- window switch and A4
- nitrous just installed ....pics..
- MSD window Switch-Any Defected Models?
- Nitrous ever go bad?
- Ripped it ALL out this weekend
- HSW plate kit pics???
- Nitrous gauge sending unit location???
- N20 shot for insurence w/ BPU cobras
- smaller fuel jet.
- window switch woes
- Need Pics of WOT placement on LT1
- just hit the 100 shot
- Help with TNT kit jet sizes
- Has anyone installed 2 10lb bottles in spare tire well??
- How will this cam respond to Nitrous?
- Need Help with 2007 Trailblazer SS
- going with the dynotune dry kit...100 shot
- dynotune shut down switch, not shutting the nitrous down
- 150 wet kit doesn't hit very hard
- First post...need help with nozzle placement
- Tubing for purge. PURGE QUESTIONS!
- LS1 Timing Tuner
- Nitrous conversion advice?
- MSD Digital Window Switch
- Is theis kit wet or dry
- Spray out of the hole???
- Just curious. Please help.
- WOT on C5
- timing tuner AND window switch
- nitrous fill stations in Oklahoma
- HSW Question
- HSW Bottle Opener
- tach wire problems
- how much et drop to expect from nitrous
- lentz rods+callies crank=how much spray??
- Cam ?
- Picts of my switches
- Any issues running tr8's in a street car?
- nitrous jet calculator +plate system
- Help with hsw wet kit
- close or open bottle
- converting dry to DP
- Intake choice help please.
- Will my setup like the gas?
- best way to pull timing?
- Just finished my HSW Plate Kit, etc.
- Need tune for 02 TA. HELP
- how many companies do a nitrogen push setup?
- Gonna buy a nano system have ???????
- FS: New MSD digital window switch
- Nitrous gone bad..
- FS: Nos Progressive Controller
- NOS remote bottle control
- The Fang
- Nitrous Direct a BIG no no!
- IAT timing tricker for LS2/C6 vette w/HPtuners
- is it safe to use nitrous ??
- Had an Idea for Voice Memo Buttons
- will i need a new tranny soon?
- Need info on 200 shot
- hidden kits
- 150 shot and -3 an line??? help
- Anyone know if TNT bottles work with Nano?
- Selling my TNT nitrous kit.
- lets see your dedicated fuel systems....
- Nano Nitrous Group Purchase
- 2 stage dry hit.. ??? question
- Racetronix Fuel Pump Kits 48 Hour Sale!!!
- IAT how to with PIC...
- N2O installed on my TBSS
- Help picking DP...
- My 408 is back up for sale
- L76 direct port??
- Relay mounting
- Best Price on the NANO kit's whos got'um?
- wtt my 860 spare tire mount for your tunnel mount
- Questions About Water Methanol Alcohol Injection - Post Them Here
- BMN Window Switch Issues
- WTB 1 ft 4 -an.
- Nitrous issues found..kinda of..
- 90mm LS Wet Nitrous Kit, Cost Comparison?
- what jets for low fuel psi?
- Problem when Spraying
- misfire code due to fuel jet?
- hsw dry kit install
- Nitrous First
- I finlally spayed
- Who is running a Mechanical N20 gaue in a pillar?
- dynotune lean shut down switch
- few questions about dedicated fuel system
- February Nitrous Specials
- NGK TR6vs ?????
- Need some help. Looking into sprayin my car
- FS: HSW 90mm plate
- How much timing to pull out? 250 shot
- who makes the 90 mm nitrous plates for the fast intake setup?
- DP on GM carb intake pics?
- Vette guys?
- WTB Autometer CF gauge anyone selling
- Mounting bottle on trans tunnel
- mohammed from kuwait
- solenoid placement for a dry hit
- LT1 or LS1 for running nitrous??? Which is better?
- How much power does this kit actual make at the Rear wheels.
- Paging Nitro Dave, LT1 nitrous ?
- Gunna Spray! :)
- -8 blow down tube
- Anybody spray 200 shot with NOS 90mm plate?
- Running line from trunk??
- Where does everyone get their battery power from?
- Trying to find the cause of my False Knock Retard
- Donate Used Spark Plugs- For Good Cause.
- Photos of my install and custom switch setup
- Jet Size Help!
- Timming Retard Unit, what are you all using?
- 12.9-1 Comp. w/ 150 shot is it safe
- 99.9% safe nitrous setup?
- how much can it handle?
- Sluggish and weird sound when I just used Nitrous
- Help
- Bottle refilling
- MSD timing twister/Window or Mallory HyFire
- Torque Setting for Blowdown Fitting
- Transmission and rear end with 75-125 shot
- wanna trade 90mm NOS plate for 78mm plate???
