PDA
View Full Version : Automatic Transmission
Pages : 1 2 3 4 5 [6] 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100
  1. Going from M6 to TH400 and need help ASAP
  2. Pan magnet issues in 4L80 pan long!!!
  3. Poll: stock 4l60, can it take a TC?
  4. Help wtb asap adaptor for 1995 4l60e for l92
  5. PY3400 feels like a stock converter????
  6. Trans Question
  7. Need help Please Read!
  8. Any 6L80E news?
  9. I have a couple of 4L60E questions?
  10. Shifting problems..Help
  11. Draining Converter?
  12. Tranny fluid
  13. Yank Converters?
  14. fti install need help
  15. Clunking noise under Accel/Decel also over bumps!!!
  16. My DD T/A transmission is going out...
  17. Transmission feels like in Neutral
  18. 4t80e
  19. WOT shifting problems
  20. 4l60e bucking after rebuild, BUILDERS INSIDE.
  21. Shifts a little soft, took pressure readings, need advice
  22. Metal "tink" noise when going into gear
  23. Tranny only leaks when I hammer the car??
  24. tcc 04 gto
  25. Shift lever position
  26. Shift problems
  27. Transmission cooler W/Fan Wiring Questions?
  28. 4l80e problem on my first test drive
  29. Hurst Pro stick in a 6 spd console
  30. TH350 For Sale
  31. torque converter question inside
  32. couple ? with trans
  33. Is my tranny giving up??
  34. Replacement trans
  35. trans. fuild change ? on TC fuild
  36. '04 GTO A4......Corvette Servo?
  37. are neal chance converters worth it?
  38. pressure port an acurate place to measure trans temp
  39. Is my 4L60E dead?
  40. b&m shiftplus+ install?
  41. 4L80e Sun Gear Shaft Bushing(s)
  42. Newbie Question
  43. so who running tci 399753 with th400?
  44. i finally found the perfect 4l80 rear fitting
  45. Sufficient cooler?
  46. Line pressure issue?
  47. Tranny Similar To This For 4l60e?
  48. Keep 700-r4 or go to 4l60e?
  49. 1st gear is locked?
  50. The 4L60E "IMO" ...
  51. Broadcast codes..
  52. how often should trans. fuild be changed
  53. th400 Converter in a 4l60e?
  54. Thanks Chris- Circle-D
  55. First time out with the Yank SS4000
  56. 4l60e Pump vane clearance
  57. 305 TPI 700-R4 TV/detent cable
  58. my gear, with TH350?
  59. 9 days left on FTI converter SALE
  60. Having obd1 4l60e trans issues
  61. Anyone break a stock trans mount with poly motor mounts and relocated torque arm?
  62. Won't move with shifter in OD
  63. personal experiences with 3600stall
  64. Help Car doesn't move.
  65. No reverse lights after auto swap?
  66. delayed 2-3 shift..billet servos installed
  67. 4l80E into 97 Z28
  68. Hey you guys
  69. Thanks again to FLT trans and FTI verters
  70. Thanks Rossler Trans.
  71. Replacing my transmission, question about converter.
  72. Hard kick when putting in drive after LS1 swap...
  73. Tranny starts in 3rd sometimes?
  74. Looking for a good shift kit
  75. Is this normal for the tailshaft??**video included**
  76. Converter Won't Seat
  77. Blowing though the converter?
  78. Car on the lift in neutral, should the wheels spin?
  79. I need convertor selection
  80. Shifting problem
  81. Thanks PerformaBuilt T400 still tunning the car.
  82. What torque Convertor do i need
  83. G8 6L80E trans output shaft
  84. any builders have problems with torlon balls on old plate?
  85. wot shift into 4th?
  86. Broke shifter cable
  87. TH400 swap shifting early, help!!!
  88. lockup
  89. autozone flywheel?
  90. any ideas???
  91. Yank SS3600 or SS4000??
  92. 4L60E hanging in 2nd..
  93. Converting from older aluminum pistons in 4l60e?
  94. 4L60E Difference in 4.3's awd 4x4???
  95. shuddering after trans rebuild
  96. Trans Overdrive Issue
  97. Gear vendor speedo issue
  98. Ok guys I really need some suggestions
  99. Converter question
  100. No reverse when warm
  101. M6 to TH350
  102. tranny cooler question???
  103. Who's running an aftermarket TC+stock tranny?
  104. Lockup for Transgo 4L80E FMVB
  105. Big hp guys what trans mount are you running?
  106. New stall, my old oil cooler good enough?
  107. Hughes rebuild kit for a 4l60e
  108. New 4l60e and convertor. now stuck in between gears?????
  109. slow shift
  110. Aftermarket shifter or knob that works with auto console?
  111. need some ratings on a 2800 stall?
  112. What are you TH400 guys running??
  113. part number for transgo kit
  114. Shimming Coverter?
  115. Rev Limiter?
  116. th400 swap drive shaft ?
  117. LT1 4L60E Vs LS1 4L60E?
  118. vig 3200 and bolt ons, what to expect?
  119. M6 to 4L80e or Th400 (various questions)
  120. Switch to Yank results in three 151 MPH runs!
  121. Converter install?
  122. Stock gear ratio?
  123. Trans never starts off in 1st unless I manually start in 1
  124. 4l60e transbrake
  125. 4L60E manual lever position switch??
