PDA
View Full Version : Generation III Internal Engine
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 [28] 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293
  1. Need help with a head casting #
  2. I have cam questions
  3. Question aboout seating and installing valve seals...
  4. let me know what you think
  5. Piston interference with this cam?
  6. Cam question
  7. Injectors maxed out?
  8. Rocker question
  9. what mod should i do next PLEASE HELP!!!!!
  10. what cam for stock exquast system
  11. just picked up a 5.3
  12. well.. the heads are coming off
  13. LQ4 help!
  14. Help with a stroker...
  15. oil pressure problem, please help asap. searched, searched searched.
  16. ls1 ls2 difference
  17. what length push rods? help
  18. cam reccomendations
  19. ls1 & ls6 short blocks
  20. PTV Clearance on this combo...
  21. I need help now!!
  22. Gains from P/P 241 heads and 1.8s?
  23. which cam to use with patriot stage 3 heads
  24. ls6 head swap
  25. heads cam install questions / pricing also compression
  26. vrx3 cam ?'s
  27. more displacement HP gains
  28. Debut of New Ultimate Race Aluminum LS Engine Block by RHS
  29. Replacing front main seal. I can't get the old one off!!
  30. Cam setup
  31. RoyalPurple 500FT. TQ. 6 EZ STEPS
  32. which motor should i buil 346ls1 or 370 6.0
  33. Valvetrain break in.
  34. which heads would you recommend for performance
  35. matter of opinion? Top end Question
  36. What caused my power loss?
  37. hci and a tr cheater cam.....post up!
  38. Clearancing Pistons
  39. need some help with trq specs
  40. turbo BMW guy looking for LS1 information
  41. Anybody use any cams other than comp? Isky, Lunati, Crane or some other brand.
  42. cam curious
  43. 95k 99 T/A---- to H/C or not to H/C???
  44. 5.3L LM7 Build Questions
  45. Can a 370 outperform a 383?
  46. Which kind and where to get valve cover gaskets and grommits
  47. High oil pressure!!! help
  48. PRC duals to Comp 918's or Pac 1218's question
  49. Convince me!!
  50. 243's on 4.8 and 5.3
  51. Another LSX cam question….Seriously this one is different
  52. Original street sweeper cam in an A4?
  53. newbie question:can you port stock heads?
  54. 40k on valvetrain....what to do????
  55. Oil smoke on Decelleration???
  56. PRC 237cc Specs / Flow / Pics INSIDE!!
  57. Red or blue loctite?
  58. 58cc heads
  59. Used Heads
  60. What is max lift for ls6 springs?
  61. pros/cons of running bigger injectors
  62. ls1 buying..need help!
  63. can you run bigger injectors without a tune?
  64. Finally got the vette up and running!
  65. Cam specs
  66. Casting numbers
  67. Lq9 deck height
  68. Small cam question...
  69. Dyno sheet
  70. MS4 cam spec question
  71. Breaking Port Ceilings / Rocker Stands from Head
  72. 227/231 .639/.643 on a 115+3. Thoughts?
  73. keep ms3 or go to ms4??
  74. Cubic Inches...
  75. Another Cam?
  76. just making sure on the bore size
  77. anyone use Livernois Dual valve springs?
  78. Mamo Combo in a 427??
  79. Forged Engine
  80. heads/cam setup question!
  81. Power/ET predictions?
  82. input on my build please
  83. cam 228r
  84. How to determine overlap with advance ground in cam?
  85. stock ls1 piston crown thickness
  86. Is my DCR too high?
  87. New G5X3 cam.. What parts do you guys suggest??
  88. New pushrods or no?
  89. Billet Main caps and bearings - Engine builders inside Please (pics)
  90. Opinions on cam specs
  91. ARP head studs torque spec wanted
  92. How does this sound?
  93. built in advance....
  94. Is this a sleeper cam or not?
  95. LS7 cam in an LS1??
  96. valve durability
  97. which cam to get?
  98. best h/c package for a dd...
  99. What's the weak point in my motor?
  100. Cam choice
  101. rod and main bearings ?
  102. Loose cam bolts.
  103. ls1 head porting
  104. Looking for feedback on the two-piece timing cover choices...
  105. Max RPM?Comp 915,Stock cam&1.8 rockers
  106. 59cc chamber and stock bottom guys come on in!
  107. looking for info on the Comp #7153 double roller timing chain set
  108. question about springs(in the head)
  109. Affordable head/mod question for 04 LS1 t-56
  110. Valve Spring ID?
  111. what heads would u recommend to use with torquer v.3
  112. 222/224 581 581 xer 112 108 ICL for Dart 225's daily driver
  113. LS1 head question
  114. Is piston selection critical?
  115. i cant deciede need help!!!!!
  116. haha funny cam install story
  117. what year is my ls1?
  118. Forged 347ci LS1 Motor
  119. Your thoughts on 228/234 .588/.598 112+2
  120. Stock Crankshaft Rating?
  121. Injector Question
  122. is there any guide on how to do a head swap
  123. Help on removing a head bolt
  124. Has Anyone......??????
  125. do i need anything else for my head swap?
