- Stock parts from silverado 5.3
- SLP Loudmouth 1 --250.00 + Shipping--
- MTI Stage 2e heads
- New Never Used LS2 coil packs with brackets and wiring
- Stock trans am ws6 wheels and tires package for sale.
- 2 NEW Front Cross Drilled Zinc Plated Rotors + all stock front brake components 98-02
- airesearch/garrett 90mm thumper turbo. 3 core intercooler/50mm wastegate
- 01 LS1 engine w/ Acc
- diablo predator, slp lid&holley filter
- T56 Reverse Slider/Synchro Assembly
- WTB LS2 Water Pump and Balancer
- 4-cross drilled and slotted rotors/pads
- 6.0 Truck parts Need to Go!!
- l76/l92 car Intake & ls7 Intake Never used
- 08-09 Pontiac G8 front license plate holder
- WTT : 4.10 gears for alum. drive shaft
- NIB Custom Diamond Pistons 383
- LS2 90MM Intake Manifold, Fuel Rail, and Injectors CHEAP!!
- 2001 z28 steering wheel with airbag
- FS: 2001 Long Block LS1 with AFR 205 Heads/Tsunami Cam and MUCH MORE!! $4000
- 241 Heads off of my 02 WS6 w/Precision Race Component Spring Kit
- GMMG Exhaust - Crane Tuner - K&N Filter
- for sale bbk 80mm throttle body and nav indash
- Superior Shift kit 4l60E 98 and up
- 04 kooks catted mids, pair of stock BFG KDWS tires, stock GTO wheels with MT DR's
- Camaro ss custom pedals
- Fast 90/90
- forsale! 4.030"wiesco turbo pistons,stock 317 heads, 6.0l truck block,and more!!!
- fs/ft pro stars
- Brand new set of Z06 243 Heads
- Guaging Interest
- 10 Bolt! Cross Drilled Rotors, Sway Bar, Diff. Cover
- BMR Race LCA's, ASP pulley/belts/bolt, Bolt-in SFC's, TTOP shades, white z28 spoiler
- 18" Dynomax Bullet 3" In/Out.
- HP tuner 99,00,01 f body
- Edge 3600 stall
- FS: MSD Digital Window Switch
- NEW 2X Weld Racing ProStars 15x3.5"
- Intake and misc. parts for sale
- FS: NX kits and 30lb injectors
- FOR SALE 85mm MAF w/harness, center mount valve covers, LS6 valley cover....
- NIB: Comp Custom LS_ mild turbo cam
- NX Gemini Twin plate kit, 4150 flange....major hp!!!
- Stock spoiler (black) F/S
- UMI chrome moly double adj Panhard bar on ebay
- FS: Rear Koni SA shocks...
- FS or Trade Comp cam 228/230 .588 .592 110+1
- m6 gto radiator
- Intake/elbow, cam, throttlebody, heads,etc. FS
- Brand New Hal 275 front springs, Slp DS Loop
- Ls1 intake manifold, cam and pushrods for sale
- C5 Corvette Wagon Wheels - $200 - South Bend, IN
- FS or Trade level 4 fully built 4L60E
- F/S SLP Loudmouth cat-back in KY - $200
- EFI Live, starter, MM, LS2 Intake, #32 Inj., MSD Wires, etc.
- 98 camaro ss parting out
- 98 Chevrolet Camaro Z28 5.7L LS1 Engine & 6 Speed Trans
- FS: Chrome Meziere for LS1
- Cleaned out the garage sale part 3 (interior &miscellaneous)
- Cleaned out the garage sale part 2 (exterior related)
- Cleaned out the garage sale part 1 (drivetrain related)
- FS: Hurst Billet + LSS
- Clear corner lights. Camaro rear firebird front new
- Ls1 Parts (Close out sale)
- TR 224 Cam!!!
- SLP TCS Module / BMR Relocation Brackets
- Ebony Cloth Seats Camaro Z28 SS
- FS: Brand New PI Vigilante 4000 stall
- ETP 11 degree 215cc heads for sale
- Idler Pulleys / Relays
- LS6 intake, W/ gaskets coolent block off and crossover tubes 325 shipped 0 miles
- 4.56 gears, boost gauge, differential temp gauge
- FS: Bassani True Duals!!