  126. new tranny jumps out of gear at WOT
  127. getting rebuild on 460lE
  128. Just ordered my new trans/converter combo from Performabuilt
  129. 4L80E Questions
  130. Curious about the rice..
  131. 4l65e beefup
  132. Tips? What converter?
  133. Need to know requirements to intall a 4L60E in a car equipped with a 4L60.
  134. A4 shifting question
  135. Thank You FLT and Yank!!!!!!!
  136. Transmission Issues
  137. the future...
  138. tranny & stall as well as rear fluids amount??
  139. 4l65????
  140. Transmission shift linkage
  141. 98 Z28 A4 shifter button sticking
  142. Input Drum Stuck
  143. Just Dropped off The Converter
  144. anybody have any luck stalling a high mile trans
  145. What gear ratio
  146. bad tranny
  147. how much to build up a 460 to handle 550 rwhp?
  148. Necessary To Trailer With T400 RMVB?
  149. 4L80E w/Transgo manual kit problems
  150. 4l65e behind 427ci engine
  151. 700r problems need help
  152. Multi-disc converter tune settings?
  153. gears and stall
  154. 4l60e to th350 coversion????
  155. 4l80 conversion U joint
  156. Wont shift from 1st!!!
  157. whats the hottest trans temps we've seen?
  158. Trans Gurus: cooling
  159. B&M Quick Silver pissing me off
  160. Trans issue 04 Silverado
  161. converter efficiency
  162. Bought a Circle D converter today!
  163. FTI Help put us in the top 10
  164. Top speed in an A4 car.
  165. 9.5 precision multi disks rattler
  166. Burnout - Possible Stall Question
  167. Aftermarket Shifter for 4L60E
  168. th400 vibrations....
  169. Change tranny fluid and filter?????
  170. Could this be the reason?
  171. 480LE not shifting problem, n00b help please!
  172. Hurst dual gate shifter in 95 A4
  173. trans help???
  174. Shifter Rattle..
  175. determining stall speed
  176. tips/tricks..
  177. Flexplate part number for 6L90 and LS376/480
  178. th400 trans brake question
  179. Sloppy shifts at part throttle, firm at WOT?
  180. what stall for my particular setup?
  181. quick race compilation after pfb lvl2 install..
  182. 3rd and 4th gears not working properly
  183. stall ?
  184. Fail Thread
  185. quick question
  186. Question for Permabuilt Lvl-II drivers
  187. th400 clearances?
  188. Need help identifying 4l60e convertor
  189. VRX3 with stock stall
  190. Quick question
  191. Strength on stock 80e?
  192. lookin at getting a shift kit
  193. How 2 make 4l60e last longer?
  194. 4l60e forward clutch pack
  195. Transmission temp guage
  196. Lost R,2,4 gears
  197. CSR Flexplate
  198. v6 to v8 4l60e
  199. M6 to 4L80 swap in progress... have a Q about flexplate spacers.
  200. tranny ?
  201. 4L60E - Drive vs. Overdrive and ASR vs. no ASR?
  202. gas mileage with a pt4400 and g5x2
  203. TH350 to LS1 question
  204. 8" 9" 10" converter size, what's the difference?
  205. Th400 lower than 60E?
  206. color wires for VSS on TH400 to stock harness???
  207. A few 4L80E Questions
  208. Is this converter slipping?
  209. th400 Pan gasket?
  210. M6 crossmember for 4l80 swap?
  211. 00 B4C Trans issue
  212. How much to repair this??
  213. Performance Switch?
  214. Converter or Trans issue?
  215. Will a 4L60e from a 98-02 Fbody work in a 94 Camaro?
  216. Alright you PRO trans guys, what breaks these parts?
  217. Trans break on 465LE?
  218. new trans installed
  219. 1994 4l60e Swap
  220. Speed Sensor Connector - TH400
  221. can a 4l80e be converted from 4x4 to 4x2?
  222. I got to buy a new flexplate.
  223. 4L60E Converter bolt sizes?
  224. torque specs on 4l60e tranny pan bolts??
  225. How do you know if your trans is slipping
  226. How much oil will fill the 4L80e and PY-3400 stall
  227. Sponsors...Need A Price On A Converter!
  228. Any pics of coolers w/ fans installed?
  229. what type of trans. fluid for 4L60E?
  230. stall question.
  231. 4L60e, 4L65e, 4L80e from 600-1000hp plus Stall Sale
  232. is this a good stall?
  233. Good converter
  234. stronger 4l60e
  235. Which speedometer gears do i need for my 700r4?
  236. 'Vette 4L60 issue
  237. 4L60E max HP
  238. blowing thru converter?
  239. Stock torque converter in a 2700lb car?
  240. what fluid to run in a fresh 4L80E?
  241. Converter Diagnosis?
  242. Transbrake solnoid spewing fluid?!?
  243. Slip Yoke Issue
  244. 700r4 in a 93
  245. trans problem
  246. th400 clutches and valvebody questions
  247. How to remove stock dipstick tube??
  248. 4l60e Shift linkage?
  249. performabuilt trans!
  250. Performabilt converters?
