- Happy Holidays From Nitrousdirect
- Just got FJO Racing Progressive Controller
- pills
- How long?
- LT1 guys with AFR heads. What plugs for nitrous?
- Some questions about DynoTune controller and solenoids
- new spark plugs when juiced?
- new spark plugs for n20?
- 250 shot on hyperutectic pistons????
- Is this a fair price (Labor)
- new christmas ornament
- Looking for a #$*&@ rocker switch
- Timing Tuner with FJO?
- Used NX KIt 4 Sale..
- how many times
- What's the easiest/cheapest way to upgrade to dual stage?
- What Switches
- 860 bottle heater
- Fuel and Nitrous Supply questions
- I think I have the final answer to my thurst for juice.
- help with gauges
- 125rwhp shot safe on a 100k w/boltons tranny?
- NX wet kit ?
- Aux fuel cell
- Tune Revealed Problems
- Can I run 100 wet shot on my stock motor with no problems?
- High pressure test results
- Bigger injectors
- MERRY CHRISTMAS!!!Holliday Hours!!
- I made it into a magazine!!! : )
- Heater on while spraying?
- Best kit to buy
- 150 rwhp shot safe on stock LS1?
- Who sells the ash tray switch panel?
- 98 Injectors
- anyone have a 5800rpm pill for msd...
- Zex Dry Kit Question
- nitrous on ls1 in the long run? damage/wear in the future?
- NOS plate system Vs. ZEX system for LS1, opinions needed!!!
- question for N20 pro. . .
- What Spec On Cam To Look For
- braided vs nylon lines...
- Question on mounting of solenoids
- Sheetmetal intake and DP
- Spark Plugs
- Dry Kit Question
- Need Help - NX MAF kit...
- 2 MSD Window Switches $70
- Nx MAF for sale...$250 obo
- Purge Line Question
- what times should I get with this kit
- Nx Whp Gains?
- First Nitros kit!.......
- Nitrous Tuning ?
- Question About NX Jets...See Dyno.
- NX Jets
- new to NOS need a little help
- hose seperators
- 150 jets
- Wideband Upgrade new release for FJO.
- Help me find a nitrous friendly cam>>
- nos shots
- Got bored
- Few more noob questions.
- Nitrous/Propane Dyno
- 150 dry shot, how can i hide it?
- MAF for dry NOS kit
- Its a Sad Day
- Almost became a thief today...
- Lightning winners needed....
- Nxrickey I Need Help Again !!!!!
- next nitrous breakthrough
- Opinions on my nitrous set up
- Possible New idea for wet kit placement
- Can we get an agreement?.....OR ELSE
- You guys Ready for the kicker?
- Need some Christmas cheer Here!!!
- How about a 50 dollar credit!!!
- Dry Jet coversions from motor to wheels?
- Max dry shot on stock fuel system with 28lb injectors?
- Nitrous Outlet Now Carrys NOS Products..
- ashtray switch panels....
- why products cost more, NXRicky rambleing.
- Race Gas And Nitrous
- NXRicky I have a Mastermind II app question...
- Stupid question... need answer quick
- Is there a progressive controller that allows you to control flow based on SPEED?
- NX progressive controller?
- Solenoid openers
- Who is this???????????
- Nitrous Discussion Concerning Chemical Makeup
- What is the fastest dry shot LS or LT?
- Can someone set me straight?
- Looking for a good Nitrous read........
- I need a 90mm ring for a new NW TRB.
- can I put 175 jets in a TNT F1?
- Hidden Nitrous System?
- NX Mainline
- Who sells the complete stand alone fuel kit....
- Nxrackey Need Help
- Nitrous mounting setup..
- LT1 Plate+nozzle 2 stage questions
- NX progressive controller info?
- conventional play with gmmp single plane and carb styler TB?
- Anyone purgeing through a dry nozzle????
- NX Heater blanket kit...
- How much gain with 125 dry shot
- A New Sticky Idea
- Dry Shot: IATs
- NX Shark Nozzle ?
- Nitrous Pressure Discussion.
- Dyno #'s
- Missing purge parts?
- LT1 Switch ideas
- Post up your nitrous dyno graphs
- who all has the timming tuner??
- Paging Dynotune nitrous
- whats a good setup for me
- Zex dry kit on LS1???
- 6.0 liter intake
- OH YEAH A4 175 shot 1/4 mile times
- Couple cam/nitrous questions
- DynoTune bottle opener ?
- Logged: Lean A/F: Small Dry shot
- Got the NitroDave's WOT switch/bracker for LS1/GTO...
- fpss setup
- More Nitrous Ignorance...56k Beware!!!
- relay switched amp draw
- Is it safe?