- ls9 heads complete brand new *pictures*
- Edelbrock panhard rod/MTI clear lid/Stock rockers
- 205 afrs,90/90 fast with fogger,custom cam,30lbs injectors,pushrods
- Bmr torque arm relocation
- Hotchkis lcas
- A/C compressor
- tci sfi ls1 flexplate & lokar flex dip stick th 350
- procharger fan w/ shroud and radiator support
- FS:LS1 Corvette rocker arms 50k miles
- Cometic .040'' Headgaskets F/S $70 shipped and PP'd
- LSX parts for sale
- Garage Sale, SLP, Honey Comb Taillights, ASP Pulley, Drag Launch,etc
- Under-drive pulley, cam, headers, SLP lid, Holley filter, Nitrous kit and more!
- stock ls1 intake an fuels rails/ injectors/throttle body
- FS: Moser 12 Bolt
- Paxton Novi2000 Centrifugal & Accessories
- ls1 intake and throttle body
- Truck 6.0 parts off of crate motor
- FS: Stock throttle body
- new in box red powdercoated BMR k-member and a-arms
- F/S factory Monsoon Headunit out of an 02' SS
- LS6 intake $250 near chicago
- wolfe roll cage in texas plus extras
- 65lb Injectors Precision Turbo Flow matched
- wtb stock headers and cats
- Vortech X-Trim
- Hurst billet shifter
- SLP TB bracket for L76/L92 intakes.
- LS1 intake, TB, Flowmaster, Magnaflow tips, A/C parts, Misc.
- new bare dart pro1 225's , and stuff....
- camaro vht'd tail lights
- FS: New misc gaskets/f+r covers/cometic head gaskets
- NBM Berger Panel, Great Condition, No Fill-Ins
- Very nice drivers side tail light(99 Camaro)
- Non-EGR 6.0 iron manifolds
- FS: MTI stage 3r heads
- Parting Out LS7 Build
- LS1 Cammed Longblock out of my LE
- WTB: F Body Power Steering Pump Assembly for LS1
- LS7 clutch pp and flywheel, and Sintered Iron disc
- Parting out 2002 Trans Am WS6, Ohio
- Two PHRs for Sale-Double Adj & Non-Adj.
- FS: Brand New Magnaflow Cat-Back for F-Body 15684 and 16723 never opened!!
- K&N Filter/ Billet Valve Cover Breather
- Parting out 2000 Camaro Z/28, Ported FAST 90/90, built T56, Tex twin disk, draglites
- Kooks 04 GTO Catted 3" Connecting pipes - $350 Shipped
- LS6 intake, true duals, aftermarket suspension, etc
- Complete aftermarket Gauge setup + extra gauges
- Grey T Top shades.... never used.... mint
- 315/30/18 MT ET Street Radials F/S
- 93-02 6sp B&M ripper..new style...$120 shipped
- For Sale 241 heads
- 4.56 motive gears out of a 12 bolt
- Stock Springs from 2002 TA
- Trans Am taillight. Passenger side.
- FS; Chrome Firehawk Wheels 17x9.5"
- LCA's, Swaybar, Sub w/box, 200 amp alternator
- 4l80e 12,000 miles
- fast fuel rails
- lpp stainless longtube headers
- 93-02 F-body QA1's and nitrous (new) cheap, need to sell
- C5 18" - 17" wheels FS
- 317 heads, eagle rods, weisco pistons
- Spare tire jack
- 2002 Z28 GM Catalytic Converters 4 Sale, Approximately 500 Miles On Them
- ASP Pulley,B&M Ripper, Rollmaster Double Roller, 6.0 crank
- FS: Granatelli Motorsports Lid, C5 Z06 style Z28 badges
- LS6 Intake 345 shipped!!!!
- LS2 LS1 Nib 415 cu in Rotating JBA Shorty Headers
- Fast90/90, TNT, Wolf Sway Bar
- BBS style wheels
- 98-00 WS6 wheels polished
- FS: NIB PowerStop rotors F&R!
- Ported LS2 intake manifold, Lingenfelter intake, Remote bleeder 6speed,
- feeler...Built 454 lsx camaro partout, everything must go.
- Remotte bottle opener 98 wireing harness
- Some stock parts.
- For Sale: Silver MP122 plus extras
- F/s ls1 stock fuel rails
- Fs/ z06 85mm mass air flow
- FS: Lots of random things turbo nitrous etc see what you need
- FS: (2) Michelin Pilot Alpin PA3 tires
- 1721 cam 4-sale $50.00 shipped
- Brand new 4.10 gears w/ Installation kit
- FS: 04-06 GTO Curt Mfg Trailer hitch & Extras
- Custom Cam 244/250.
