- No Upshift?!?!?!
- Help with stutter with 4L60E @ 75MPH
- Trouble w/ new tranny not shifting
- 4L60E question???
- Shaking after Stall Install around 45-60 mph
- Tranny/Convertor revisited.. More info
- Average 60fts with Yank SS3600?
- Need a complete schooling on 400trans
- need a better converter!!!!!!!!
- 20mph roll downshift
- 4l60e shifter query
- Transmission Problem
- please help
- will stall do??
- 4l80e with classic gauges (flexible shaft driven)
- Shifter Q's
- Hayden tranny coolers?
- possible new t/a owner
- Bolts for tranny crossmember
- Shift Kit/Stall question
- th-400 to moser 12 bolt help.....
- Torque converter question.
- Z-PAK Concerns
- What is wrong with my transmission ?
- When bolting the 4l60e up....
- SS4000vsYANK PRO ELIMINATORvsPT4000
- M6 to TH350 (speedo question)
- Manual valvebody?
- LT1 auto transmission combinations
- TH400 Fluid from Vent Tube
- Will i be satisfied with a 2800 stall?
- Sticks in 2nd Gear!
- 700R4 and 4L60e - do they interchange?
- For all the people that talk sh#t about Fuddle converters
- SS4000 is in!!!!
- broke my second coverter...
- Flexplate Opinions
- Ss Tb 3600 Yank!
- RPM or Performabuilt ?
- Does i need an oil flush?
- Which standalone computer for 4L60E ?
- still having issues....
- Tranny cooler lines..size/how to
- RPM Stage V Tranny owners inside please
- NEED HELP FAST!!?!?!? 4l60e DONE??
- Converter is going in!!!
- Problem on highway--transmission overheating?
- Yank phone number??
- What does a 3,000 stall feel like?
- Got a ? please help
- YANK SS3600 vs. SS4000 Track Results. No BS Just hard facts!
- Tune After Converter
- 6L60E 6 speed auto
- do I need a tune with a torque converter???
- Red PCM pin # 20 & 21
- What's a blue converter?
- converter comparison please!!
- Need help on M6 to A4 swap
- 4L60E Stall Question
- Automatic Question
- trans temp ?
- pulling tranny
- My New setup!!! opinions wanted!!!
- A4 and B&M Pro-Stick Shifter
- tranny additive
- A4 tranny or convertor issue..??
- TH 400 install from an m-6?????????
- Auto vs Manual. Reliability, Maintenance Costs...
- what's up with this?
- TH400 Dipstick tube
- Whats up with my tranny????
- any one with a yank pti4000 stall
- Pilot bearings
- tranny cooler...Is aftermarket enough?
- who builds the best high performance 4l60e
- trans brake for 4l60e???????????
- What should I replace on the trans while the motor is out: non lsx related?
- Trans tail leak?!?! WTF??
- 4L60E affects engine, speedometer
- what shifters fit A4 Console
- yank 3600
- Finish Line Transmissions
- When did your 4l60e die?
- ultra bell??
- 4L80E swap is complete !!
- Why is the Vig 2800 really a 3200?
- where should I mount my trans temp gauge inside the car?
- Trans builders help, 4L60E build one last time
- TH400 Speedometer values
- TH400 build
- trans shop in ILL. called transking or tranzking?
- 93 4l60 in a 94
- th350 input/output shafts
- tci trans scat valve body kits
- bellhousing to engine bolt length
- will any 3200 stall do?
- Question on perfect combination for track only car
- Transmission rebuild
- drivetrain loss for th350 th400 and 4l60e
- Best price on the th350 cross member with torque arm mount?
- phoenix converter
- Stall?
- Problem with my new PI Vig 3600 stall..,.
- 4L60E to t56 $ ?
- TCI Converter?
- convertr install
- Tools/other stuff?
- Manual Valve Body?
- Horsepower rating...
- Neal Chance for LS1/TH400 setup FS
- p1870 code question
- People w/3600 stall, question for you.
- Manual Valve Body 98-02 fs/ft
- Stall question
- Stall drivability
- please help, 3rd and 4th keep slipping
- Valueable lesson I learned today
- need to know thread size
- how big of a tranny cooler
- what will break first
- After market Auto shifters
- quick question
- 4L60Evs 4L65E
- Where to hook up trans temp guage?