  126. What would be the Better Setup ?
  127. small oil leak from between header and gasket?
  128. trick flow heads
  129. looking for info on a double roller timing chain set
  130. 6.0 engine stand bolts
  131. Best under the curve cam?
  132. what do you think about this cam?
  133. Bearing question
  134. Best under the curve cam?
  135. would i see a gain
  136. Interesting discovery about 853 and 799 heads
  137. lq4 6.0 accessories
  138. Can these fit?
  139. Broke bolt off in head during valve spring install, HELP!!
  140. prw shaft mount rockers?
  141. best oil viscocity/weight....
  142. just got some etp heads,now what cam....
  143. Comp 850-16 lifters
  144. Piston ?
  145. engine combs
  146. Headers
  147. Headers
  148. 6.0l heads
  149. Rocker help
  150. More aggressive version of Cheatr cam?
  151. need TSP Torquer V.3 Times and combos
  152. Should I Mill My PRC 5.3's
  153. Out Of the Box AFR 205's
  154. P0301?? Misfire HELP
  155. diagnosing coolant leak
  156. What cam should i use
  157. H/c help
  158. Need Help on Deciding on forging bottom end!!
  159. Patriot Dual Valve springs valve seal, which is Exhaust & Intake?!?
  160. I Have a Hesitation or Vibration,Please Help!
  161. Ajustable timing sets.
  162. 5.3 head question?
  163. Making a 148k mile motor live at 8-10psi (550rwhp)
  164. ls6 head questions
  165. Low oil press help
  166. 5.3L build, NEED HELP!!
  167. How far can you mill 243s?
  168. Stock Pushrods
  169. Are these any good????
  170. found a cam package,what do you guys think?
  171. tfs 215 vs. stock 241 power range
  172. compression -> power range
  173. stock bottom end 460rw 150 shot
  174. stock compression ratio
  175. Infamous Ticking relative to RPM?!
  176. LS1 vs LS2 valvetrain question
  177. sputtering?!?!?!
  178. VooooooDooooo
  179. Which head gaskets for nitrous build.
  180. Will LS6 heads clear a 5.3 bore?
  181. Need Help Please
  182. 1st LS1 Build Carbed
  183. 6.77 @ 102.95 mph with an internally stock LQ4
  184. Internal oil pan pictures...
  185. Torquer V3 Track Times
  186. How high can you safely rev a stock LS6 longblock?
  187. Got some Questions!!!!
  188. PRC and hollow stem valves breaking?
  189. Stock valve covers
  190. help to pick a cam
  191. ARP Head Bolts or Studs?
  192. Rod Bolts
  193. 427 Build up from LS1 to LSX baby!!!
  194. Comp 216/220-stick with recommended 915's w/1.8's?
  195. VoooooDooooo
  196. PTV Clearance measurments
  197. what a head case ???? etp , prc , patriot , afr ,
  198. What is the average price for machine work?
  199. Trying To Figure Out What Compression My Setup Is Making
  200. LS6 cam
  201. help with rod bearings
  202. what do you shift...
  203. What is preferred aftermarket cylinder head ?
  204. Va speed 228/232 idle clip
  205. Suggestions on rockers please
  206. Proper Tune new rings
  207. How big a cam....
  208. I think she needs some new bearings
  209. Stock rocker VS Aftermarket
  210. Not another cam question wait yeah another cam question
  211. who to get a "fancy" valve job from?
  212. Mamo Combo
  213. Possible broken valve spring
  214. Bearing clearance issues... Help Please
  215. Valve clearance
  216. timing chain dampener
  217. Piston to wall clearance
  218. lls6 intake vs bbk ls intake???
  219. Spec me a cam for a high compression 347
  220. Need info on ls1 arp head studs how many of each bolt?
  221. LS7 lifter perload?
  222. Diamond -8.6 boost pistion, What compression?
  223. New project
  224. Cam Swap Needs?
  225. need some help on project went awry
  226. Who is running this setup?
  227. Prying off LS1 oil pan...HOW?!?
  228. 241 heads vs 243 heads
  229. ording a cam setup tonight! read over please!
  230. Iron 6.0 In 98 Z28
  231. which heads should i add to my torquer v.3
  232. Help with head/cam choices
  233. best cam for heads and power
  234. oilpump and pickup tube bolts ??
  235. valve spring help
  236. 2.02 intake and 1.60 exhaust, to big for a 383?
  237. Whos running a lsx iron block or warhawk alum block
  238. heads and cam (PRC VS Patriot)
  239. Bore size and Head Gasket Size
  240. g5x3 question
  241. Starting off
  242. Installing LS6 oil pump in my LS1 today, any prep necessary?
  243. Heads: TEA Stage 2 LS6 vs. AFR 205
  244. Rebild Ls1 or Trade for Ls6
  245. LS6 hollow valves
  246. Best factory ported head for 370"
  247. .650 springs on a .651 cam
  248. 1998 ls1 vette stumbling at high rpms?
  249. heads??
  250. 1998 vette motor any pros or conns
