PDA
View Full Version : Manual Transmission
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 [62] 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91
  1. Straightline Perf. awesome trans swap
  2. 98 sonoma manual trans problems
  3. Spec Stage 3+ SCO93F question
  4. 6 sp. in a 69 383 camaro
  5. Problem with bleeding clutch
  6. how do you knw if u have an aftermarket clutch?
  7. would you recomend a new master cylinder??
  8. which clutch?
  9. v6 tranny question
  10. 6pd with mech. speedo?????
  11. anybody know what parts to get to make an adjustable master
  12. My textralia instructions got torn.. how to install clutch balanced?
  13. trans noise
  14. LS1tech.com October Rebuild Special
  15. starting slave cylinder swap
  16. Stock Flywheel balancing?
  17. Ls6 good clutch
  18. Will not go into gear!
  19. Where to get a Textralia?
  20. Need help with bleeder valve
  21. Car going in on monday for M6 rebuild. Questions.
  22. Clutch pedal sticking?
  23. is it bad to drive a couple months with a bad 3rd gear
  24. Transmission stick
  25. Help with clutch
  26. Which Shifter?
  27. T-5 question
  28. Any way to adjust an LT1 clutch?
  29. Spec Light Weight Pressure Plate?
  30. Check engine- Will not shift into 4th [DSM M5 not LS1 M6]
  31. who put the most miles on their factory clutch?
  32. Give me your input about what to do?
  33. question about stock clutch
  34. shifter ball threaded adapters
  35. Drill mod?
  36. Bleeding clutch master
  37. help diagnose my clutch problem...
  38. Anybody elses Ram Powergrip chatter?
  39. New T-56...to me.
  40. M6 swap guys SkipShift ?
  41. Spec Stage 3 Clutch only last 1 year!
  42. Drill mod?
  43. Ram 6130 Break in period???
  44. LS6 Clutch Question
  45. Please help!! What parts will work for swap???
  46. centerforce dual friction engaging weights stuck?
  47. Stock Tach Accuracy
  48. 6 speed tranny nightmare
  49. Please Help Quick! Torque Specs on Pressure Plate
  50. Tranny fluid question
  51. Car rocking during decelleration....
  52. installed Hurst billet shifter in T56,now grinds when shifted fast into 4rth. WTF
  53. Billet Slider Keys anyone have them?
  54. instructions for installing a complete new clutch ?
  55. Grinding in 3rd and sometimes in 5th???
  56. stage 2 break-in
  57. Help Please!
  58. no tire barking in second
  59. SLP Flywheel, Light Weight Steel Billet - Opinions anyone??
  60. Anyone In NJ That Knows Where To Get A Clutch Installed?
  61. Do You Need A New Flywheel With A New Clutch??
  62. New Centerforce DFX Clutch
  63. SERIOUS Tranny Problem! HELP!!!
  64. 1st gear pops out of gear now and then???
  65. Transmission Blown!
  66. grinding in all gears after hurst install, need help
  67. Has anyone ran a Spec 4....
  68. Hard to Shift
  69. T56 rattle/jingling
  70. Where can I buy a reverse lockout solenoid??
  71. Flywheel install
  72. Is a drill mod required for a texarillia clutch..
  73. Do I need a clutch kit or just a clutch?
  74. Question about shifter?
  75. what gears available for the tremec t56
  76. aussie vs. ls7 vs. ls6
  77. trans. problem
  78. Shifter install question.
  79. Just got my Textralia kit with new billet flywheel
  80. You want a nice tranny and clutch?
  81. LT1 T56 with a LS1 engine possible?
  82. t-56 parts
  83. LS7 Clutch in '01 SS
  84. T56 center console Q?
  85. installing a shifter
  86. What's the difference between 01SS and Z06 clutch!?
  87. Any Luck with A4 to M6 Swap?
  88. LS7 clutch installed!!!!
  89. Centerforce Clutch for an LS1?
  90. main shaft
  91. Slop/play in output shaft, Need Help
  92. Which is a better box?
  93. Need to drain the Clutch Fluid?
  94. what is the best clutch?
  95. Spec Stage 3 clutch question Need Help.
  96. T56 grinding 3rd gear
  97. Clutch disk
  98. new too ls1 and 6 speed,my clutch is.....
  99. Is there any way to make shifting smoother
  100. Bolting Transmission back up.
  101. DOT 5 okay for clutch?
  102. Question?????
  103. Textralia Question
  104. Skip shift elim in, codes still throwing
  105. ram powergrip hd or not
  106. Tranny Problems
  107. Clutch switch.
  108. New clutch in, now car wont go into gear :(
  109. m6 newbie question
  110. Weird shifting problem HELP
  111. Shift Rail assembly
  112. Spec Stage 3+ SCO93F
  113. for my T56
  114. McLeod or Textralia single or dual ??
  115. where to get master cylinder
  116. I think I made a mistake
  117. A4 to M6:Master Cylinder not lining up? Wont reach the Pedal??
  118. Master Cylinder Install hang-up...
  119. Hurst Shifter Kit - Makes a lot of noise??
  120. Does having an '01 mean no drill mod req'd? Also textralia users inside please
  121. Help! - Clutch issues 3k Miles after install
  122. A4 to M6 swap. Need to know witch codes to edit.
  123. LS6 clutch question...
  124. Does the CAGS skip shift slp harness work?
  125. Need help. Can't tell if I need a clutch, Master Cylinder, or slave Cylinder.
  126. M6 Question
  127. clutch line...problems disconnecting
  128. SPEC Comparison: Stage 2 PLUS vs. Stage 3
  129. Pressure Plate
  130. Anyone know the GM part number for VSS connector?
  131. I need shims!
  132. Bleeding the Clutch System
  133. Can someone help? Slip yolk for T56 M6
  134. Tapping Diff/Tranny for Temp Probes
  135. Need a new clutch........need advice
  136. T56 speedo sensor???
  137. So what's the best clutch today?
  138. New to LS1TECH,a few t56 problems/questions
  139. clutch ?
