PDA
View Full Version : LT1-LT4 Modifications
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 [90] 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138
  1. c6 front brakes
  2. Getting rid of the OPTI
  3. whats the point of the air pump?
  4. Temp guage?
  5. a 307?? whats the thoughts?
  6. Should LT1s have a forsale section?
  7. Please post pics of F bodies with 325/50-15 rear tires!
  8. Pics of my new motor!!
  9. Pics of the new setup with single plane.
  10. are they the same
  11. SBC heads on an LT1 - Who?
  12. LOW OIL light
  13. free ram air mod?
  14. Oil pump Part number??
  15. Convert to synthetic?
  16. LT1 Water pump Help!
  17. is my trap speed low?
  18. lt1 balancer question
  19. LT1 Guru's, take a peak
  20. what spark plugs are good?
  21. Need help/advice.
  22. Want to Hear a 305 114 LSA idling low..
  23. tap tap tap..
  24. My cammed LT1: cc503
  25. OBD2 KS compatible with a OBD1 Swap?
  26. Hot Cam Costs
  27. LS1 airbox
  28. Exhaust Leak
  29. Lt1 1/4 mile times
  30. k member removal questions
  31. Bleeding the clutch??
  32. Looking for emissions legal headers and y-pipe
  33. cam for a 396!!!!
  34. need advice on building this LT1
  35. Ordered some new parts
  36. Lt4 Km
  37. Lt-1 ?
  38. No muffler?
  39. Anyone have problems with 1.6 S/A rr's and a big cam?
  40. Effects of different 02 sensors
  41. High temp spark plug wires?
  42. Oil pan?
  43. Emissions
  44. Replacing the stock muffler (not catback)
  45. Quick Q about Cam Lube
  46. 355 Pistons?
  47. 383CI LT1 How much power?
  48. Ah F*** - RANT Time
  49. high performance oil pump
  50. 94 LT1 5.7 chevy block?
  51. Anybody think this intake could be converted to fit an LT1?
  52. painless hi-rpm kit
  53. Main stud torque spec
  54. Cam & valvetrain guys - couple questions
  55. Max Rpm
  56. SA or NSA RR's? Help
  57. Rocker Adjustment
  58. Where to buy LT1 shortblocks or cores?
  59. engine bay color change
  60. Headers, Y-Pipe, Rocker Arm questions
  61. Pistons rings
  62. Need photoshop help please! =)
  63. I cant figure it out!!
  64. simptoms of arcing in the distributer
  65. Body control module?
  66. Best was to get a 305 long block into the back of a truck
  67. LT Headers w/ Emissions...other parts?
  68. LS1 Lid under Stock Camaro Hood
  69. $ for new head gaskets?
  70. Head Gaskets?
  71. 4:10 gears
  72. Anyone need a long block. (affordable)
  73. Needle Roller Cam Bearings: what are the downsides?
  74. 99 LS1 over my LT1?
  75. A bad night...
  76. Comp cams 292XFI
  77. Ss Hood Shocks
  78. Delteq on the way
  79. Its DEAD!
  80. Intake elbow/nitrous questions
  81. F1A on the way for the LT4. have Q's?
  82. Finally Time for a Cam! Which one?
  83. Spark plugs
  84. What plugs should I use???
  85. lt1 OTVC spark wires problem
  86. all you 396 lt1 guys
  87. type of water
  88. Quick, anyone have the link for going from non vented to vented opti?
  89. D1SC guys come on in!
  90. Need some LT1 tuning help
  91. HP tuners?
  92. TH350 ?..... on 383 lt1
  93. Going Rate
  94. Timing Chain....
  95. R & R fuel pump questions?? Need Help!!
  96. opinions on which tranny to run...
  97. T-56 Clutch problem......
  98. Posi locks grrr..
  99. Help a long time lurkers idle
  100. Where to buy a bare block?
  101. LT4 Knock Module on '93?
  102. Destroyed it
  103. Headlight Conversion??
  104. Edelbrock LT4 Heads
  105. reomve oil pan with motor in car
  106. alternator relocate?
  107. Finally ordered my 355 rotating assembly
  108. Injectors?
  109. I need part number for the Comp Pro Magnum 1.6's
  110. Ticking noise
  111. any suggestions? slight miss in my 94z
  112. Header question
  113. heads I seen a pontiac mag (high Performance Pontiac feb 07)
  114. Info I found today. For all those wondering which cam and comp.tune for street LT1
  115. y pipe
  116. Mounting RAdiator Vertical
  117. diagnostic prob
  118. How much are custom cams..I need cam help.
  119. lt1 knock sensor?
  120. cam suggestions for 94 z28 LT1 6 speed manual
  121. Bone stock LT1 6spd car
  122. Need to know cc's on GTP LT4 heads
  123. Do You Peepz Remember...
  124. spark plug question
  125. at what horsepower are you having trouble
  126. is this dcr or scr ?
