Click here to visit LS1Tech
Click here to visit Performance Trucks
Click here to visit Mod Motor Tech
Click here to visit Modern Hemi
LS1Tech Wiki
LS1TECH
Go Back   LS1TECH > LS1-LS2-LS3-LS6-LS7 PERFORMANCE > Generation IV Internal Engine
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into LS1Tech.com, click logo to login
Old 10-27-2009, 01:00 PM   #1
GC99TA's Avatar
Trader Rating: 14
Default Anyone had the heads off an LY6 yet?
I'm just wondering about the LY6 piston tops. I've read that they have flat tops with no valve reliefs, but I also read that the SCR is only 9.67:1.
Doing the quick math with the info above and assuming the pistons are at least .005 out of the hole, I come up with about 10.33:1.
So, I have to assume the pistons either have about 6cc's worth of valve relief, or are down in the hole (.025 or so), or a lesser combination of the two.
I have a 2008 LY6 sitting in my garage for my conversion project and I'm curious to find the truth about the SCR/pistons......just not curious enough to pop the heads off and look/measure myself if someone else has already had one apart. Any pics or actual measurements taken would be great. Thanks!
FWIW, here are the "assumptions" I used to calculate the SCR:
Chamber volume: 70cc
Piston head volume: 0cc
Gasket thickness: .051in
Gasket bore diam: 4.083in
Cylinder bore diam: 4.000in
Deck clearance: -.005in
Stroke: 3.622in
__________________
MY SITE
99 Trans Am M6
AFR 205 Heads, Comp 230/232 cam, Mamo Ported FAST 92/NW 92, Speed Inc Rails, 42LB SVO Injectors, Racetronix Pump, Fast Toys Lid, FTRA, Dual Stage Dry Kit, 160* stat, ASP pully, FLP LTs, Borla Cat-Back, B&M Ripper, SPEC Stage 3 Clutch, Moser 12 Bolt W/4.11s, Dennys N2O DS, D&D Viper Spec T56, BMR K-Member, SFCs, LCAs, LCARLBs, DSL, Trq Arm, and APHR, QA1's, Welds, 27in QTPs.
73 Camaro RS - Carb'd LSX Swap in progress....
GC99TA is offline   Reply With Quote
Old 10-28-2009, 01:16 PM   #2
Trader Rating: 0
I'm interested also if someone has a parts and specification breakdown. The junkyard ly6's are fairly reasonable and I've seen new crate ly6's at $3000 to $3500.
Thanks
James
Casimirblue is offline   Reply With Quote
Old 10-28-2009, 03:06 PM   #3
GC99TA's Avatar
Trader Rating: 14
Quote:
Thanks
James
Yeah, the junkyards really don't expect to sell many of them just yet because most vehicles orginally equipped with them are still under warranty. They don't realize that these are a great swap candidate for someone like me since they're an iron block, 4 inch bore motor with factory L92 heads. FWIW, I picked mine up for $1800.00 with less than 3000 miles on it. Came out of a 2008 Fed Ex van that got totaled out.
__________________
MY SITE
99 Trans Am M6
Old 10-29-2009, 06:33 PM   #4
GC99TA's Avatar
Trader Rating: 14
Well, I just refined my search terms a little better and it appears most are saying the LY6 pistons do have exhaust valve reliefs, but not intake valve reliefs.
That pretty much answers my question on why the compression is what it is, but I would still like to hear from anyone that has actually cc'd the valve pockets and/or measured how far the LY6 piston is out of the hole, just so I know if my other assumptions/calculations are correct. Thanks a lot.
__________________
MY SITE
99 Trans Am M6
Old 10-29-2009, 10:36 PM   #5
PwrdbyLS1's Avatar
Trader Rating: 1
I had the same question because I will run my LY6 1-2 years before I build my 408 and i've read 9.9:1 compression. But I have remove one head and the pistons are dish and have 2 notchs...
here's picture I've take
the dish have a diameter of 3" and a depth of 0.050 so .35cu in.. in cc(cubic centimeter?) 5.78cc
So around 6cc + 2cc for the notch... -8cc piston.. we are far from the flat top we have read...
