #5
1998 Pontiac Firebird
TT632's Avatar
Trader Rating: 3
Quote:
Originally Posted by LS6427 View Post
570-580 RWHP...M6
4" bore is what is needed.
__________________
TT632's Vehicles: 4th gen SOM Formula, 1068 RWHP
05 Avalanche. 02 GMC 1/2 Ton
87 Olds 442 60k all orig. 280Z 350 sbc.
05 POS Rav4.
"Crap! GM's going down the tubes and I still can't get a good deal on a new Camaro!"
TT632 is offline   Reply With Quote
Old 10-23-2009, 05:06 PM   #6
Trader Rating: 0
Quote:
Oh OK.
__________________
Old 10-23-2009, 05:07 PM   #7
VortecHOjunkie's Avatar
Trader Rating: 5
Your compression height on your piston is going to be very small. Hope you don't plan on any power adders. I would think you would need to run an aftermarket block for that much stroke.
__________________
1999 White RCSB silverado
2003 GSX-R 1000 (sold)
VortecHOjunkie is offline   Reply With Quote
Old 11-05-2009, 01:47 PM   #8
danhr's Avatar
Trader Rating: 16
335 hp
__________________
1997 Z28: iron block, cam, ported gm casting heads, edelbrock intake, moser 9"....
danhr is offline   Reply With Quote
Old 11-05-2009, 02:00 PM   #9
LS1Tech Sponsor
Trader Rating: 4
LS3/L92 = 4.065-4.068 bore - maybe what you were trying to say?
or
LS2 = 4.00 bore?
John@Scoggin is offline   Reply With Quote
Old 11-05-2009, 02:16 PM   #10
Trader Rating: 0
Quote:
or
LS2 = 4.00 bore?
A stock LS2 is 4" bore? oh, ok.
__________________
Old 11-05-2009, 06:08 PM   #11
melsie68's Avatar
Trader Rating: 1
Quote:
Yes the compression height would be shallow at 1.015 but there are many SBC engines running around with 1.000" pin height to use a 4.000" stroke and 6.000" rod in a stock 9.000" deck height block. The typical engine combo would be a 427-434cid. I understand the ring life will be shortened and oil control reduced. But I have never built that combo so I cannot say from experience.
Many will say not to use more than a 4.125" stroke with a 6.0L block due to the cylinder length. I wonder if anyone has some experience with a 4.200" stroke and one of these blocks. The smaller 1.888 Honda rods will certainly help with block clearance and rod to cam clearance. I would strongly consider the fact that ALL the heat treating of the crank journal on the rod throws will be gone when it is turned down .212". The crank should be re-heat treated after it is turned down. But that will become an expensive crankshaft once you consider the work to have it turned down and then heat treated again. Not to mention most will think it is crazy to spend that kind of money on an Eagle crankshaft.
__________________
1968 SS Camaro, tagged, insured
pump gas LS stroker 404cid
th400, 3.89 gear, drag radial, footbrake
10.110 @ 133.49, 1.455 60'
melsie68 is offline   Reply With Quote
Old 11-05-2009, 06:13 PM   #12
LS1Tech Sponsor
Trader Rating: 4
The cam tunnel is not open as such to warrant any issue from the rods hitting them like on the regular SBC engines. Translation: no small base circle cams just because you want to use a long stroke/rod or an offset rod ratio.
I would def go with something of better repute for that build than an eagle IMO. IIRC we can get callies to grind the rod journal and rough or total balance the crank before it is shipped.
Old 11-05-2009, 06:29 PM   #13
melsie68's Avatar
Trader Rating: 1
The cam tunnel is not open to warrant any issue from the rods hitting them like on the regular SBC engines. Translation: no small base circle cams just because you want to use a long stroke/rod or an offset rod ratio.
Any comment on the cylinder length John?
What would you call that underside area beneath the cam in an LS block anyway?
__________________
Old 11-05-2009, 06:31 PM   #14
LS1Tech Sponsor
Trader Rating: 4
Man it is hard to say. I would say the amount of piston coming out and the possible amount of rock from that iron block would more than shy me away from trying to do it without some sleeve to make sure itll work right. Thats alot of real estate
If i were to guess on parts, i would call that the arm pit...lol.
Old 11-05-2009, 06:37 PM   #15
melsie68's Avatar
Trader Rating: 1
I would be hesitant as well just based on the ground work laid out by others that have done the longer 4.125" stroke combos in stock GM blocks. Now assume we are talking about a block with a longer sleeve/cylinder in it, what would you say is the max stroke would be before we see interference with that "underside" arm-pit area below the camshaft tunnel? And let us assume stock LS/SBC rod journals of 2.100".
(Don't mean to hi-jack here but this discussion may be relevant to the build.)
__________________
Old 11-05-2009, 06:44 PM   #16
LS1Tech Sponsor
Trader Rating: 4
Had to edit my post. The tunnel is open but not as such that is causes a problem like the SBC did when say using a long rod 406 (that is what i meant). but as in the LS7/LSX block you could run up to a 4.250 stroke (we build a 468 LSX with a 4.185 * 4.250 stroke) and not have a problem with the standard large pin 2.100 rods. If you want to run more or are having questions, then maybe the small journal would be better fitted but it is just at 2" or the honda journal then. Realistically anything longer than that would take the warhawk probably or the RHS (if its out) the Dart Billet or the LSX tall deck (when it comes out). To try and build that many more CI out of a standard deck is reaching the limits of what even the LSX can do at the moment
Old 11-05-2009, 07:37 PM   #17
melsie68's Avatar
Trader Rating: 1
Good stuff John! Thanks for the info.
__________________
Old 11-07-2009, 01:32 PM   #18
LS1Tech Sponsor
racer7088's Avatar
Trader Rating: 0
I don't think those heads are that good on such a small bore either but they could work. Your other stuff seems alright. You probably can't really make a piston work in that deal for any kind of street type engine though and no power adders.
__________________
Erik Koenig
School of Automotive Machinists
HK Racing Engines
racer7088 is offline   Reply With Quote
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
LS1TECH - Archive - Top
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Advertising - Terms of Service - Privacy Policy - JOBS
