- 2007 6.0 questions
- Engine Choice Question
- LS1 motor mounts for a El Camino -69
- 6 cyl to 8 conversion need help
- Just scaled my 68 LS1 protouring nearly 50 50
- 13 pin connector on 4L60e? (TH400 swap)
- turbo turd s10
- Want to put intank fuel pump in a 20 Gallon tank
- 78 Caprice Henry's LS1 car - Alive Again - vid
- Its alive!!!!!
- GTO AC Compressor vs Vortec truck compressor??
- My '62 LS1 Nova starts right up
- brake switch wiring...ok to leave alone?
- Need help 98 corvette wireing harness OBD-2 port
- Anyone want to trade LH8 pan for stock Fbody?
- FS: 55-57 side mounts and poly mounts
- truck intake clearance.....
- E40 ECM Cruise Wiring
- Aftermarket O2 sensor wiring
- Oil pressure Sender
- lower profile exhaust options
- My custom "ford" emblem for LS1 swaps.
- Power Steering info needed
- 1970 elcamino lq4 swap ?s
- LS Engines???
- a few last questions
- gear indicator switch question
- HELP! LS2 does not stay running
- Trying to find the right oil pan I need help
- Sinister Rx7/ls6
- What headers will fit my 68-72 a-body?
- why does everyone switch to the car water pump?
- LS into C3 HELP!
- Throttle body question
- Idle & Hesitation Issues
- Using Transdapt Motor mount part# 4592 on A G_body/LQ4 swap
- Setting Up the electric fuel pump/regulator for the G-body/LQ4 swap
- Turbo 6.0 what power to expect
- A-body ls swap combos. list the best here
- Me and a buddy were tossin the idea around to...
- E46 Conversion - Whats the problem with it?
- Ls1 Colorado
- ls1 into a 96 3.8 firebird
- LS and ProCharger
- Quick ? for guys with ls1 accessories on ur 5.3, new alternator location? w/pics.
- LS1 into 94/95 LT1 F-body Question
- 5.3L from an '04 Isuzu Ascender?
- quick? Will a 6.0 flexplate work with a 5.3 engine?
- 400FWHP 5.3 or 6.0 for $2000 possible?
- Jeep TJ&YJ LSx Conversion Compilation Spreadsheet
- Runs Great!....till it warms up
- wiring help please!?!?!
- Quick, cheap 5.3 swap into a 1990 Silverado
- Fuel Pressure
- LS1 Swap question
- Chevelle got a little magazine coverage.
- Cam question: Carbed LQ4 w/ 5.3 heads
- Which ECU to use for hi-power conversions/swaps?
- Need some help.
- Swapping cammed LQ4 in 1977 chevy truck.
- Where to find a Ford 8.8, 3.90, 28 spline???
- TV cable install on LS1 info wanted
- Anyone seen this bracket conversion?
- flexplate spacer confusion
- !!06 GTO LS2 to LS3 418!!!
- slave cylinder
- late model transmission behind a sbc
- LS1 240sx Guys Help Me Out Plz
- electric temp sender question
- '99 L36 V6 to '01 LS1 V8 swap (w/PICS!)
- Need Info for 2000 V6 Camaro LS1 Swap??
- 69 Nova LQ4 turbo questions
- 1967-1969 Chevelle/Camaro LS1 Swap Header
- DBW Gas Pedal mount 240sx
- LS7 Corvette accessory drive
- 67 camaro project
- 6.0 emblems
- Just wanted a second voice to make sure I am right
- fuel rail
- which transmission did u choose and why?700r4?th350?th400?
- my gt ls swap with updates
- In car video at VMP
- Mustang lsx begining
- 4-67 A body,LS1,2004r swap
- LS1 Dipstick Removal
- Craziest, Most Original LSX Swap?
- lifting a 5.3
- 5.3 into nova or jeep
- spohn mounts
- Stand Alone Question
- 6L80E in a G-body?
- Wiring Help
- Anyone have experience with http://www.lt1conversion.com ?
- Conversion folks - Tranny Cross member question
- LS1 swap guide to 2 gen Camaro.
- odd ls1 problem
- LS1 year model?
- c10 conversion
- 87 cutlass lq4 questions...
- Spectra Fuel Tank
- VSS for LS on old Muncie style manual....
- Odd fan issue
- LQ9 DBW Pedal Motor?
- Crossmember not lining up
- LS1 in 1989 3/4ton Suburban...?
- Auto Meter Electric gauges with stock senders
- My 67 Camaro Project
- Spectra Premium in tank pump failing
- e38 pwm cooling fan control
- LSX in a foxbody question?
- Corvette Fuel Filter, Russell fitting 640940
- 04 GTO harness into a 93 TA 4L80E. Conversion help
- Stand Alone Harness for LQ4 W/200r4
- 4L60E v. T56
- Wiring Help
- 62 Bel Air sedan 5.3 Turbo build
- Just curious
- LQ4 swap into camaro
- Look what we did today...
- 98 LS1 harness mod question, cam sensor plug?
- Need Help, Swap fires but doesn't idle
- LQ4 6.0L sawp into 96Z, potential problems?
