PDA
View Full Version : Generation III Internal Engine
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 [20] 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293
  1. Which headgasket-Have TFS 235-6bolt-on iron 408 4bolt?
  2. Is This Normal (pics)
  3. 706 Heads on LS1
  4. 317 Head questions
  5. Is it normal for ls1 engine to burn oil?
  6. Id'ing a LQ4 vs an LQ9
  7. Valve Train Exposed
  8. Valves wont seal?
  9. will this make 400fwhp
  10. How The Hell Do I Line Up Dot-To-Dot?!?!?
  11. Heads and cam swap?
  12. want a recipe for 10 sec cam only nitrous car.
  13. ls6 heads or heads ?
  14. Timing chain after cam swap
  15. GM MLS gaskets on 408 w/ 4.030 bore?
  16. Question About Intake and Valve Cover Gaskets
  17. $115 cam on ebay
  18. COnsidering these cams, input?
  19. oil pressure dropping above 2.5k...
  20. 2000 ws6 cam
  21. sps rod bolts?
  22. how much pwoer you guys making with a 6.0
  23. LQ4 block
  24. It started as a header install...
  25. Lq4 top end question
  26. Well, this sucks.
  27. ls1 crankshaft limits
  28. How much to mill on LS2 243s?
  29. cam size vs gas milage
  30. Street sweeper HT VS XER281HR
  31. Tips for cleaning out head bolt holes...?
  32. Parts shopping list (suggestions and input needed)
  33. 2000 LS1 Questions
  34. Engine rebuild tips
  35. Tweaked 5.3 Power Level?
  36. 24tooth to c6
  37. simple question
  38. Doing some mods very soon.. what kind of dyno #'s should I expect?
  39. Lifters from Blown Motor, Useable
  40. Question. Aftermarket cam stock motor.
  41. need help... ASAP
  42. Rear Main Seal
  43. Opinions on GC 0w30.
  44. Best Cam Only but H/C later
  45. Ls6 heads ported vs. unported
  46. Difference between these two cams?
  47. camshaft journal
  48. New throttle body...throttle cable to short
  49. regrind cam
  50. oil pump question
  51. Melling Oil Pump 10296 - A Few Questions
  52. anybody dd a t rex cam mpg?
  53. Do I really need a new oil pan gasket?
  54. Engine? Vibration - Help!
  55. Engine wish list stuff
  56. Ms3?
  57. Any 6.0/MS4 with 2.5 PRC making good numbers?
  58. rocker arm install
  59. Any benefits from turning ls6 cam at 112lsa???
  60. 240/244 608/613 114 408 who's using one
  61. oops
  62. Etp cylinder heads pushrod hitting side of wall please help
  63. Car Started Once, Wont Start Again
  64. cam question for those in the know
  65. DTC0106 after cam install
  66. F13
  67. To all ms3 six speeds????
  68. timing chain question?
  69. Peak RPM?
  70. Help! Found a small spring after oil change(pics)
  71. Getting the rear cover to seal
  72. Finally some dyno numbers!!!
  73. horse power on tiny budget
  74. What do you think happened ??
  75. 317's and cam stock ls1
  76. ms3 vs mti x1
  77. Pushrod length for LS1 to LS6 cam swap???
  78. Morel lifters/pushrod length?
  79. shorty headers bad?
  80. 60lb injectors too big for cam only?
  81. 5.3L or 6.0L Block
  82. Stock Pushrods OK With Dual Springs?
  83. 6.0 compression ratio?
  84. custom grind vs. shelf cam
  85. What kind of power should I expect with this setup?
  86. old racer
  87. 4.8 and 5.3 head difference
  88. Is using a 4.085 cometic gasket ok w/4.040 bore?
  89. stock 5.3 heads
  90. ANOTHER spun bearing??
  91. SI6 cam?
  92. 5.3 cam limits
  93. Chasing a Knock/Tick
  94. arp rod bolts
  95. ls1 swap
  96. whats your 408 6.0l setup
  97. LS1 Noob...Couple questions doing a rebuild
  98. Problems with Harland Sharp stock rockers pics inside
  99. PP 80MM TB question
  100. Head flow velosity?
  101. 918 springs
  102. ls6 coolant line
  103. Changing oil pump and timing chain
  104. what changes were made to the trans am ws6's from 98-02
  105. What to do to build a Forged Shortblock
  106. question lightest cranks
  107. Timing chain replacement Q
  108. spring specs on 02 317's anyone?
  109. PRC or TEA spring kit vs COMP 921 kit?
  110. ms3 cam only build plans
  111. Where can I find a head bolt tap???
  112. I know...Another PTV Question.
  113. my head studs dont look right
  114. Compression Figure
  115. Question about LS4 oil pump ( Part# 12571885)
  116. swapping heads...853s to 243s? couple quesstions
  117. Question about rods
  118. cam in 5.3
  119. LQ9 Swap, What to do ???
  120. Replacing pistons and rod bearings with motor in car?
  121. pushrod question
  122. GMPP LS6 Engine Swap Notes
  123. PAC 1218 Springs?
  124. lifters for ls1? lunati?