  140. wierd issue
  141. RAM Clutch Disc??
  142. RAM Clutch Disc??
  143. Slave cylinder covered under warranty??
  144. A4 to M6--where to find the parts?
  145. '00 M6 TA - Shifter Problems
  146. CLUTCH Problems
  147. Where Can I Get A Gear Puller For A T56?
  148. Trans is grinding!!!!!!!!!!
  149. Spec Stage 2+
  150. What Causes My 4th Gear To Get Stuck ?
  151. which transmission should i use????
  152. HELP! Brand New LS6 clutch is giving me fits!
  153. what clutch fluid?
  154. 2 Questions about T56 LS1
  155. Energy suspension tranny mount
  156. Anyone running Amsoil ATF in their M6?
  157. LS2 Flywheel part number?
  158. Spec 3 a good choice for streetability
  159. T56 steel 3/4 fork
  160. Grinding into 2nd
  161. Drill Mod??
  162. shifting problems
  163. Do I need to upgrade clutch hydralics
  164. Spec 2 vs Spec 3
  165. clutch swap NEED HELP!
  166. drilling orfice on c5's?
  167. Reverse Problems?
  168. new hotness slave part number?
  169. The way I drive
  170. Which Clutch
  171. T56 rebuild
  172. trany gets stuck in gear
  173. Clutch help
  174. UMI Short Shifter/Subframe Connectors
  175. Is there a better clutch for the money than a Z06 clutch?
  176. dumb newbie question
  177. Best M6 60'
  178. Clutch pedal (please help)
  179. Just want to double check before I Order
  180. Help- Cant Bolt Up Tranny.
  181. Bleeding Problems
  182. Simple torque managment question
  183. engagement inconsistant?
  184. How Much For A Clutch???
  185. Stuck Clutch
  186. Spec 3 engagement issues after 9k miles
  187. Spec II or III
  188. Clutch headache
  189. Cluth Pedal Problem?
  190. rebuilt tranny question
  191. Is this normal
  192. SPEC 3 clutch chatter
  193. Pilot Bearing
  194. Some Mcleod Twin Disk Questions
  195. Anyone using a ram clutch with ram slave and master cylinders??
  196. Accessing the bleeder valve from topside
  197. changing my spec 3!!to ram power grip
  198. Another tranny problem
  199. What is clicking and chattering?
  200. LS7 clutch for LS1/LS2 cars
  201. LS1Tech.com Tranny Rebuild Special
  202. bleeding........
  203. What's a good shifter for my c5?
  204. 05 z06 shifter knob fit on our T56s?
  205. Black brake fluid! Why?
  206. had my trans rebuilt
  207. Changing gear ratios in a CORVETTE MN12
  208. Strange CLick sound in 1st and 2nd gear
  209. Clutch feels soft WTF?
  210. opinions and Driveablity on a RAM 6130 with 402L pressure late
  211. RPMs sticking
  212. A4 to M6 conversion for LS1 F-bod...
  213. Loss of second gear
  214. What Clutch and whats needed for swap version 1.332454353
  215. Ram 6130/402 PP do I "need" an adjustable master cylinder immediately?
  216. Throw Out Bearing/ Pilot Bearing Noises
  217. GM Clutch Fluid
  218. Drill Mod??
  219. 10% Off All SPEC Clutches And Flywheels!
  220. Textralia Clutch
  221. Clutch lays on the floor?
  222. New to a M6
  223. T56 threshhold?
  224. which clutch to buy?
  225. How much HP before shifting problems?
  226. Slave or Master cylinder?
  227. Problems with McLeod Explosion Proof Bellhousing
  228. need a little help, car is poping out of gear and hard to get into gear
  229. Stock M6 tranny mount
  230. Getting my winter car ready- timing belt change. Can't get crank to stop turning.
  231. clutch
  232. Carolina Clutch
  233. Harlan shift light users... need assistance...
  234. Input shaft movement
  235. Weird Noise on start up
  236. Problem with the Pro 5.0
  237. spec 3 and billet steel flywheel worthe an extra 400
  238. Shifter difficulty
  239. Advantage of an Aluminum Flywheel?
  240. T56 Tailshaft plug / cap /cover
  241. make my master cylinder adjustable?? anybody have a how to??
  242. chirpin' 2nd
  243. Questions on the 05 GTO T56
  244. Bleeding slave not working..
  245. Z06 clutch???
  246. Fidanza Aluminum Flywheel Balancing question?
  247. My New Website is Up.. www.t56rebuilds.com
  248. Clutch Rattle
  249. Trans wont shift?
  250. How important is a Mighty-Vac?
