Can you believe it? 1 month until the 3rd Annual LSX Shootout. That's not very long. What's the status of the car you plan on bringing? Come on; hold back no secrets. Are you already where you want to be or are you working towards a certain goal?
Texas has 100* heat right now and, given, it will not be this hot in Memphis in October, but due to the heat my car runs right in the middle of 2 Index Classes right now! My goal is to make one or the other either by adding more power somewhere (it's tapped out) or slowing the car down within the PCM and/or weight to run the slower number. Either way it will not be easy. We tried different cams and hey, she just knows what she wants to run on right now! The car really talks to me!
Best of luck to everyone participating and I'm curious to know your latest developments and what you are doing to prepare for this great Event!
__________________
2000 Trans Am 346 NA, 4L60EBest ETs: 6.49 (1/8) and 10.20 (1/4) Wanna Race? GMHTP Feature Car - November 2008 | 2009 LSX Shootout - #1 Qualifier (10.50 Index) www.fquick.com/FastTaGurl
Reason: change title to 30 days out!
I'm nervous my car will not be done in time. We are certainly doing everything we can. If it does get done in time, it's very likely I'll be making my first test passes in a Turbo Ls car. So, I'm sure it'll draw some laughs.
__________________ 1999 Trans Am Tatershack Performance I need a motor sponsor that can handle 25psi
A3--Full Suspension--347--S480--6.0 manifolds--A2W http://tnfbody.com/forum/showthread.php?t=9537
Special Thanks to: Tatershack Performance/AEIcnc.com/Speed Engineering
My clutch still hasn't came in and i still got to get my tires and wheels, might get me a 2 step and start runnin it on e85 soon.
__________________
12.68 AT 111MPH BEST YET(UNTUNED RUN)-SLP SS, M6 - SLP AIRBOX, BLACKWING, SLP LID, DESCREENED MAF, KOOKS 1-7/8X3, DUAL 3 INCH CUTOUTS ON KOOKS Y, SLP U/D, SELFDONE HP TUNERS TUNE, BMR SAFELOOP, TICK MASTER, NO BACK SEATS INCLUDING BELTS(31.8 LBS), AIRCONDITIONING IS FOR PUSSY'S!!!
I just went 11.504, 11.501, 11.502 and the tree I am not to bad * .011, .008, .024 (.500 Pro Tree).
I am not sure what class to enter in the Index rumble?
__________________ Built & Tuned by East Coast Supercharging
2004 & 2006 E.C.S. C. C. Champion
2008 Pro 11.50 Champion
2008 LSX Showdown Index Event #2 Winner
2008 LSX True Street 11.00 Index Event #2 Winner
2009 PINKS ALL OUTTAKES Feature Car @ MIR
2009 Hot Rod Drags Quick 8 Runner Up
I just swapped from a 10" to an 8" converter and installed a much need manual valvebody last weekend. I have also removed some extra weight, installed strange brakes, and a Meziere race WP for about 150lbs off the scale. I'm gonna let the temps go down a bit before heading to the track to test and tune. Last time I ran the car it went an 11.01(still with 10" stall and stock brakes), which was just shy of a half second improvement over my shootout ET's last year. I'm hoping to be right at the 10.50 mark when I get back on the track.
I seriously doubt Ill be able to run this year. Ive been laid off from work for the last few months, and that has really hurt my track time this year. I havent been down the track since March. :sigh:
Just recently, my clutch has started giving me trouble under high load. Sometimes it will try to grab, and just chatter. While other times, it wont even think about grabbing, and it'll just over power the clutch. Pretty sweet for 7,000 miles on a clutch rated for 650 ft/lbs, when Im making around 400! On that topic, I think Im going to give Monster Clutches a try this time.
I need to order some track wheels as well. Ive got tires for them, just haven't decided which wheels to go with. Ive been looking at Street Lights, just haven't seen any GTO guys running them yet. Guess Ill be the guinea pig for fitment.
__________________ Dalton Winfield
Shocker Inc Racing Editorial Staff @ PlanetLSX
Switched to an 11" Yank TC, added PFADT Billet/Poly tranny mounts, been running in the 9.30's in the hot weather. MPH has gone up over 150/151. Shortshifting the FLT 4L60E tranny at 6400 has not really slowed the "Barbie Vette" down much. Been racing the IMSM Heads Up on a .400 Pro Tree Series with some success - Very Hard to run against transbrake cars. Will be racing at the NMCA/NMRA shootout in Joliet this week in the LM-EFI 9.50 index. Been to some KILLER cruise nights this summer so far. See you guys in the fall!!
JR
__________________ 00 C5 Coupe-FLP 427 C.I. C-5R, AFR Heads, Fast Intake, Lunati Rotating Assy., FLP Fuel System, Comp Cam, Rockers, Springs, Lifters, Pro Charger/F-1R (18.5 lbs.), FLT Stage VII A4, Kooks Header Syst., Yank TC, RPM C6 Z06 3.42, CCW Wheels, Penski Coil Over Shocks, FLP LS1 Edit, Motor City Mold CF Hood, Alston Race Cars Full Cage. (Dynos 802 RWHP/900 Motor on 93 Oct.)
I still have a pile of parts that need to be installed but at least I have everything here finally. Waiting to be installed are new Moser 12-bolt, TFS 215 heads, LS7 lifters, Yella Terra rockers, Fast 92, NW TB, Nitrous Outlet 92mm plate, new wheels and tires, and get down to Futral's to have the car retuned.
I guess I am going to have to give in and get a cage installed as well or I won't be racing at all.
Avoid nutswingers: for genuine Madman products, buy only from authorized dealers - http://madmanandcoracing.com/dealers.htm World Record 60ft 1.18 on a 275 drag radial Worlds Fastest Torque Arm F-body - 7.43 @ 188
Late Model Racecraft Quickest and Fastest LS1 on stock suspension
Ill be there,Think im going to be there on stock unported 317's Wonder just how fast you can go with these heads? Finishing up a little chassis work and dropin the motor back in. Hope to test 3rd week of aug.
__________________ OLD COMBO : LQ9 6.0 cam, headers, n2o, carb setup...6.27@109, 1.38 60' on 275 DRs
NEW COMBO :Who knows??? I DONT!!!