- TCI or Fuddle
- Problem with SS4000
- Setting up trans cooler
- anyone running an Art Carr converter?
- 4L60E Cooling lines
- which hole on the trans is the return line?
- An idea for a cheap overdrive?
- another 4l60e question..
- fluid question..?? dex III, dex VI?
- weird sound??? HELP
- Converter install question ASAP !!
- th400 questions
- just got trans rebuilt not working right!!! HELP
- 4L60e experts help needed !
- TH350 Converter Brand Selection
- Will it work??
- Transmission Shot?
- oil return line to transmission
- Loose Automatic Shifter
- just put in th400, no reverse
- Stall + N20
- what rmvb/t-brake should i buy?? th-400
- TCI Flexplate and Trq Conveter bolt issues NEED HELP?
- Trans brake & 4l80 problem
- Tranny fluid used as engine oil?
- How do I mate LQ4 to a TH350?
- Safe to drive without trans cooler?
- How do you check your stall?
- 4l80e guys with nitrous....how tight of a stall?
- best converterfor $350 or less?
- which converter
- Trailblazer SS AWD - Yank SS3600 or Vig Multi Disc 3600
- tranny temp gauge prob
- What cooler and where do i find it?
- Bypassing the computer shift in A4
- What is overdrive?
- Th400 Temp Sending Unit?'s
- Trans temp gauge wire pics LS1??
- What else should i do while im in there(convertor swap)?
- Stall with heads and cam
- 4L60E not going into 4th gear
- trans pushing fluid out of dipstick no 1st or overdrive
- how many converter bolts?
- How many hp 4L60e handle
- rear main seal leaking because of flexplate?
- Yank Fuddle Vigilante
- Install Converter HELP!
- Vacuum Modulated 4L60E
- anybody use the Yank pro extreme 4200 stall?
- Cooler line kits?
- Question about building my 4l80e
- Weird things with a 4l60e..
- TH400 & Electric Shifter Setups
- blown up?
- driving around town in 3rd?!
- please help me select my converter
- Help Please
- not shifting into 2nd at wot
- performance shift question
- High Stall Converter Question???
- OK..RMVB 4l60e?? Is there??
- Help me pick a stall
- 4L60E Downshifting from Overdrive when Crusing
- Shift points at WOT
- A couple questions about a 700R4.
- blown trany ?? help
- Fuddle...4000...60ft?
- need help with trans
- Car lundges/creeps at start up?
- 4L60E Manual Shifting...
- ???: Tci
- Frame rail trans cooler for a 60E?
- write up on changing tranny fluid
- looking for converter
- .....help Th 350 Flexplate......
- Should i be worried about my TCI breaking?
- What size stall
- What is Converter Chatter?
- Wiring Pinout Needed! Trans Sensor...
- A converter install write-up??
- torque converter going out?
- 4l60e no first gear
- Hard shifts from 1-2 gears
- tranny pan?
- Filter change HELP
- A few questions about the stall I have coming...
- Trans held gears longer after long drive
- Speed Sensor
- How many hp 4l60 ?
- Vigilante 5 clutch setup info
- Stall questions...
- Stall Speed
- Just an FYI....
- Time to install...new tranny / verter
- SS3600...I'm that guy.
- How much does the TCI Flexplate weigh comared to stock??
- No Shift 2-3 under WOT - PLEASE ADVISE
- soft shifting
- Damn 4l60e....
- Corvette 4L60e to 98 Z 28
- 4l60e or 4l80e?
- Tranny coolers
- Anyone use a COAN converter?
- Converter bolts reverse thread?
- TCI 3000 and 3.73 to much?
- 4l80e slip yoke
- I need spare built 4L60E, who would you choose
- HELP TH400 swap help whine noise
- Trans Cooler mounting
- a4 with carb set up & no computer
- Help - need advice!!
- i got a question about trany mount
- Anyone run a Dynamic TH-400??
- 4000 stall question
- 4l60e?
- Tranny Issues... w/ 4l80e Need Help if possible.
- HELP!!! Trans fluid everywhere
- Another trans problem 4L80E
- converter question
- Anyone run the PRO YANK 3400 EXTREME?
- tci controler info for the 4l80
- T-brakes can someone school me on them
- 4l80e and 9 inch driveshaft question
- Tranny
- High HP A4 Guys...