And my piston are a bit over the deck... maybe .005"
Hope its helping you !
__________________
99 Camaro SS M6 - 346 LS1(RIP) -> PRC 5.3L stg 2.5, Torquer 2, LS6 ported oil pump, LS2 Timing set, Powerbond pulley, Katech rod bolts, SLP Lid, Ported TB, LS6 Intake, ARH Headers & Catted Y, Tex OZ700 Z grip, Hurst billet plus shifter, Moser 9in & 4.11s, BMR LCA with Relo. Brackets & PHB, UMI TA & Relo. Crossmember, Bilstein HD Shocks, Brembo rotors & Hawk pads and more... 420rwhp @ 6000 & 410lbs.
LQ9 stroker soon...
PwrdbyLS1 is offline   Reply With Quote
Old 10-29-2009, 11:46 PM   #6
BES Stroked Nova's Avatar
Trader Rating: 12
Send a message via AIM to BES Stroked Nova
same pistons in my short block,just mine have a notch for the intake valve, I just used a 06 GMPP block, and put one of these rotating assemblies in it. I didn't feel like dealing with a LY6 block... but having the exhaust valve notch there makes it a little eaiser to shove a monster cam in these, and mill the heads and make some decent power for cheap.
anyways, I have milled L92's, 242/246 cam, little port work, out of the box GMPP L92 intake, ultra low profile elbow. Made 585HP on the engine dyno, and it Rev's forever! I shift it at 7800.
Car manages High 10's, Low 11's full weigh(3800) 6 speed car.
I just love this little motor.
__________________
2006 Duramax Dually, Crew Cab Tow Rig. 4" MBRP
2000 SS #8053 M6 12 bolt,BES 6.0L, L92's 242/246 custom cam. carb/efi
418 LSx all pro hurricane headed solid roller EFI SOON TO COME
BES Stroked Nova is offline   Reply With Quote
Old 10-30-2009, 11:52 AM   #7
GC99TA's Avatar
Trader Rating: 14
Awesome information. Just what I needed! Thanks a lot for the pics too. It always helps to see just what you're dealing with.
__________________
MY SITE
99 Trans Am M6
Old 10-30-2009, 11:58 AM   #8
GC99TA's Avatar
Trader Rating: 14
Thanks a lot for the info. Sounds like you've got a healthy motor there. I think mine's gonna be a pig for sure if I don't do some milling and maybe put in some thinner cometics.....just not sure if I'm ready to do it just yet or wait to ultimately build my 408.
Can I ask why you didn't want to use the LY6 block? Have you heard of specific issues with these blocks? My guess is just because of needing to relocate the cam position sensor to the front and get rid of the VVT stuff maybe?
__________________
MY SITE
99 Trans Am M6
Old 10-30-2009, 01:03 PM   #9
Trader Rating: 0
I kept my VVT stuff. I know people are tempted to gut these things and stroke them out, but it really isn't all that necessary.
For the cost of a 408 you could effectively have a ZR1-style engine with one of these LY6 engines. FWIW it's a 9.6:1 compression motor, so it's basically ready for ~10 psi. You don't need a $1200 crank/rods to go fast.
__________________
i own a 4th gen f-body
pillagenburn is offline   Reply With Quote
Old 10-30-2009, 02:38 PM   #10
Trader Rating: 12
yeah, cam sensor, Knock sensors. and VVT stuff...
Plus I didnt have access to the blocks, but I did get some VERY low mile rotating assemblies(like 2 to 3 miles max) and used those in a GMPP 6.0L block.
__________________
Tags
11s, 12, 230, 232, cam, duramax, dyno, engine, heads, ls1, ly6, mile, motor, performance, stroker
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
LS1TECH - Archive - Top
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.2.0
Advertising - Terms of Service - Privacy Policy - JOBS
