PDA
View Full Version : Generation III Internal Engine
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 [57] 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293
  1. afr 205 vs tfs 215???
  2. port matched heads
  3. Turbo
  4. ARP rod bolts vs Katech
  5. Wanting to rent flycutting tool
  6. cam lope
  7. cam swap lifter problem
  8. Porting question on head
  9. E-RAM SuPERCHARGER...wow..
  10. What would u buy
  11. What does a Underdrive pulley do?
  12. Cam Retainer Plate
  13. what size Push RODS?? "help"
  14. What Type Of Heads On 97 Corvette
  15. Seem to see more and more 383s lately...
  16. Cam Question
  17. Futral F13 Users Have you swapped out your F13 for anything? Results? Track Times?
  18. cheaper to build motor or have it built?
  19. oil change?
  20. ptv 243s and a 5.3
  21. Anyone had experience with a cam like this? v.custom grind
  22. Need Proven H/C Combo for 383
  23. new cam
  24. i broke a header bolt half way in the head. how do i remove it?
  25. tfs heads and pushrods???
  26. 12551364 casting 6.0
  27. SCR and DCR HELP
  28. what do you think?
  29. Does any have an ARP 8mmX1.25 bolt laying around?
  30. Flycut pistons
  31. LQ9 Heads!
  32. Cam Info
  33. ls1 went into puddle of water cai sucked up the water, what to do? help
  34. Can someone tell me if these rebuild prices seem right?
  35. Destroke a LS1?
  36. Rattling noise under the dashboard?
  37. Benefits of porting used LS6 heads versus buying new
  38. TFS heads & compression
  39. Theres alot of related post about this but none answered me
  40. ls7/caddy lifters worth it?
  41. Main bearing question
  42. 1st time engine build "HELP"
  43. 241 heads
  44. H/C 5.3 all motor
  45. Any sound clips of TR230/224 111?
  46. Looking for advice
  47. Changing Cams
  48. Part 2 of my headbolt hole problem.
  49. Please Help Nobody Has Replied To My Post All Day!!
  50. Nitrous pistons
  51. Need Help Maybe Major Problems!!!!!!!
  52. Need Help!!!!!!!!!!!!!!!!!!!!!!!
  53. 853's vs. 243's
  54. Heater is not hot just warm(HELP it's Cold)
  55. My Final list, PRC, TQRIII....
  56. cam retention plate
  57. will this work?
  58. What pistons for boosted 421 and where?
  59. Need Help roller rocker selection
  60. LQ9 - LS1 interchange able parts?
  61. New style rear-main seal, opinions???
  62. lq4 biggest stoke?biggest bore?
  63. Stock LS6 shortblock...?
  64. Whos the best to go with
  65. Ported pistons?
  66. Anyone have any #s for Patriot Predator heads?
  67. Power potential from these heads?
  68. Real world stories on heads?
  69. Valve spring
  70. curious on ur t2 clearance?
  71. help cant decide on cam
  72. to paint block or not?
  73. Should I...?
  74. Swapping sbc parts to 6.0 iron block
  75. Question on 44lb/hr Delphi 8.1L Marine Injectors
  76. FAST intake and EGR
  77. Heads for the TRak cam
  78. Got a Question
  79. what injectors should i use?
  80. oil pressure!!
  81. What oil to use wiht LS1 75,000
  82. Patriot Gold Install Height and #'s on Seat???
  83. How much better are the 243 LS6 heads over the stock 99 LS1 heads?
  84. Ok think I got my cam picked out
  85. 1.8 vs 1.7 roller rockers????
  86. 228r cam ?
  87. MS3 vs SI7 Cam?
  88. oil pressure too high?
  89. Comp Cam 54-000-11
  90. stroker owners need thoughts
  91. gm hotcam
  92. New AFR 235 cc heads
  93. 60cc TEA 5.3 Stage 1.5's with a Tv2, check my math!
  94. 19 RWHP from AFR 205 59cc?? Are you kidding me?
  95. J 43145 Alternatives?????
  96. Lifter choice with F14 highlift
  97. 386hp on a cam/header swap only
  98. ms3?
  99. are my 2000 LS1 heads 241's or 853's?
  100. did some 02 fbodys come with the ls6 block?
  101. Sputters after pushing it hard
  102. Looking for possible SCR and DCR calculations for custom cam
  103. In need of a used 5.3 or 6.o!
  104. Who Is Running 15w-40 In A Stock Bottem End Car??
  105. Maximum lift on stock 243s ?
  106. LS1 Stock Rods
  107. NA Stock Bottom Monster build coming to a close :)
  108. Do I need to machine a new block?
  109. which windage tray
  110. quick spring identification help?
  111. H/C/I questions and what to expect?!?!
  112. Good new and bad news...
  113. Thoughts on this heads / cam combo?
  114. LS1X warhawk heads!!!!!
  115. LS2 and LS7 Flywheel Same Part Number?
  116. Scorpion Rockers
  117. 383 cam
  118. Final cam decision - Poll
  119. rebuild suggestions
  120. PP S2 035 casting or PP S2 243??
  121. at what milage should timing chain be changed?
  122. Problem found( Damaged reluctor Wheel)
  123. headers
  124. Who has the best H/C package?? give me a good deal!!
  125. installing timing chain. stock oil pump.