- Where do I get a brass bottle nut for a electric opener?
- how to know?
- Launch controller with spark retard features feedback request
- Everyone Post PICS of PURGE setup
- how/where to run mainline..
- Max Spray?
- What Size Purge Line?
- Problems problems problems
- question about HSW plate
- fs hsw interface
- MSD Digital Window switch question
- How to wire neatly and professionally
- Shortblock ? for 300 shot
- Which NX 4150 plate?
- New NX dry maf results
- What's the fastes 346 on nitrous?
- bottle and air
- Should I ? with..
- Wicked DP Dry (not mine)
- 300 through a fogger.. keeping the heads down?
- what jets do i use for this set up???
- will a 255 pump suport 2 kits???
- How do progrssives work?
- N2O installation on a 2006 TBSS (need minor wiring help)
- Shift lower for nitrous?
- Difference in running a 4an and a 6an main line
- Off the rail maximum shot?
- witch race gas for nitrous
- Help me Put Together my Direct Port
- General Nitrous kit question
- Nasty fuel rail hell please help
- Efi Sniper NOS kit question...
- new nitrous system question...HELP!
- Another timing tuner ?
- HSW bottle pressure regulator leak
- Quick ? for my nitrous brothers....
- timing for 100 shot
- NGK Plugs for a 150 shot??
- T-Top Holders?
- fuel shortage
- High Pressure Dedicated Fuel System Build-Up
- Oil Lubricants In There Oil
- Mounting bottle in trunk??
- Fastest Stock block/internals?
- witch is a safer Nitrous system
- what to do to run a wet shot of NOS
- Narrow band connection
- N2O and LSA ?
- 2008 Official "Nitrous Fast List"
- Looking to add a sneaker shot.. help please
- Spark plug sticky???
- nitro daves
- Question about a zex wet kit
- Wiring the Timing Tuner Question?
- Stock fuel pump ?
- Who uses internal bar on cast tunnel ram.
- dynotune or FPSS
- Blowdown tube ?
- NX Bottle Volume Display Controller
- nos15974 progessive controller
- Dedicated fuel supply from tank
- FREE Nitrous System & Accessories!!!
- Spark plug and gap change N/A Tune?
- Teflon Sealant??
- blowdown tube
- My nitrous/fuel system! Pics galore!
- DynoTune A/F lean shutdown switch
- M6 guys with 100 shot whats your setup
- fpss
- ls1 78mm NOS plate
- Dry hit + heads/cam?
- how much will this cam work?
- Solenoid installation
- N2O install Help?
- nitrous issues
- TPS Switch & Window Switch Question?
- How to convince the wife to let you have Laughing Gas
- lean shutdown switch and timing tuner questions....
- Refill Station
- Sputtering
- I have some questions(Nitrous wet kit and Daves plate)
- HSW Plate on the Dyno
- Note to self "do not lose or misplace NOS stuff" Your wallet will suffer
- Finally broke down
- good nitrous cam for my application
- incognito
- need your help
- How and where is your Nitrous filter installed???
- Painting bottle
- What fitting is used to connect the fuel line to the fuel rail?
- window switch + spray out of hole....setup.
- Hidden Nitrous on LS1
- 42lb + racetronix good enough for h/c + 150 shot.??
- Wiring relay question
- 4.10 m6 and a 100 shot
- nitrous hook up
- Interesting Dry Nozzle Idea
- Lets talk E85 and Fuel solenoids
- gaping plugs for a 250 to 300 shot
- Think i made a mistake goin wet.
- ls1 stock fuel setup for nitrous ? is it safe ?? should i do pump upgrade or seperate
- hsw plate kit installed
- harris wet kit
- Anyone have a purge, window switch, and/or a C5 panel for sale
- i need a stock vette intake manifold!!!
- Internal Purge
- ok i have a problem and i need to fix it asap
- Does nitrous kill your motor?????
- good wet kit for 355 lt1
- Need Wideband Curves, for a better V and P gauge.
- plugs
- NX twin Nozzle Kit
- 90mm dual stage plate, dual nozzle systems bunch of n2o stuff for sale
- What else
- My Experience with Nitrous Outlet..
- WOT switch and Window switch?????
- 100-150 shot with high mileage
- Tnt F2 Kit Pics Please
- window switch
- dynotune
- Nitrous section humor for the week
- Almost Ready ?!?!
- Hsw
- Who has a seperate fuel system for nitrous?
