PDA
View Full Version : Conversions & Hybrids
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 [32] 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69
  1. LQ4 swap into a 68 GTO A-body: Questions
  2. oil pan ?
  3. LS1 in my wrangler won't turn over
  4. question for you guys looking to use 'vette fuel filter/regulator setups...
  5. Fuel Tank Swap Problem
  6. Ls1 in a 1997 Chevy 1500
  7. Whats Up Gonna Be Doing A LS Swap Into An Early 240Z
  8. It's ALIVE!!!
  9. why would I make a vette look like a viper?
  10. S10 pro street
  11. Non-LS1 fuel pump options
  12. 4th gen Fuel Pump work in a 3rd gen tank?
  13. Where to go? 1979 Silverado
  14. Impala Sender question
  15. ls1 engine install guide pdf file
  16. PCM fan relay control question
  17. ls1 240sx question
  18. Few lil problems with first run
  19. A-Body Hooker headers and F-body Oil Dipstick
  20. LS1/3rd gen f-body coolant hose
  21. 04 GTO Motor and 6spd in 69 Camaro
  22. Creature Comforts question
  23. Putting 99-02 fuel pump in 95 Z28 ?s
  24. looking for a mustang
  25. Help installing a LQ4 into a 65 Chevelle
  26. Old Dog Z31 300zx LQ9
  27. looking for some insight on a toyota swap...
  28. LS1 5.3 into an '82 k10
  29. WHOOHOO !! My LS6 Mustang has PAINT !!
  30. Street & Performance ?
  31. Where to connect coolant crossover line?
  32. 5.3 carb swap
  33. smog on a LQ4-9
  34. Help
  35. 5.3 in a 2wd 72 blazer (oil pan problems)
  36. 550 rwhp for 68 Camaro
  37. Built rear-end in C3 Vette. Looking for possibly 750whp with n2o...
  38. LS1 to LS2/LS7/LSX conversion
  39. 98 F body harness, how to hook up my volt guage?
  40. Does anyone have shorty headers on a F-body
  41. Water Pump question??
  42. LS7 in a Silverado SS?
  43. Fiero with ls1 or ls2
  44. 2nd Gen Camaro
  45. LS1 to LS6 Conversion....HELP!!!!
  46. would shorty headers work?
  47. Twin turbo ls1 foxbody...? You can have it...
  48. Pacesetter Franken-headers
  49. fuel filter?
  50. LT1/T56 into 2nd Gen Swap
  51. Project Progress Report - 72 Chevelle
  52. Headers or OEM exuast manifolds?
  53. 67 c-10/ ls1 headers
  54. L92/L76 Intake to TAC module Wiring HELP!
  55. Anyone using AFCO swap radiator, F/A body
  56. converting from 3-wire MAF to 5-wire MAF???
  57. Anyone using the trans dapt motor mounts on their 67 camaro
  58. A-body crossmember pics
  59. 3.8 to ls1 will standard trans bolt up?
  60. Washing the LS1?
  61. what intake to use on 4.8
  62. Harness Question
  63. Ls1 into 240sx____PICS
  64. LS1 Mustang new times again !
  65. Invading Germany: LSX into BMW E34 525/535
  66. LS1 84 Vette just needs a little work to be complete
  67. I need a new driveshaft right?
  68. ls1 won't start?
  69. Wrecked my baby....
  70. Switches for Cruise Control?
  71. Year One Bandit shaker scoop
  72. LS1 swap in 75 Camaro HELP!!!
  73. LS1 swap HELP!!!
  74. cruise control
  75. gas tank
  76. Electric fan choices
  77. 5.3 in a 69 camaro, will the alt clear a cowl hood?
  78. Ls1 into a 97 S10,Need To know a few things
  79. T-56 6spd in s10 for under 2K?
  80. No signal from VSS
  81. Stainless Works Headers $650
  82. Need help with F-body front acc's on 5.3
  83. Starting from scratch
  84. LS1 into 73 corvette
  85. Variable valve timing
  86. Interior swap?
  87. not enough vacuum
  88. Ls1 Fj40
  89. Revcounter Problem
  90. 240sx + T-56 = what master cylinder?
  91. Autometer Speedo
  92. lost a thread pls help
  93. 6.0L LQ9 Swap questions after days of searching
  94. LS1 in 94 Z28 won't start
  95. LSX Mustang air?
  96. Hot Import Nights - Chicago
  97. engine dies immediately but fires off great.
  98. Completed E36 LS1 swap total weight and corner weights
  99. is four inches too much?
  100. Complex wiring questions
  101. FS: Richmond T10 4 speed
  102. Engine frame bracket- Which one?
  103. current performance wiring
  104. New S13 hatch owner wanting to do an LS1+T56 swap
  105. why carb an LSx?
  106. 66 Chevy II, 70, Camaro or 68 C10 truck for a swap?
  107. 66 Chevy II, 70, Camaro or 68 C10 truck for a swap?
  108. Corevette LS1 in '87 RX-7, transmission question.
  109. fresh swap, no start
  110. For Sale : LS1 Foxbody swap Headers
  111. Help on converting a 98 harness
  112. Help please, on lower alternator brackets!!
  113. whats everyone useing for a brake switch
  114. what lt headers for an rx7 ls1?
  115. 6.0 in a 82 Chevy silverado
  116. S10 Sanderson S10 ls shorties what gaskets to use!!
  117. LS1 3rd gen swap
  118. Question: Thick White wire, what to connect it to?
  119. Extreem LS1 project
  120. Try to start-> Click
  121. LSI in 69 Camaro --- A/C mounting problems
  122. reversed/flipped truck manis on s10??
  123. Opinions on HP Tuners
  124. Can anyone recommend a good fuse panel
  125. Compressor Brackets
  126. throttle body coolant line, bypass and necessity?