  125. vengence vindicator cam owners?
  126. a better view of my cracked piston
  127. stroker reliability
  128. Yay! I blew my engine!!!:(
  129. Got the ARP bolt out......BUT!!!
  130. Can someone give me a rundown of all the LS1 factory heads?
  131. help me t-shoot
  132. help with cam decision
  133. 92mm throttle body
  134. pictures of my blown ls1 (kinda sad)
  135. good head cam combo
  136. Lunati Voodoo 60511
  137. LS6 243 head prep questions
  138. [PRESS RELEASE] Katech Performance Launches Online Store
  139. Time to start it
  140. Always knew there was a problem
  141. 5.3 build ?'s
  142. Cam for 5.3
  143. Looking for most aggresive cam for stock LS1
  144. cam specs
  145. cylinder location
  146. What parts for high compression bottom end that will turn 9000 rpm
  147. 5.3 buildup
  148. 6.0 build questions
  149. Cam / Springs question
  150. GM MLS head gasket
  151. Tr230/336 112
  152. what springs should i get
  153. What size injectors?
  154. LS6 build advice?
  155. well now it runs, but......
  156. LQ4 build specs, anyone wanna check them?
  157. edelbrock victor Jr LS-R heads?
  158. T Rex Cam P to V issues
  159. JP performance timing chains
  160. Help! 6.0 or 5.7 LS1!!?!?!?!?
  161. race vs standard bearings??
  162. About to order my cam, have some questions
  163. Valve spring shims - LS specific
  164. possibly a noob question about LS1 heads on an LQ4...
  165. Compression on a 5.3??
  166. TSP Discount code???
  167. TFS 215's with morel lifters what pushrod length??
  168. Got tune?
  169. Cam help
  170. how difficult...
  171. HELP me get this ARP crank bolt out!!!
  172. Need a few bearings and torque specs
  173. Building LSX Hybrid SBC
  174. Baking Pulley Torque ?
  175. 5.3 cam ?
  176. Porting Typhoon intake Questions Inside
  177. Installing new valve seals have ???'s
  178. Would you rather have torque or horsepower?
  179. Whats the current best head on the market?
  180. Solid roller cam with hydraulic lifters gained 28 rwhp!
  181. Upgrade rocker arm studs?
  182. new comp 918s...the problem wasn't fixed
  183. yella terra rockers with 98 heads?
  184. Different kind of noise...not a tick
  185. Piston Ringland Compression height for Nitrous?
  186. New to LS Engines, have some ?'s
  187. Did i screw up ?
  188. Another 918 down the drain.
  189. Installing stock main bolts
  190. Help LS1 crash damage
  191. TR228 cam, thoughts
  192. underdrive pulley
  193. Stripped oil pump/pick up tube hole...need advise
  194. stock ls1 cam
  195. what do you think?
  196. Ms4 vs g5x3
  197. What type of spark plugs for etp heads
  198. is it ok to reuse head bolts?
  199. copper head gaskets
  200. What happens and how fast will valve guides wear with 650 lift cams ? guides replaced
  201. Rocker pushes down spring when torquing them down?
  202. need head gasket help!
  203. cracked head bolt boss opinons needed
  204. 2000 ws6 cam
  205. Anyone here purchased a burned longblock?
  206. cubic inch ls1 questions
  207. heads and cam setup?
  208. cam install
  209. Cam only to h/c combo... opinions wanted??
  210. Melling 10296 Install ?
  211. Internal Balancing
  212. 408 guys, couple questions...
  213. what to do next .....with poll!
  214. morel lifter install question
  215. TR 230/224 Idle Clip, untuned
  216. Ls1 crankcase breather?
  217. Melling 10295 oil pump users in here please...
  218. Anyone loan or rent me their JPR cam tool? Please!
  219. How to convert Mod/Tod to any video formats
  220. my ls6 block and my thoughts on it
  221. Got $ want a short block, 408...
  222. firing order by degree.
  223. just installed ms3 cam and.......
  224. Edelbrock heads, which valve seals?
  225. LS1/LS6 How can I Tell?
  226. proper lifter prep ?
  227. kind of shakey?
  228. Crank rotation
  229. Dipstick tube & piston stop..
  230. Cam Difference
  231. ls6 block
  232. Lets examine my SES light
  233. help
  234. Best Rockers
  235. Best cam/torque converter combo for 4500lb whale
  236. When Lifters should be replaced?
  237. Whats the best headgasket to use w/408ci engine
  238. will ported heads make exhaust louder?
  239. new GM crate engine
  240. Does anyone have any experience with these roler rockers?
  241. is it possible
  242. Head Bolts/Gaskets....
  243. Idle problem/whistling
  244. compression questions
  245. part number for head bolts...
  246. Ported or not?
  247. WTF! ARP head bolt snapped!!!!
  248. HELP! ticking now misfire.
  249. Comp cam 228-232 114 xer v.s. Mti x1
  250. oil loss,when accel hard smokes
