PDA
View Full Version : Conversions & Hybrids
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 [55] 56 57 58 59 60 61 62 63 64 65 66 67 68 69
  1. schrader valve size
  2. LS1 in a 5.0 fox body?
  3. What powers the computer??
  4. It's Alive
  5. '97 Corvette exhaust manifolds...
  6. Fired the '69 this weekend!!!
  7. 350 dune buggy
  8. F Body Pan Swap
  9. 55 Chevy truck- Lt1-m21
  10. 71 Chevelle alternator clearance issues?
  11. Thought you guys might be interested in an RX-7 for an LS1 swap
  12. LS1 in 86 Montee SS or 84 Z28?
  13. will an autometer 0-90 fuel gauge work??
  14. LS1 swap in 2nd gen wiring ????
  15. I have a blown 6.0 LQ9 engine sitting here.. What parts are salvagable??
  16. vortec 8.1....
  17. vortec 6.0l turn key engine swap setup on ebay
  18. interchanging oil pans
  19. How to run speedometer off of C5 transmission
  20. schrader valve size
  21. drivetrain help.
  22. gto ls1 in 71 camaro
  23. p/s going to coolant hose?
  24. flush oil fill cap????
  25. need a new oil neck
  26. 70 LQ4 nova questions
  27. 4 Years later and its done!!!!
  28. What is the 6.0 that I want? what is a fair price?
  29. LSx to 200-4r??
  30. 5.3L or 6.0L LS truck engine for 3rd gen
  31. What shifters will work with my T56
  32. anyone know if autometers can be taken apart
  33. ls1 and tremec TKO?
  34. Connectors and Pigtails
  35. Crankshaft Position Sensor Location?
  36. LS1 Swap Question (NSX?)
  37. burned out my fuel pump?
  38. Autometer Tach Instal Questions.
  39. lt1 alternator wiring help
  40. LS1 into a '94 Z
  41. 3.73s with a stock 4l60e?
  42. plug wires with sw headers
  43. LS1 Throttlebody To MAF Elbow w/IAT Provision?
  44. Firebird conversion headlights
  45. stock ls1 power?
  46. where to run autometer water temp sender??
  47. Try to keep the stock fuel system GTO 04 LS1 into 66 nova.
  48. And now for something completely different...
  49. unisteer in LS1 67 firebird?
  50. LS1 gas mileage
  51. harness help
  52. Good online sources for LS1/T56?
  53. HELP! Some brake troubles here...
  54. LS1 Opel GT?
  55. Four-seat Corvette = RX-V8?
  56. fuel pump and regulator advice
  57. GN fuel sender
  58. 02 sensor questions.
  59. How many people have made/modified wiring harness?
  60. LS1 wiring question.
  61. Power steering pulley question
  62. It can't be THAT hard
  63. -6an or -8 an
  64. fuel rail cover w/ one cut out
  65. Rebuilding my swapped RX7 over the winter- (big pics)
  66. broken bolt snafo
  67. C5 fuel level sender
  68. Got my engine, finally
  69. Can I use 99+ O2 Sensors on my 98???
  70. ls1 in a 1953 chevy 2 door
  71. LQ4 vs LQ9
  72. LQ4/4L80E in a Jaguar XJ6 - almost there!
  73. Ls1 v8 miata exhaust system
  74. What manifolds for g-body conversion
  75. has anyone done a 72 chevelle lsx
  76. New pics of tube frame C5 hybrid car
  77. Electric throttle body conversion.
  78. ?'s on Speartech reworked LS1 Harness
  79. C5 instrument cluster
  80. Clutch pedal helper spring
  81. 79 chevy 350 motor
  82. LQ9/4L80E in 72 chevelle driveline angle?
  83. Fuel Fitting??
  84. Ls1 Throttle Cable
  85. T56 shifter repositioning Q
  86. Full C5 Drivetrain into C3???
  87. using a return line
  88. 1987 rx7 gxl in kansas
  89. Megasquirt for sale
  90. 6.0L belt driven acc.
  91. Corvette engine to F-body specs help..
  92. ls1 into 94+ stang questions
  93. 1080lb 250+mph turbo LSx swap
  94. Got it running
  95. Where to buy?
  96. LS1 Swap into 94 F-Body
  97. 05 Coil Packs w/ 98 LS1?
  98. Planning update
  99. My LS1/T56 swap into '68 Chevy C-10 stepside
  100. 5.3 vortec newbie w/ questions
  101. Turn key engine supply harness, 410HP?
  102. my hybrid in action. RX7 on oad course
  103. Header lengths? for UK enthusiast!
  104. Header Flanges
  105. Can 2001 Computer Control 1996 Anti-Lock Brakes?
  106. LS1 swap into LT1
  107. 327 LS1 69 Camaro Turbo AWD Protouring
  108. LS1 head question
  109. ls1 in a challenger
  110. Which engine should I put in my van?
  111. 4.8/5.3 questions?
  112. ls-1 conversion question (spindles)
  113. Ls1 headers for a V8 Miata!!!
  114. 6.0L questions
  115. Ls1 in Prowler>?????
  116. t-top welding
  117. Lt1 and Ls1 kmember
  118. Will this work for my tach?
  119. What's missing from my harness?
  120. Fuel line upgrade
  121. My next conversion project car!
  122. 5.3 vs 6.0
  123. Engine set back in 2nd gen swap
  124. 6.0 & 5.3 INTERCHANGE
  125. Started building headers [PICS]
  126. Where is Conversion to Carb in LS-1?
  127. How Do I Wire The A/c Fan?
  128. 1st Gen F-body LS1 project Ideas
  129. 12 volt disconnected and computer program lost??