  127. Speed sensor for 4l60e
  128. Corvette Drive By Wire
  129. Year range of GenIII equiped trucks?
  130. LS_ in to a G-body drag car
  131. New F/A/X body swap pan??
  132. looking for s10 swap headers for ls1 longtube
  133. "Search" Feature In "HyBrids & Conversions" Help Please!
  134. ECM mounting bracket
  135. 6.0 4l80e in a '94 rcsb 1500 need info
  136. I need the "Project Orphan" articles from Popular Hot Rodding
  137. a quick radiator question
  138. 1981 Corvette - LSx Anyone?
  139. Aussie LS1 conversion
  140. 68 Camaro/ T56/ LS1 driveline angles - noise
  141. ls1 rock crawler
  142. LT1 to LS1 fuel questions
  143. 6.0 LQ4 pin outs
  144. what to do for dlc ls1 engine
  145. Moroso oil pan?
  146. Best fitting motor mount?
  147. R12 in R134 system
  148. Removing dipstick tube
  149. StoneOfFire's 98TA guts in a 96 Firebird project
  150. balancer ?
  151. wiring harnesses?
  152. Need Merv or Blahsters help here :) Wiring Question
  153. stealth with ls1 swap
  154. What is the best way to hook up a th350
  155. ls"x" exhaust manifolds...
  156. Would this oilpan work?
  157. Can I MAKE a car?
  158. Starion/Colt/Conquest LS1
  159. write up on ls1 into lt1 car...harness and shitt
  160. Need Help! Swap won't start!
  161. 1988 And Earlier LS Shootout!
  162. Any ideas how to hook up TH400 tranny to cable driven speedometer?
  163. It LIVES! 85 Vette with a LS2
  164. Wiring OBD-II using GM pinouts or using Nissan/import pinouts? emission questions
  165. Ls6 Supercharged Bmw M3 T56 6 Speed
  166. t-5 into 240sx PROBLEMs
  167. Do You think this engine will fit into my car?
  168. LS1 foxbody swap-- Difficulty level
  169. Motor mount Q for the experts
  170. LS1/5.3/6.0 in a 1965 Chevy truck
  171. Hummer H3 Alpha 5.3 motor and oil pan
  172. LSX in a Crown Victoria. Anyone tried it?
  173. killer 71 c-10
  174. wiring help!!!
  175. f body accessory part numbers
  176. ls1 vacuum diagram..
  177. Question about using LT1 gauges
  178. LS7 into a fox body?
  179. My LS1 FD build, no kit.
  180. 9.96 at 139.5 on the LS1 Stang!!
  181. looking for shops that do LS swaps
  182. 69'camaro W/ 4th Gen Dash
  183. 67 chevelle header question
  184. Need Info On Lt1 to Ls1 Swap
  185. New Project: 1968 Cutlass Convert LS1
  186. 96 S10 Blazer AC
  187. Houston, we have lift off
  188. 5.3L is it worth it?
  189. LT1 to LS1 k-member problems
  190. LS1 Intake on a 6.0L Truck engine
  191. How to get the AC working?
  192. Opinions on LS1 in a '70 Monte Carlo
  193. Question about p/n and tcc(Speartech wanted) lol
  194. Modified f-body oil pan, is the oil capacity ok?
  195. 98 v6 A4 to 01 ls1 A4
  196. wiring
  197. PCM re-flash Seattle area
  198. any Sponsors stock Edelbrock #71181
  199. 99 v6 to 99 ls1 swap
  200. alternator and idle problem
  201. Removing a fan
  202. Black Obsidian Update!
  203. Opinions on Heads and Cam for LS2
  204. Video of my car
  205. harness extensions...
  206. LS1 into a 97 T/A - A/C problem
  207. ls2 in a 1969 camaro
  208. needed for conversion: interior wiring for stock camaro gauges
  209. CAD LSx oil pan rail dimensions/diagram?
  210. For Those Wanting to do a swap!
  211. clutch line adapter/fitting leakage
  212. O2 sensor wiring
  213. 68 camaro a/c, oil pan, wiper motor
  214. steering box CLEARS headers!!!!!! pics
  215. water pump heater hose nipples
  216. I think I have some wiring crossed......
  217. length of time to wire up an ls1?
  218. Dyno results are in: 452 rwhp
  219. No Data Link
  220. 2210 pin out question /93-97 Camaro
  221. ls1 not running right in 69 camaro
  222. Popular LS1 distributers/junkyards in New England.
  223. bleeding air out of cooling system?
  224. I need some major help
  225. Long start times, any ideas?
  226. Anyone looking for a stang to swap?
  227. 5.3 into 4th gen swap
  228. question for Cable X users
  229. LS-1 cams
  230. Yet another "Help! My car won't start!" thread
  231. gas mileage
  232. tpi vs LSx
  233. PHR LS1 mustang swap pulls big mph!
  234. which motor mounts
  235. another 98 won't start, need quick advice
  236. 2nd gen Camaro 6.0L swap - which oil pan
  237. my 79 reliant kitten with ls1 and th350
  238. HELP HELP!! tank pressure!!
  239. Twin Disc Clutches and Master Cylinder
  240. ls1 in a third gen camaro
  241. LS1/700r4 into 02 Jeep TJ
  242. in-tank fuel pump vs. external pump-66 chevyII
  243. yes, C6 Z06 brakes will fit on a 4th gen F-body....
  244. LS1/2/6.0 into mopar a body
  245. Everybody with a Gbody and A/C....
  246. Motor Plate..
  247. LSx and 4l60e into a G-body
  248. High Fuel Consumption?
  249. Manual Transmission Swap - Hummer H2
  250. 94 To 98-02 Front End