  126. 00 vs 01 engines
  127. almost free LS1
  128. seafoam?
  129. Head gasket
  130. Will this Combination spin to 6700 RPM without Valve Float?
  131. Which heads?
  132. heads and cam at 103,000
  133. So Lost on picking a cam...I have researched and researched and...
  134. 243 heads LS2 and LS6 - how to tell the diff?
  135. Blower Cam Question
  136. MS4, PRC 5.3 2.5's or AFR 205's??
  137. Safe power level
  138. Stall questions!!!
  139. PTV clearence questions
  140. bad tensioner is throwing the serpentine belt?
  141. Coolant flush help
  142. Stock redline question.
  143. Can someone tell me what cam this is by the #'s on it??
  144. SLP 1.85 Rockers, Any good??
  145. Throttle body prting questions....
  146. what you think the number in the Dyno with this mods
  147. Help me out here please
  148. Oil Pressure Problem - Could it Be Accumsump Installation Related - Experts Please
  149. 24X trigger orientation
  150. Good way to check valve geometry with a stock rocker
  151. whats the better cam
  152. Start up of engine not fired in about 4 years.
  153. Proper way to check lifter preload
  154. 2000 rpm idle
  155. My Audi A4 for a LS1/6 short block complete take out
  156. Cat-back exhaust
  157. High Compression Heads and Cam Build
  158. Lifter Retainer Modification
  159. SCR10.23-7ccs=????
  160. Exactly what causes this crap...
  161. Ls2 timing set vs double adjustable set?
  162. Couple of pics of lightly ported 317 heads
  163. Any one know this shop in Cary IL.
  164. T-rex V.2 Or not
  165. destrokin my ls1
  166. Best Street/Strip Cam
  167. is this a good set-up?
  168. Best cam for LS1 Heads?
  169. 2000 vs 2001 z28 or ss
  170. what oil pump and timing chain
  171. Anyone have ptv issues with my setup
  172. alt bracket
  173. Yella Terra 1.7 Shaft Mount Roller Rockers for L92 Heads
  174. Non-radical cam to go with current mods
  175. what to should this make ??????
  176. Time to Start Modding at 85K, Need help w/Cam and Heads for DD
  177. What camshaft?
  178. 5.3 or 5.7
  179. Overheating problem!!! Please Help!!!
  180. Metal Head Gasket Question
  181. What cam with PP stage II (59cc) heads
  182. Problems with the Engine, Please Help !!!
  183. TR224...what shift points?
  184. Best Price on Yella Terra Ultra Lights?
  185. cheapest Scorpion rockers
  186. Horsepower predictions
  187. how much power you think i have?
  188. HELP!!!! Engine Surging PRoblems
  189. valve spring question!
  190. How can you tell if an engine has a spun rod bearing with motor out?
  191. Engine Torque question
  192. Degree camshaft? Is there a write up?
  193. cam question
  194. will ls1 head fit 5.3 block?
  195. Update to my smoking/Oil consumption issue
  196. new:engarde:stock
  197. Oil? leaking near driver's side
  198. Cylinder head shop in/around chicago il
  199. pushrod length checker.....
  200. GM #12498544 Head gasket question??
  201. 4.8 heads
  202. ring gaps
  203. Head shops in/around San Diego
  204. put down 394rwhp 384tq with small cam only!!!
  205. Help on a LQ4 rebuild .010 over pistons?
  206. cam ?
  207. cam dilemma...what would u do?
  208. Any results from Patrick G's "Donkey Dick" cam??
  209. Head ?
  210. Help Need To Find Shop In Chigago
  211. Vengeance, TEA, FAST, 348 max effort build!
  212. LS3 heads?
  213. ls1 cam only time ?
  214. ZO6 cam and ratio rockers
  215. is it mandatory to change to a ported oil pump and DBR TIming chain?
  216. F-Body oil filler neck
  217. Engine experts - Question about high compression Iron 408 - 12.5:1
  218. !WTF! Dakota beats my 4.8!!!!
  219. Question
  220. cylinder head install price ??
  221. This cam still O.K.?
  222. which heads?
  223. head/cam info
  224. Engine noise/knock
  225. How many times can ARP head bolts be whored?
  226. Cracked block help????
  227. i have 2 oil pumps, which do i use?
  228. what heads come stock on a LQ4
  229. Will this be a close one??? Pred-z, Patrick-g??
  230. Using Diesel Engine oil??
  231. How do i tell if the heads are milled or not
  232. Just asking?
  233. stock rockers with tfs 215 heads???
  234. Need valve locks +0.050"
  235. which underdriven pulley ?
  236. timing chain info needed 98 ls1 semi built
  237. Cam only A4, locked, any cam post up your Dyno #'s
  238. Huge Cam and S/C Opinions
  239. Quick question about factory heads
  240. Poss time to swap cams, need a recomendation
  241. roller rocker arms
  242. MS3 grinded advance?
  243. 6.0 stroke
  244. codes after installing tp and intake
  245. Max effort cam for not DD
  246. Whos car is this or what LSA??
  247. rebuilding ls1
  248. TSP 224 or 233 Cam?
  249. Highest legal NA hp in California
  250. best valve spring compressor tool?