- Finished Product '00 S10 4.8 PICS
- GTO project
- ls2 in my 69 camaro
- fox mustang lsx Q's
- help with engine stands
- '00 S10 4.8 Dyno Results
- how do I attack the spark?
- Fuel Vapor Canister recomendations
- LS6 Intake manifold and cable TB on LS2 with E40 PCM
- th400 vac hookup
- Ls2 dbw
- Cleaning out the garage......what do U need?
- A-body headers on the cheap! Check it out
- clutch resevoir
- Couple of issues after swap...
- Starting swap on 73 nova (what motor mounts)
- underhood hanress: who's using it?
- My wiring seems to be done!
- excessive. the 69 camaro
- Gauge Question
- connector part numbers
- trailblazer SS complete swap 4x4 is it possible?
- thinking of converting my rad to a dual pass in sted of a single pass?
- Headers
- Connector C100 Pin N, "Ignition 3 Voltage"??
- Camaro Tank Pickup/Wiring/Fuel Line Questions...
- I might give up on my LS1 swap after all
- Out of the Blue Running Issues
- suggestions on possible third gen swap?
- Where to buy LS1 manifold exhaust flange?
- hud display conversion
- LSx Conversions at Hot August Nights
- Anyone here running the gauge cluster from an LSx powered vehicle in their hybrid?
- GM A body ?????
- Preparing to order my radiator, anything special I need to account for?
- L92 VVT T56... can it work?
- 06 TBSS Motor - ECU Options
- Rubber fuel hose for injection?
- Best T-56 Solution / Ideas?
- EVAP Solenoid
- lsx? miata help
- 1st gen F-body twin turbo
- which oil pan for nova?
- can you plug the coolant crossover
- ls2 back firing question
- LT1 iroc swap need Help!!
- Speed sensor signal
- How can I tell the year of my lq9?
- 96 v6 bird to 00 ls1 wiring??
- Coil covers, low budget/plain covers
- ls1/ls6 headers for 5.3 vortec ??
- us a Mp t70 big egnough for a 6.0
- LS3 in a 1969 camaro Vac Lines
- LSx/4L60e recommendations for an miata
- forced air design
- 1st startup.......need help
- LQ4 or LQ6 to 2002 Firebird 3.8...
- LS1 '35 sedan does "Route 66"
- Need some Serious Wiring help please!
- LT1 faster than a 5.3
- 05 GTO in S14 DBW throttle wiring help
- Corrected interference with power steering pump and chassis
- New Vid '78 Caprice 99 LS1 TH350 373 gears
- Help Ls1 S13 Please help!!!
- '65 Buick Special conversion- it has begun!
- E40 ECM with 98 Corvette Pedal
- Question about Rockauto/Spectra EFI gas tank
- New vid - LS1 swap 64 Imp SS
- lt1 6speed 98 S10?
- Z-Bar ball stud to block relocation?????
- G-Body Frame Notch Detail in 1955 Chevy Truck
- heads/cam LS1 into a 1968 Firebird
- when swapped for a 6.0. whats your MPG
- 5.7 to a 5.3 swap
- What knock sensors?
- MIL light
- Need help with 98 PCM pinout chart!!
- 5.3 vortec flexplate is it dished or flat?????
- need some bellhousing advice
- 04 vs 02 LS1 harness
- Already picked my motor, not sure on chassis
- 8.8" IRS in something other than a Miata?
- Speed shops in the MD DC VA area
- Carb Legal LS1 Headers for S14
- ac relay
- What cars can I cut the injector clip off to match LS1?
- Dumb ABS question
- going from DBW to DBC
- 70 Chevelle-Canton or Moroso oil pan?
- F-Body Exhaust Manifold 3 bolt flange drawings
- LS2 into 1983 Mercedes 380 SEC
- LS2 24x problem
- Need Help PS Question for a LSX C4 Corvette Swap
- 66 chevy II ss ls7 conversion Help
- The goldyloxx thread (lsx into 1980 camaro)
- Alternator clearance on A body- 600 box
- Has Anyone done a BMW E38 LSX & T-56 swap yet?
- LS1 stalling off/idle then back to idle
- 5.3 dod swap questions
- LS1 into 95 tahoe... Help please
- WTB: Mustang coupe / LSX
- finding an engine in so cal
- 5.3 in my 93 chevy truck
- 69 camaro conversion
- Question on LS3/7 Air Filter Assemblies
- 5.3 wiring question
- keeping factory gauges options? 72 chevelle ss 4160E
- Who is using a remote electric pump?
- Which stall converter should I use?
- Ls1 into 95 Buick Roadmaster Wagon?
- Aftermarket Kit Inner Fener Panels!! Nova Clip!
- Carb'd LS1 edelbrock intake w/ign box
- ISIS Intelligent Wiring -
- gauge fittings
- 6.0 lq9 swap in 55 chevy
- 99-02 pcm
- Help will not run
- where can u buy stock oem ls1 parts?
- LS1 K-member
- What does this do?
- Using old coolant temp sensor on passenger side head
- Any known LSx --> Z4 Swaps?
- Wish my car would co-operate
- Camaro LS3 has arrived for my 65 Malibu
- CTSV Shifter conversion
- 1994 RX7 5.3 swap
- ls1 id
- LS2 to 200-4R swap with electronic throttle, is it possible?