- How much nitrous on stock ls1 w/forged pistons?
- 04 GTO Nitrous Question
- Nitrous newbie...(mainly LT1 folks, but whoever really)
- Nx Is Now A Sponsor On Tech.
- TIMESLIP from Jan 06 GMHighTechPerform LS1 v LS2 Shootout
- Avoiding N20 on 1st gear?
- C-5 Ashtray N2O Panel WIP
- Spraying 200-250 ... what do I need to do?
- Solenoid Frequency??
- NX MAF or TNT F2?
- Tech Services from NXRICKY
- 100 shot on a bolt on lt-1 a4
- Who Wants free Car?
- Thanks Dynotune
- Nitrous Ignorance
- NX low cost digital progresive controller
- NX 90mm TB or Direct Port?
- how much can a bolt on lt-1 take
- Methanol and Nitrous
- Nitrous bottles mounted in my bed
- NXRicky's going off on a tangent, & explaintion on products differences.
- Nitrous On An Automatic
- no2 prob?
- n2o advice?
- NX or ZEX?
- Rebuilding stock motor
- ** New Product News!!!
- OK....LT1 guys that spray 350+
- Spray 175 shot with less timing or 150 with full timing?
- what gears with nitrous?
- Dynotune 2 Stage Window Switch
- How much nitrous can you put?
- 5w30 or 10w30 for nitrous cars?
- Harris Speed Works controller install ?......
- Spray Happy
- NX Max 2/Solenoid Driver wiring question
- Zex mounting
- NX 150shot ?
- Fittings to adapt fpss
- too much juice?
- something 2 think about.... NOTHING TO DO WITH NITROUS
- Nitrous vendor Jihad
- Anybody have a link to NGK TR7s?
- Fuel pump upgrade
- NX Kit Wiring Check!!
- Freeze MAF
- Window switch and shift points
- DYNOTUNE LS1 Wet Kit - $369!!!!
- Have any of you made your own nitrous switch panels?
- GM High Tech Perf./Jan 06 Issuse, all about N20
- Hello from Cold Fusion Nitrous Tech.
- What shop have been put on?
- switched 12 volt power ?
- Complete Accessory Race Packs! Great DEAL!!!
- Dry 100shot and forgetting to take traction control off
- What wideband are you guys useing???
- Nitrous Solenoid
- got a n02 idea . . . would it work?
- 84 s-10 blazer with 5.3
- DynoTune Wet Kit Install
- Car stalled out after nitrous shut-off???
- Why does nitrous create power?
- New to Nitrous need some help ZEX
- NX Direct port jet table
- TPS Module
- DYNOTUNE 8 Cylinder Dry Kit - $299!!!!
- Dry shot: Solenoid failure: Low TPS
- popping noise while spraying
- whats the biggest i can juice my 02 Z28. wet or dry
- Performance Racing Industry 2005 Photos!
- Does NITROUS need HEADERS
- ***Holiday Special*** Pro Race Packs!!!
- Want to see your car on our site?
- 3 Stage Mock up Pics **Dial up no no**
- Introducing the new PRO Dry kit
- Just finnished the install and tested it out!!!
- Need some nitrous help
- Who has the fastest M6 Hot Cam/Sprayed Car?
- Thanks to Beer99C5! Sent me Nitrous Stickers
- BANDIT SPRAYS at The Track 1st Time last night!
- Which Nitrous Gauges
- Spraying with stock pcv system?
- am jucied
- A few pics of my set up
- MSD didital switch problem
- Nitrous Wiring
- my first 10 second Nitrous pass
- Spraying on a hot intake valve?
- Hitting rev limiter with Dry shot......
- New Product....
- What Kind of Nitrous system should I get.
- A couple of Nitrous questions
- Dry Shot JET size??
- Update: N20 Solinoid Stuck Open
- Dyno numbers A4 SS
- Whats the biggest shot I can use on stock bottom end?
- Nitrous veterans in here please! Robert?
- need some opinions from nitrous guru's
- Christmas Specials!!!
- Just Installed Nitrious...need input???
- nos dry pills
- What kind of engine motor oil are you nitrous guys using???
- New NX nitrous solenoid question (amp draw)
- nitrous with supercharger/turbo
- wiring diagram
- Moderators / Sponsors
- Congrats To Nitro Dave!
- Nitro Dave
- LT1 Nitrous Question
- Fogger nozzle mounting
- Will it hold? The rear that is.
- Plug Wires
- hidden idea
- clutches and nitrous...
- How Offten Should You Check Your Solenoids.
- need a quick answer on blowdown tube
- Sneaky Pete
- N2O is not cheating
- Free Plate conversion!!!!
- Nitrous help!
- Spraying off the line A4