  127. Lt1 Cam Rant! Others Will Agree With Me!
  128. lt4 hot cam, or CC306
  129. LT4 Hot Cam ?
  130. 383 LT1 fuel pump reccomendation
  131. Has anybody built their LT1 using a 2-piece rear main seal adapter?
  132. Any ideas on how to run the alt only when deleting the PS, AC, ect??
  133. off road y pipe
  134. Brian@pcmforless
  135. LT1 Dream Team?
  136. High stall for 700R4?
  137. need clutch help on a 95 hawk
  138. oh, no, mister bill, not another cam thread!?
  139. 1.6 roller rockers
  140. water temp guage
  141. LT1 What cam? I just want the damn thing to lope as hard as it can.
  142. vacuum line re-route
  143. Whos Opti-spark Should I Go With
  144. IAC Question?
  145. 98 Z28 LS1 Question Vs Bolt on LT1
  146. help with 4l60e
  147. 1.7 Rockers on an LT1?
  148. need some cam help
  149. Replacing Plug #8 - LT1
  150. Engine bearings
  151. LT1 turbo headers and parts
  152. 4.10 Gears on my Z28
  153. heads and cam??
  154. gas mileage
  155. 58mm TB gasket
  156. Scat vs Eagle
  157. 355 with cc306 question.
  158. Please Help My Formy
  159. Good budget heads for a rebuild?
  160. which motor mounts is this k-member for?
  161. Lt1 Ws6 Hood
  162. What springs do I need?
  163. Anybody Have Le2 Or Le3 Head Porting
  164. Fresh motor problems starting. Help!!
  165. valve cover removal
  166. Need some opinions on oil psi issues
  167. Headers on...finally!
  168. cam swap: rockers and timing set ?'s
  169. has anyone had this problem?
  170. info on sunoco hood
  171. Tunercat help
  172. trade or sale my zo6 wheels !
  173. calculating DCR on LT1/LT4
  174. Anybody with 93's have long tube headers and retained single wire 02 sensor???
  175. oil change= lower pressure
  176. Benefits of Internal Balancing
  177. Miss after 9" and Racetronix Install
  178. 3500 stall to high for nitrous
  179. 93 Fuel Pressure Regulator
  180. running with no coolant
  181. Does the rear side of the block get painted?
  182. LS1 PCM on LT1.
  183. ARP main studs
  184. 93`s and pacesetter mids help!!!
  185. What 02 sensors do I need???
  186. LT1s from the olden days
  187. how awsome is it that there's a dyno at the track now
  188. LT1 #4 finally bought a good one
  189. wierd thing happening (car "bucking")
  190. going to dyno tune what #s should i get
  191. Plug wires
  192. Clean LT1s harder to find?
  193. is a lt4 knock module important??
  194. 97 LT1 back firing or breaking up - need help
  195. Has anyone tried this at all?
  196. DCR to shoot for
  197. Greg Good - Anyone know his contact info?
  198. C1242: Rear Esb Does Not Hold Motor
  199. OMG...Did I just ruin my new cylinder walls?
  200. Kinda need some direction...
  201. need help with some parts numbers
  202. Need answer about a cam.
  203. oil pressure
  204. What are 374 heads worth?
  205. Where to buy bushed wrist pins?
  206. CC305,CC503 owners inside please...
  207. 9 inch pics...
  208. What you guys think..
  209. fuel pressure
  210. ARP Intake Man. Bolts
  211. People with SLP CAI and TF Elbow come on in!
  212. went to the dyno today
  213. your opinion valued
  214. My new supension set up
  215. Need help/info asap
  216. motor and tranny
  217. Replacing LT1 barings
  218. Car won't start when its cold out
  219. Slp Cold Air Lt1
  220. cut and extend harness?
  221. Need a 96 LT1 ignition module!
  222. throttle cable question for carbed or single plane guys
  223. Coil dual connector plug
  224. got a quote for lt and td install
  225. Air pump removal
  226. Best LT1 cam for mild headword
  227. speed pro 383 pistons - HP capacity?
  228. lt4 flexplate ?
  229. lt1 problem!!!
  230. connecting rods??
  231. Took it out today
  232. Low oil level sensor??
  233. Alternator Relocation Kit
  234. Which water pump?
  235. Squeak/Chirp coming from under car at low speeds
  236. Ewp Heating Problems
  237. which clutch to buy
  238. Baaaaaaaaaaaaaarrrf!!!!!
  239. STS turbo kit install? driveablity? MPG? etc?
  240. whos got the best deal on opti's?
  241. 396 LT4, Needs TB.HELP! Mono or twin 58mm?
  242. I know this is not the section for this but, I Need a 96 LT1 (6-speed) engine harnes
  243. Can i offset my rear wheels?
  244. valve spring question
  245. slp air intake ?
  246. buying a high mileage lt1=bad idea?
  247. New Coil
  248. special way for porting LT1 intake manifold
  249. Car has trouble starting after new motor
  250. -40* Timing?