  130. Power loss and Computer holding program
  131. 6.0 Id
  132. Big roots blower on LSx
  133. About to take the plunge - LSx in 72 Nova
  134. oil pan help! need slimmer oil pan!
  135. TH-400 x-member modification?
  136. Will PCM lock the Torque Convertor of a 700R4?
  137. Looking for information about the inline walbro fittings Straight to dash
  138. truck accessories in a first gen
  139. two fuseable links off the alternator
  140. How long is TPI kickdown cable?
  141. Ls1/t56 swap into 95 Lt1/4L60e Trans AM!
  142. LQ4 into 99 v6
  143. 99 and new fbody harnesses the same?
  144. LS1, LS2 or LS7 in a BOAT ???
  145. LS controls on genI sbc. hybrid help pls!
  146. 1LE intake elbow help plz
  147. how long did your conversion take to complete?
  148. hmmm what to do....
  149. Help Asap!
  150. LS1 & T56 drop out - Where?
  151. motor mount plates
  152. Trailblazer conversion
  153. LS1 RX7 slowly in progress
  154. LS1 Fuel Rail Fittings
  155. weight of a 6.0L
  156. 95 K1500,5.7 To Ls1
  157. adding a pin to the PCM connector.
  158. harness from turnkey
  159. ???'s about gauges
  160. 4th gen front suspension in 3rd gen?
  161. Warms up then dies.
  162. Ls1-240
  163. Free T Shirt from Speed Scene Wiring
  164. ls-1 conversion question (brakes)
  165. t56 conversion
  166. Speartech throttle-by-wire
  167. Fuel Pump
  168. A few needed answers please.
  169. LS1 Trike
  170. V6 in my SS?
  171. 6.0L wiring harness
  172. 4L80E in 1st Gen Camaro
  173. 3rd Gen - 4th Gen A/c
  174. C5 drive shaft/torque tube welding, what rod.
  175. LS1 into S10 swap header pics
  176. Ls6 Intake manifold on 6.0 engine
  177. Painless wiring Kit
  178. ls1+240sx
  179. LS-1 / T-56 into ´59 Cadillac
  180. motor mount templates from faq wont load
  181. ls1 motor in a 97 v6
  182. Part Numbers needed
  183. New Sponsor! Speed Scene Wiring
  184. Rear Mounted Battery Wiring
  185. good news and bad news...
  186. 6.0l into 99 v6 firebird
  187. STS turbo on 3rd gen LS1?
  188. F-body motor mounts
  189. F-body fuel rail part number
  190. ht4100 to ls1?
  191. 6.0L in 70 nova
  192. Is BCM necessary if you don't reprobram PCM?
  193. fs 99 ecm 9000 mile
  194. Fuel pump wont wrok until out of tank???
  195. so who's done/doing a SBC (not ls1) into a Fox Body Mustang?
  196. LSx into a Conquest/Starion?
  197. How long without a tune?
  198. No Spark !!!!
  199. 72 suburban and 71 malibu need swaps!!!
  200. 6.0L vs 5.7L wiring harness
  201. 4.8 mods?
  202. 2002 6.0 truck donor veh up for auction in Tx...
  203. LSx in a DeLorean....
  204. ls1 vs 6.0L
  205. cpu ecm question
  206. Plastic Mock up engines
  207. 6.0L harness
  208. HELP!!!!! LS1 and Turbo 350
  209. budgets & estimates
  210. Alternator wiring questions
  211. Forward Oxygen Sensor Source?
  212. Ls1 carb question
  213. Ls1 Radiator Into Third Gen Trans Am
  214. 79 LS1 motor pics
  215. cooling...
  216. Mazda RX7 LS1 with ATI ProCharger '04 GTO kit
  217. Relocate A/c compressor help
  218. LS1 installed into 1982 Trans Am, need tech support
  219. 96 Blazer with 2005 Suburban 5.3
  220. Question for my buddy
  221. OBDII Connector
  222. need an LS1/A4 for your swap?.....
  223. I Know, I Know This Isnt The Classifieds BUT...
  224. Weighed my car today...
  225. Engine mount adapters???
  226. 84 k5 blazer 99 ls1 swap
  227. Crank Re-Learn
  228. Cooling Questions
  229. LS1 into a replica 66 shelby cobra?
  230. Which LS1 motor to look for?
  231. Interior Wiring harness help!
  232. Wiring for race car??
  233. Auto to Manual flywheel bolt question
  234. fs 85mm maf
  235. 88 s10
  236. 5.3 Vortec cam,LS-1 intake
  237. Engines from G&R Auto Parts
  238. So what do think? Finally got my conversion to the track...
  239. Anyone seen a GENIII in a 65-66 B-Body Chevy
  240. '68 Corvette Story...LS1 into a '68???
  241. 2 speed fan wiring
  242. ls1 into 3rd gen
  243. is 4 gauge good enough for starter wiring?
  244. Ready to fire up the LS1 280Z!
  245. water pump inlet not lower hose
  246. Air intake on a 94 3.4 l to ls1 swap
  247. what about...
  248. Emissions....
  249. 1994 LS1 camaro...
  250. Gauges help