- FS: HP Tuners Pro - hardly used.
- Procharger Oil
- Futral F11 cam, suncoast airbox, stock valve springs, ac parts, exhaust system, etc
- FS: Great condition CLUTCH
- Bolt-in LCA relocators
- ds t-top,monsoon,hurst,more.....
- FS: Perfect condition LS1 lifters
- I have 1994 Z28 Partout
- Avon M500 Tires - Brand New
- NIB Mac High Performance Air filter
- l92 heads complete with rockers!
- FS: 2 - 16 x 8 Firebird/Trans Am Chrome Wheels $75
- WTB: ls2 or ls3 block in CA
- Cold Fusion Stand alone system
- Gm 6.0l head gaskets
- Wideband w/sensor
- YSi Supercharger
- Chrome C6 Rims with Pirelli Tires 800$
- full A4 swap
- Manifold and Cats
- Fs mgw shifter
- Trickflow 7.500 pushrods
- Kooks 3" Dual midpipes for 05-06 GTO with electric cutouts
- Bunch of 4L60E A4 swap parts
- a lot for sale. TAKE A LOOK
- Bogart wheels with hoosier slicks and skinnies for sale
- lca relocation brackets, a4 shifter cable
- Almost Compl. DynoTune Nitrious Kit
- 7.4 Comp Cam Push Rods
- NIB Gtech pro rr
- 1999 C5 Corvette 5.7L LS1 Chassis Engine & Manual Trans
- F/S: Nitro Dave's Stand Alone Fuel Cell
- 05 Pontiac GTO LS2 Engine 6 Speed Transmission 63K
- 4 Corvette Air Pressure Sensors
- Thunder CheateR cam
- XeSSive custom grind
- FS: LS6 intake
- Janzter Ported throttle body
- FS: UMI Rear Susp, Lokar, comps cam, 65E, B&M stall, Nitrous/bottle.....
- Gauging Interest: Spec Aluminum flywheel for LS1/LS6
- FS: ASP Underdrive Crank Pulley for LS1 (Virginia)
- MTI stealth Cam II
- Patriot Heads FS
- FS: 347 Ls1
- M/T 26x11.5x17 ET Streets...like new!!
- 2 17x9.5 Z06 wheels
- Stock 16x8 Camaro Rims and Tires
- FS SDCE Procharger bracket and Dual intercoolers with all pipes
- Few item $$$$$CHEAP$$$$$$
- F/S--Hal/QA1 Front Double-Adjustable Shock & Springs
- ls9 heads brand new
- l92 heads $300 shipped
- Autometer trans temp gauge
- Strange master cylinder
- Cam swap stuff including cam
- FAST LS intake
- Sweet thunders and magnaflows (true dual mufflers)
- NEW LS1 LS6 block
- FS: Z28 Parts Stock and Aftermarket
- FS: 2002 LS6 pistons and rods
- F.S: 317 's 6.0 Manifolds and 6.0 Parts
- Z06 valves,timing set,crane spring tool,dual springs
- Mickey Thompson ET Streets on Stock 16's
- Drag Pack - M&H, GTO Spares, Spacers
- HP Tuners Pro, NGK AFX Wideband
- 16" Trans Am Wheels w/ Tires
- 10 lb. NOS Bottle
- Passenger fender needed!!!!!
- GARAGE SALE (ttops, cam, shocks, mickey thompsons, LCAs, etc...)
- Misc parts
- FS- NIB AlkyControl Progressive Meth Kit with Fuel Cell
- CME exhaust and valance for sale
- Turbo Kit FS/FT
- Ported LS6 heads with Dual Springs
- JBA Shorty Headers 04 GTO
- Borla catback exhaust
- Hooker Longtube Headers
- Whisper Lid
- 2 brand new F-body '02 sensors
- 248/242 XER comp custom cam 116lsa for turbo car
- JE dish pistons for sale stock stroke 6.0 4.030 bore
- random car parts FS
- greddy oil catch can.. cheap!
- door parts , mirrors, glass, regulaors handles , power locks
- Weld prostar fronts w/tires, spacers, lugnuts, tan leather door panels CHEAP!
- MTI Stealth II Cam
- FS: Livernois stage 2 243 heads
- 6.0L Iron Heads and Truck Pan
- Gauging Intrest: 2 Boyd Smoothie 2's 17x9's
- Cleaning Garage: Tons of engine parts..
- FS: GTO bell housing $175 shipped
